pat1
    7
Everything posted by pat1
  1. Man you can't catch a break. Looks like lack of lubrication. Did this happen after you put it back together?
  2. That's normal oil pressure. At over 100 psi I'm surprised you haven't blown any oil filters up. I've seen one go @120 psi and that was a mess. It was a crappy fram filter.
  3. You had over 100psi of oil pressure at anything over idle? That's way too much no wonder the bottom end was shot. You sucked every bit of oil out of the pan. I would put money on that you were causing cavitation or foaming the oil. Not good. The oil pump can't flow foam.
  4. Who blueprinted the motor? Did rips build the motor ? This sucks.
  5. Sounds like they are trying to sell you a rb20 trans which will not last long behind a RB25. How much are they asking for the swap?
  6. Nissan MAF runs off a heated wire and it uses that wire to measure the amount of air that passes that wire. The ecu measures the air by how much power it take to keep that wire a certain temp. So when you run a blow threw set up that air intake changes because of the heat generated by compressing air by the turbo. That intake charge temp is a lot higher than it would be if it was stock even when it passes through the intercooler. On a nice and hot day with heat soak your looking at 200f + degrees higher than the intake charge before the turbo . So with that said it will have to be tuned for that blow through set up. And I wouldn't think the stock MAF would stand up to that temp for very long. K.I.S.S keep it simple stupid. Sometimes we try to redesign the wheel when the original wheel works perfect to start with.
  7. I cut a hole in the core support for another pipe to pass through. Then I had to put a 90 degree coupler in. I made a flange out of sheet metal and exhaust tubing for a flange to mount up to the MAF. I think I posed pics on hybridz years ago.
  8. Intake side the way it was designed. A suck through MAF setup. It worked like a charm. No tuning issues.
  9. Your going to have tuning issues with a blow though set up. The system wasn't designed for a blow though set up ( ask me how). I learned alot with my rb set up one thing is the K.I.S.S rule... Keep it simple stupid. Just place the MAF 1 foot or more away from the turbo and your done. Drive it and enjoy! When I had my rb20 I had the same problem. I had the MAF placed in front of the intercooler. Nice and cool air. I ran tubing from the MAF to the turbo. Easy as pie. Problem fixed and fixed fast.
  10. Don't do a blow threw setup. Your going to open a whole new can of worms. You want the air flow meter at least 12 inches away from the turbo so you don't have turbulence problems. The farther away the better.
  11. You get what you pay for. Buy it once and forget about it. The china stuff is crap.
  12. That's not detonation, something was in that cylinder and banged it up. That thing has been hammered!
  13. Pm me I can build you one. I have a few choices in price.
  14. I have a extra one. If you pay for the postage I'll ship it to you. Let me know
  15. Here you go. Double check and make sure this pinout is the same as your ecu.
  16. Yes it is. I had NIStune for a while and loved it . I'll find the diagram and ecu PIN numbers for you tonight.
  17. No the 280z was fuel injected to start with. The tank will have a feed and a return. The 280z tanks also have baffles.
  18. It's very easy, power,clock,RX and Tx wires. I have a a diagram somewhere. I'll try to find it.
  19. If I remember correctly AMS used to sell stuff for the 300zxtt when I had one and people complained about the product all the time. I have a cheap Chinese intercooler (cxracing) and its junk! I had to weld it up a couple times. I want to replace it with a better core but I haven't had a chance. I mean it does the job but it could be better alot better. You get what you pay for. I wouldn't trust it on a hot hot day high boost and a crappy tune= a bad day.
  20. PRC double pass radiator part number 2111100. I got mine for less than 300.00 shipped. 24x19 inlet on the right and outlet on the right. http://www.prcracing.com/aluminum-radiators.html
  21. You have nothing to worry about. Slap that thing in and enjoy. It should be balanced unless it's some chinese ebay crap.
  22. With the engine running look at the fuel trims and the o2 sensors what are they saying rich/lean. What ignition timing are you seeing with it starts messing up. Look at the engine cooling temp and intake temp. Are they showing the correct temp? I had a ecu crap out on me on my 20 before. Are te caps in the ecu ok? Are they leaking? What's your fuel pressure? Is the cam/crank timing ok? The NIStune is a pretty sweet setup you can monitor everything the ecu is doing.
  23. I would be happy to build you a rear sump pan. Just let me know when your ready. When I had my rb20 I used the stock rb20 motor mounts with the stock 280z motor mounts (I think). There should be a thread on this. I know I posted pictures of them. I used a stock 240sx throttle cable. Off of ebay for 5.00 shipped. I would use a Bosch 044 pump. I don't like thw walbro pumps. They are cheap but you get what you pay for. Your ecu should come with your swap. You can use the stock intake masifold. It fits perfect. You can use a ebay intercooler if you like but you get what you pay for. I'm using one and I don't like it. It's not very efficient. But again you get what you pay for. I had to weld my cxracing crap up 4 times so far. I posted a wiring thread for a rb20
  24. My guess would be either the CAS or the airflow meter.
