The car peaked at 430whp at 18psi at a 7k rpm redline.
My boost controller was not working, no matter what we did it did not respond. Knowing I would have to come back, I left it at that. The plan was to leave and come back later, run 22-24 psi and set the redline at 7800 rpm.
On the second session I was sure I would clear 470-480 whp and be extremely happy.
After the dyno, I went home and rescheduled my second session for 4 weeks later, so I would have some time to work out a few minor kinks and find a decent boost controller.
Driving home, I kept it under 3,500 RPM light load, it would only be MY luck that something bad happens. On the drive home my motor INSTANTLY shut down, almost as if the CAS, Ignitor, or Timing Chain snapped. I mean instantly. The car will still crank, not even a SIGN of it trying to fire back up. I was extremely tired, I did check though my injectors and coils have 12 volts. Tomorrow I will I will start the diasnostic. First seeing if the CAS is ok by visually seeing the injectors spray and spark firing with a coil removed.
If the CAS is ok, that only leaves the Ignitor if there is no spark. Il do a compression test also, I think the motor threw a rocker arm, but I am just shocked. 30 + HARD pulls on the dyno, not a single problem. Driving home under 3,500 rpm and the problem arises. I am beyond frustrated and exhausted.
