Everything posted by 80LS1T
From the album: LS1 turbo
Swapping out the LT1/T56 for an LS1/T56 + turbo!
80LS1T replied to 80LS1T's topic in Gen III & IV Chevy V8Z Tech Board
I got some C6 manifolds on last night. The passenger side is about 1/8" from touching the strut tower. Do you guys think I should just notch the strut tower a little or massage it a little with a BFH? I don't know if beating a strut tower even a little will mess with my alignment or if notching it will ruin its strength? Either that or I need to find another manifold that works on that side. -
How much did your salvage yard LS1/T56 cost?
80LS1T replied to kce's topic in Gen III & IV Chevy V8Z Tech Board
I paid $3900 to shipped to my door for a 2002 LS1/T56 with 48,000 miles on it. All accessories, computer, pedals, maf, harness, and ecm. I also was searching for months until the right deal came along. Most I that I have seen on Ebay for the 01+ LS motors and T56 combos go for $4000+ not including shipping....so more like $4500 shipped -
I removed the LT1/T56 last night and tonight I test fitted the engine with some 1" LS1 conversion set back plates that I got off of ebay and the MSA SBC mounts from my LT1. Fits like a glove. The only I thing I may have to do is attach the rear bolt on passenger side of the rack and pinion a different way. Thats the only thing hitting the oil pan. I might be able to just grind it down some. I'm just happy the oil pan can stay stock! Truck manifolds do not clear frame rails on either side. I'm going to try some flipped C6 manifolds next. I really don't want headers as weird as that sounds. Engine is sitting further back that the LT1 was! Probably 1-1.5" -
As you can see the engine is as back as far as it can go with the bell housing on the engine. -
Are you running the stock accessories and brackets for an LS1 Fbody car? I found out tonight that the truck manifolds will not clear the frame rails. The C6 manifolds look promising for me though!
Where is your radiator slammmed? -
I am actually going to ditch my initial design of the tank being mounting horizontal back by the fuel tank. I am gonig to make a new surge tank to go up in the engine bay with the high pressure pump and remount the low pressure pump in the stock location. I think my tank was too short and I was still sucking air into the high pressure pump. I wont know until after the engine swap if my new tank will work like it should though.
Wiring all components for the LSX Swap
80LS1T replied to kj280z's topic in Gen III & IV Chevy V8Z Tech Board
Man I could have used that switch 5 years ago for my LT1 T56! My switch connector touches the tunnel but hasn't given me an issue. Rockauto part # MOTORCRAFT Part # SW5857 Nice find! -
Well I recieved the engine and have started modding it. I decieded after much (more) reading that the bottom end will be fine stock.(knock on wood). So instead I bought some 317 heads with PRC double valve springs to lower the compression down. Other goodies include some Yella Terra roller rockers, 60 Siemens injectors, FAST fuel rails, and ARP head studs. Still trying to find a used LS6 cam so I can put this thing back together and start the mouting process! Feels good to be doing something like this to the car again, I think I like building stuff like this more than I like driving it! -
Thanks for the pics. The color is House of Kolor Cobalt Blue with a silver metalic base coat. I don't have the codes for them though...
If you can get a pic of your motor mounts and how close you are to the firewall that would be great. I'm trying to get an idea of how much room I will have for the turbo piping up in front of the engine. Oh and maybe a pic of the space in front of the engine! Thanks!
You'll have to swing up to Appleton when I start on mine to check it out! What are you doing to yours? -
Is the engine back as far as you can possibly go? Where does your shifter come up in the car? Car is looking good so far!
Thanks for the encouragement guys! I'm super excited to start gathering parts and get this show on the road! My original plan was to do a 6.0 LQ4 engine and T56 but after adding up all the little stuff to make the LQ4 basically an LS1 set up I didn't see the value in it. New intake manifold, different brackets, harness, water pump, balancer, etc.... Plus I after doing some thinking I like the idea of shaving 85lbs off the front end to help make up for the weight the turbo, intercooler, and piping will add. I'm going to order the pistons and rods soon. Some say you don't need them for my power goals but for about $1000 I can have a forged bottom end with a more ideal compression ratio. I've just seen too many boosted LS1's with broken 1st ringlands to not do it while the engine is out. I'm not going to go crazy with the rest of the engine though. The LS1 I'm getting already has the LS6 intake so I'll just run that. Im going to check the castings on the heads and if they aren't what I want then I'll be running some 317 castings with some upgraded springs and yella terra rockers. No porting of the heads this time. I didn't really feel like porting my LT1 heads was worth it in the end. Probably could have saved my money on that and done different power upgrades. As for the T56 I won't be opening that up either this time. Just going to get a nice clutch and roll with it. Haven't seen too many of these have issues so I'm not really worried about that. -
I honestly don't think it will live forever and I'm the kind of guy that likes to avoid problems if I can. Too many guys with FI LS1's seem to break the top ring lands so I'm a bit skeptical of what the stock motor can really take. Besides its cheaper and easier to just do it now when the motor is on a stand in my shop -
Well the time has come for me to swap out the LT1 for an LS1. I am bored with the power that it makes and I don't want to spend money on the LT1 to make it faster. So I have been watching ebay for the past few months looking for a deal on an LS1/T56 drop out and I finally found one! $3900 shipped to my door for a 2002 LS1/T56 with 48,000! I haven't recieved it yet but its on the way. I am hoping to pull the LT1 out soon so I can start mocking up the LS1. Plans are for an LS1 with flipped truck manifolds(personally Im sick of header leaks and the manifolds have supported 1000HP so they wont be an issue) and a single turbo. I am going to put forged rods and pistons in the LS1 and drop the compression down to 8.5 or 9.0:1(somewhere in there). The goal will be 500RWHP for the street with 600HP for the track! I want a monster and this should do it! I wish I could post more but with a full time job and starting my own automotive repair shop Im too busy to browse the forums as much as I would like. I'll be posting pics and info as I go along in the project though!
Well I finally had enough time to work on my car and get this thing built...but its not working as I planned. I ended up having a friend weld up an alluminum tank and put some fittings on it. The tank is about 1.6 liters. I used the Tsunami high pressure pump and a mallory 15psi pump. I think the 15 psi pump may be causing the malfunction that I'm having but I'll take any other ideas... Problem is that I can only build 30 psi of fuel pressure. I have the low pressure pump feeling the surge tank, the return line dumping into the surge tank, a line from the surge tank acting as a return line for the surege tank, and a line feeding my high pressure pump. I also have a check valve in the return line so that fuel from the surge tanke doesn't go up that line. I am stumped at this point, I figured the check valve would fix this but after installing it there was no change. I have tried adjusting the regulator but that hasn't helped either. It almost sounds like the high pressure pump is aerating but I find it hard to beleive with the surge tank feeding it.... Anyone have any ideas?
Oh and from what I've been reading about building a surge tank, I should use a low pressure fuel pump...so should I use something that is for a carb'd set up? Like 4-5 psi?
Im trying to avoid a custom fuel cell at this point. I like being about to use my filler neck to fill up so I'm trying to avoid a fuel cell. I think I am just going to have a buddy weld me up on out of alluminum. Im getting some rough dimensions tonight and then Im going to give them to him so he can have a look.
After installing a new Aeromotve Sunami fuel pump early this spring I am now running into fuel cavitaion in my fuel pump when I do donuts and when I run the tank below 1/4 of tank. This pump flows way more fuel that the MSD pump that I replace so thats why I didn't have the problem before. I bought this pump because I'm going to be swapping out the LT1 for either a 5.3 or 6.0 chevy sooner than later. I can't stand the LT1 and I'm bored with the power it makes! So the Gen 3 V8 + turbo will be a near future project! Anyways, I know a lot of you are running fuel surge tanks but where are you getting them? Summit doesn't seem to have them listed(or I can't find them...) and all of ebay's stuff is from Hong Kong or Australia(I'd rather buy from the states if I can to avoid any shipping issues). Thanks!
