ZXT_bean
Everything posted by ZXT_bean
  1. in my experience, i have a 80' n/a car, and used a 81' turbo tranny. the differences were the input shaft spline count, and the rear pinion flange bolt pattern. so i just swapped the rear flange and had no issues..
  2. ZXT_bean
    almost done!
    mafiaz, do you mind just posting the msq. file?
  3. ZXT_bean
    almost done!
    am i splicing the wire in line with the GB wire, or am i tapping the resistor into the GB wire and then give it a 12v+ source? that sounds like a great idea. personally i have not even tried to wire it up as of yet. i have removed the old harness and so fourth, but still trying to make sure i get everything wired up correctly before i install the new harness.
  4. ZXT_bean
    almost done!
    have you made up a msq. file for you to get running on? because if you have would you be willing to share it? im using the same firmware and so forth.. and it would really be a big help getting this car started...
  5. ok well ive got it all assembled.. now i need a msq. file for a stock l28.. ive found the one moby made.. but i need it for msII and 2.88 firm ware version can any one help me out?
  6. this is just an idea. but would a 81 crank pulley work in this situation? i mean it already has the tone ring on there. im not sure of the amount of teeth that are on there though. possibly just use the 81 crank pulley and swap the tone ring.
  7. that sounds like a good idea. what is his name here on the board? well i ordered everything today!!! megasquirt II w/pcb3, stimulator, harness, tuning cable, iat & clt sensors. so now i have get a base map setup, and everything configured correctly. im hoping i can use the 81 cas. any tips and tricks will help!!
  8. i have read that. and i am still in the grey area as you will... but as long as it has the possibility of working i will figgure it out
  9. ok so im am confused. am i able to use my 81 cas on the crank pulley and not use a 82-83 dizzy? i dont mind doing the swap. just kinda curious.
  10. well i finally got around to scrapping the parts car.. i needed it out of my drive way, i was sick of all the rust all over the ground haha
  11. thats a real inventive mounting bracket. i have often thought about using one of the m90 eaton s/c on a project. i actually have one in the garage with all the intercooler piping and such. might happen one day
  12. thats really neat.. id like to see the mounting bracket and how you fabbed it up..
  13. you could always make sure that each cylinder is at tdc, and fill each combustion chamber with compressed air, and do it that way.. the valves will never fall then. thats a really neat tool
  14. well id imagine it works in the same fashion. the 82-83 dizzy is a direct plug and play swap. im gonna go out to the garage soon, and check to make sure the injectors are pulsing. i know i have fuel pressure. and i never messed with the distributer, so the timing should be spot on. and ill check all my wiring again. im still unsure if i have the ignition harness wired up correctly, like i said i have the 81 harness, so the connector by the ecu is only a 6 pin plug verus the 82-83 harness which is a 8 pin plug. so ill have to go through that once again. ive tried to go though my wiring diagrams, but havent had much luck tracing wires. any one have a pin out of that plug?
  15. ok well ill go back to basics. i know the motor is good, i drove the parts car around the block with no brakes lol!! im using all the zxt parts, injectors, afm, ecu, i havent put in the turbo fuel pump yet, but im not sure if its going to be needed. last night i wired in my own fuel pump relay, now i get the 5second prime, and as soon as i touch the key to turn it over, the pump kicks on. still not sure on the amount of psi. i can hear the injectors pulsing.. or clicking rather. the green light comes on inside the ecu, does not seem to be there while cranking, as i stated earlier, this might be an issue. im not sure if my CAS is sending a signal to my ecu so the ecu can send a signal to the ignitor. i really believe my issue is spark related. is there a way to test the CAS. mine is a 81, so its down by the crank
  16. well i have a update for everyone. it still wont start. im starting to get really annoyed. here is what i know. 1. i have a good ignitor. 2. the green light is on inside the ecu (but isnt when cranking, might be an issue) 3. i have power to both my coil, and ignitor, and i belive my ecu is pulsing to the ignitor. so im at a loss here. i dont know what to do. or where to look. besides going megasquirt, i dont know what to do. but i do have some more pictures for everyone. and just for some giggles, my lil girl, Chloe. haha
  17. well i only plan on running 12psi tops on the stock setup, so id like to hope that the internal map sensor in the megasquirt ecu is capable of handling that.
  18. so then this would be a much cheaper route, anything else i am missing here?
  19. well i hate to confuse anyone, but i have no purchased anything yet lol. im still trying to wrap my head around this whole idea. im glad i didnt, because basically everyone is telling me that the relay is easier to make from scratch. and now that i think about it, my brother, is a wiring and soldering genius, so he will be assembling it for me.
  20. thanks alot everyone for the input!! now i just have to place my order.. should be doing that here in the short future.
  21. i just spent about an entire hour going through your library of photos of your car. and i must say, it is pure inspiration for me! thank you! its a amazing ride!
  22. i thought the harness they sell basically takes the place of the relay board? or did you just cut the connector plug off and just use the wire? and another question i have is. the injectors in my car are from an 81', so they have the dropping resistors already wired in. would i keep that part of the wiring, or wire the injectors directly to the relay board.
