timbo1jz
Everything posted by timbo1jz
  1. I can tell you for sure that if you have the later round style liquid filled 89+ motor mounts on your 7mgte then it will for sure bolt up as it is the same mounting as a 2jz. You can actually use the 2jz mounts on a 89+ 7mgte, but you have to grind away on the dowel pins on top and then they fit perfectly. The only difference is that the 2jz mounts at the bottom bolt are thicker that the 89+ 7mgte bolts. So the 2jz mount bolts use a 19mm nut as the 7mgte bolts uses a 17mm nut. The 2jz mounts are a lot more solid then the stupid liquid filled 89+ Supra mounts. but yes a 7mgte with the later style mounts will bolt up.
  2. Yah, John from Beta motorsports is currently building me a 2jz crossmember for my 1jz swap into my 74 260z. He really knows his stuff and it helps me because I already have 2jz factory mounts installed on my 1jz from when I ran this motor in my Supra so I won't have to use those Jaguar mounts and brackets because I don't like the way they mount.. The 1jz and 2jz mount identically the same besides that the 2jz is about less than a 1/2" taller. Should work great!!! I can't wait!!!
  3. very cool man, I am in the same boat as you. Get some good pics during your build up!
  4. Just giving you guys a sneaky peak of my 1jz that I will put in m 74' 260z in about 2 weeks. Its a 1jz single turbo 60-1, with crower cams, ect. Its about 500 whp. I will be pulling the motor out of my Supra hopefulley in a week and a half. I am very stoked. Anyways, here is a pic of the 1jz.
