74
Everything posted by Tony D
Custom Intake- How much can the stock ECU handle?
Tony D replied to Challenger's topic in Fuel Delivery
JB Weld it, send in the testimonial! -
The S130's with both L28E and L20E in the JDM had progressive throttle linkages/TB's with the standard mounting for the TPS. The L20's primary opening was about the size of an American Dime, while the L28's was aroudn the size of an American Nickel. The engine usually would run at cruise and up to about 3500rpms on the primary bore. So running around normally you used a lot of the throttle play---almost 3/4 of total pedal travel. Your engine vacuum signal was quite high as a result-you got better fuel economy. But cruising along the road at 3000, you touch the throttle and the tip-in of the larger bore caused a great surge of power (er...whatever you want to call it for a stocker...) compared with a similar actuation of the smaller T/B opening. It really makes driving the car nice and smooth away from a corner. I only wish I could find a way to open up the stock bodies to a larger secondary/smaller primary for cammed operation. It would give a better MAP signal in the plenum opposed to a larger 60 or 65mm T/B at all cruise and low speed operation parts of the fuel map, while the larger secondary is there for mechanical operation when you press it the rest of the way to the floor. I'm thinking JeffP would appreciate such a feature on his car nowadays...heh heh heh
Remember I said the Japanese were splitting overbored N42's under high boost conditions. The hype surrounding megabored engines is revealed for what it really is when you start pumping serious horsepower. Remember Electromotive was making 700+ with no more than a standard SCCA-Style overbore to clean up the cylinders round, and a standard stroke crank... The Japanese had a saying 20+ years ago: 3.2 for Normal, but Tabo-San-Gata lives forever... Boost, not bore. If you want valve unshrouding, notch the block accordingly. The thicker walls will pay dividends under increased cylinder pressure.
1) the head on the Bonneville engine is not limited to 9500 rpm it's simply where we shifted gears while working out actual real-world acceleration runs. It is a work in progress, there are several people who know how high that engine has actually revved on the dyno while doing 'float checks'---we haven't floated yet, BTW... 2) the head on the Bonneville engine is the same one we ran on the 2.8 motor, it's nothing special in preparation, and truthfully has far less exotic materials than many other 'street' engines I have seen overbuilt for the street.
Don't put a catalyst on it, it will be the wrong way to go about it---the carburettors are not set up for that, and you will make more headaches than you will solve. A standard 1971 SU setup with AIR injection will test clean out the tailpipe (the Arizona Standard) to 1983 CALIFORNIA standards. So there is no reason under the sun, with a properly running set of SU's on an engine in decent tune that simple carburettor adjustment/tweaking and standard maintenance procedures wouldn't get you a passing grade. No borken spark plug wires, no misfires, and not too lean or your HC will go through the roof! But run them at 'lean best' and fully warmed up with fresh oil change (no offgassing of HC from the oil as it gets hot...) and you should pass no problem. If you don't, it's a matter of putting AIR back into the exhaust system through a Toyota Gulp-Valve system instead of a pump and belt system (good luck finding one!) like the 74 had originally. NOx, if they even test for it, would be a spark timing and EGR situation, but pass that bridge when you have to, find out what the test criteria will be for your vehicle from the State Testing Governing Board---its' not a secret standard. Simply take your car to a place with a CO and HC meter and adjust your carbs accordingly. It's no real big deal at all. It's a tailpipe functional test. It's easily passed by a car in good tune. Even relatively modified ones!
The LD28 has a larger impeller. This is documented in another thread. The folded metal pumps are junk, and are an aftermarket unit, the stock Nissan pumps are all cast impellers. I have often thought of having an impeller cut on a five axis using some developmental software we have at work...it's just getting time in the milling machine without anybody looking... Personally, I paint all the cast impellers with Glyptal before installation. When one finally craps out, I'll dissect it to see if it helps prevent corrosion and/or cavitation damage to the impeller.
PM answered.
147hp to the rear wheels using all stock components including ECU and AFM. 1975 280Z...
Information Disseminator! Your sheep will be fruitful this season with you disseminating like that all over! I had someone argue once about N42/P82 runner size. That Excel summed up my general comments to the guy. He was not convinced. He was also 1 second slower in the 1/4 mile and swore I had a cam in my rat-trap POS Fairlady. Small details, stacked up, make for a fun car. Like BRAAP posted, there is more to it than just an intake manifold. Spark plug wires are one of my faves as well. People think they last forever. They don't. I babble late on in the evening. Forvgive me.
details details details... "But they look the same spacing, what's 2mm?" LOL
many industrial hardware stores sell heavy-duty flexible shafts---sometimes they have a small jacobs chuck on the end, other times they have a nice, standard 1/4" collet on the end. With a simple 1/4 X 5/8" locking shaft adapter you can connect that flexible shaft to an old washing machine motor and hog the HELL out of ports with a bit like MONZTER showed. The speed is only 3500 rpms, but the amount of pressure and feed rate you can use is amazing. I made one of these setups in 1985, and to this day still use it (though lament my original Japanese Flex Shaft has about had it now...) MUCH easier to control than a bulky drill, probably not as nice as a dremel, but then again you can't spin a 1 3/8" diameter 80 Grit Flapper Wheel and just force it down the runner bores to clean them up with a dremel now...can you? I love my Washing-Machine Motor Monstrosity. Everybody that sees it seems to like it. The Japanese used them in the shops---recycle something like the old 3/4 horse washer motor and a cheap flexible shaft...much cheaper than a bulky electric die grinder (though I confess last time Harbor Freight had those electric die grinders on sale for $19.99 I bought TWO!---man they work fast!) But for a beginner, that nice slow motor and shaft speed allows you a lot of room for a mistake---and you don't easily gouge a 1/4" deep groove across the face of the workpiece if it catches and runs away on you! Just a thought. I'm thinking everything but the motor is probably available through McMaster-Carr for shipping right to your door (including the burrs!) -
Just to state it again, the Euro Turbo has slightly over 1 5/8" I.D. in the log runners, though the head portion is slightly constricted same as any other stock Nissan Cast Manifold in that area...nothing some burr work couldn't clean out as an example. I'm suspecting that the stock Euro Turbo will support one honker of an engine with those dimensions. Slightly O.T., but it's always good to look at what's already been designed rather than proceeding from blank sheets on every aspect. On the 'one piece' or 'multi-piece' flange issue---I'd suggest the manufacture as a single piece, then after fabrication relief/growth cuts may be done by the owner of the piece to allow for the expansion/contraction that occurs. This is what was done on JeffP's SFP conglomeration... As stated, it should minimize misalignment possibilities.
Weber DGV's are no harder than dual quad holley's with vacum secondaries to set up. You simply convert the secondaries to mechanical operation...but like blowing through a four barrel: Why? EFI is the way to go boys. Cheaper and Cheaper every day!
If he gets much faster in that thing, he won't be able to do the three-lane change into the offramp in time to get back near his 'lead car'....
Nope... Like I said, Maru is Zero...but like there are three ways to say the number '3'...the same sounding word can have several meanings depending on the ideographs used to depict it. "Katayama" as calligraphed by "Mr. K" would have a different pattern than if a 4th grader spelled it out phonetically using Katakana. Katakana and Hiragana are the two main forms of writing, one it old Chinese-Based Ideographs, Katakana is a phonetic way of writing so the Japanese can incorporate words that don't have a traditional old-school Hiragana. Like the Convienience Store "7-11" If you look at it, you would think it was Sichi-GoIchi...literally '7-11' in Japanese. But NOOOOOOOO! It's spelled in Katakana only, and is pronounced in Japanese using the Katakana Phonetic Spelling 'Seben-Erebbin' Figure that crap out. So "Maru" as written in English could mean several things---like you said, "Nissan-Maru" was the ship (as are most Japanese Ships) but the "Maru" that signifies "0" is totally a different ideograph than the one for "Maru" the ship suffix! Clear as mud now? Oh, and this even confuses Japanese---you have to actually READ what is being said sometimes, because the context in which the word is spoken has to define what it means. San-Maru in context is 'Three Zero' and is probably someone saying it that way for a reason. Normally 30 would be SanJu---literally meaning Three-Ten. But a Z432 is not a 'Zetto YonbyakuSanJuNi' (Z Four-Hundred Thirty-Two) but rather 'Zetto Yon-San-Ni' Literally 'Z Four Three Two' There's a reason when you start to learn Japanese that one of the first phrases you pick up is 'Kami Ni Kaiete, oh kudasai' "Please Write it Down". There is a "World Traveller" advert out there for Cingular or AT&T right now where a guy says 'So Mr. World Traveller is about to call his best customer 'Mr. Stinky Fish-Face' through a simple intonation gaffe. This is not too far from the truth. Chinese is even worse. "Ma ma ma ma ma ma" is literally a sentence with a different intonation on each way of saying "Ma" that makes it mean a different thing, each with it's own Ideograph! I haven't tried past 'NeHow Ma' Five different intonations intimidates me! Even clearer, eh?
On my car, I used a 17 mm piece of tubing at a slight angle in the turbo's inlet piping, about 10cm from the turbine wheel. This 17mm tube is smaller than the BOV dump at around 25mm. I use a 25mm tube from the BOV to a tapered fitting that necks it down to 17mm. This gives a more directed velocity shot, and the hasn't seemed to affect how quickly the plenum blows down. By blowing some compressed air at the compressor wheel you can best figure out what 'angle' seems the best for getting the wheel spinning. Keeping it 10cm away (er, 5" maybe) keeps that larger tube from screwing up the flow too much from sticking in to the intake ducting. Same thing for your PCV, btw, similar setup like the OEM lines---if you play it right, you can use the stock upper PCV hose to hook to your fabricated intake tubing. Argh...it's off the car and in the shed right now...I don't know exactly where...this is an example of where one photo would make what I'm trying to say much clearer!
New idea for a turbocharged intake design?
Tony D replied to PanzerAce's topic in Turbo / Supercharger
If you ever take a look at some late model Toyota Four-Cylinder intake manifolds, you will see exactly what you speak of: What looks like an Aluminum Header on the intakeb ports, with a Throttle Body in the formed 'merge collector' section of the assembly! Long runners, torquey torquey torquey...and all that volume is used, same as something with a bigger plenum. Like Monzter says: There's very little that hasn't been thought up already, it's just a matter of finding it and then reapplying it in another realm. I applied "Lizard Skin" insulating compound (for floorboards in hotrods, originally) to Centrifugal Compressor Torus Sections to keep personnel from rubbing against them and burning themselves...sales guy never thought of 'that' application before. Hell, it sure beats wrapping rockwool in chickenwire around them...ugh! Messy messy messy! Paint it on with a roller, and no muss no fuss. Almost anything is applicable to more than one application, it just takes an open mind. -
To answer the question about the SMOG check--which I think it the pivotal point: Turn your boost down, and stick your J-Pipe back on it. Paint your intercooler black so it doesn't draw attention. As long as the system remains 'as manufactured' it will pass the visual. It will be one day out of every 730 that you will have to run that way. Shouldn't take you 1/2 hour to accomplish, and then stick it back on. If it's connected, and it doesn't have a CARB EO # on it, they can fail you on the visual (and paranoid techs these days will not hesitate to do so and most 'check only' stations, and you will have to go to a referee... Do you want that hassle? For the hassle once every two years, just swap the J-Pipe back on and pass the SMOG Test. Now, as to 'either or' it all depends on how hard you boost and how long. It's not like you have a Saab with a 2.5 gallon windshield washer tank hidden inside the left fenderwell... your methanol supply will be limited, and the more you boost the more you use. So if you boost early, and boost often it can be as much of a drag as refilling a NO2 bottle... A proper intercooler can be integrated and cool you fine to stratospheric levels, and methanol will add some power at the upper ranges. I ran 21 psi with no intercooler, and the old Reliable Spearco Water Injection unit running ethanol/methanol/isopropyl/water for years on both my early Turbo Z and that was after I took the unit off the Corvair which had it on there forever (er...like installed some time in the 70's or early 80's!) I don't know about people saying liquid injection will 'limit' your boost levels, Multistage turbosystems on pulling tractors run water injection through four stages of external compression to boost levels of over 150psi in the manifold. It's all a matter of each stage compressing and adding heat. And when you add heat at pressure the amount of water the air can hold in suspension goes up each time. If you start out with a low relative humidity your first stage can inject a LOT of water for heat removal. I think the 'limit your boost on liquid only' is a spurious contention. Clear as mud now? LOL
I had that suspicion! Thanks for the heads up! How is the Fairlady Z?
Lumiweld and a propane torch... Or heliarc, yeah they can be welded. The bumps at the inlet of the runners are a frustration! I think this is where the EGR is introduced on some manifolds, but on my P82, I didn't have EGR, but STILL had the same bumps (just without holes in them!) Probably says a lot about 'common runner cores for casting all manifolds' than anything else! -
Just to be pedantic, you need the EFI Bible and a multimeter. The EFI bible gives AFM checks which should have revealed your AFM problem right on the spot. Following the EFI Bible circuit checks, you can check all circuits in the system within 45 minutes, and in a similar time do all the component checks that would follow on from getting a 'bad' circuit check. I'm glad you got it running, but how was the EFI Bible 'not helping' in this diagnosis, as what you replaced IS covered in there quite explicitly... I'm curious.
That would result in a direct shunt of the hottest water directly to the pump inleet exacerbating the cavitation issue. Ideally, like Electromotive did, you would vent all cylinders above the head to the radiator, this lets the water flow directly bottom to top in each individual cylinder, and evacuates steam and air bubbles from each cylinder equally. If you look at the "How To Modify" book you will see their tapping of the cylinder head, they did all cylinders directly to the radiator. You only need the two smaller bypass lines for pump circulation when the thermostat is closed. Once it cracks open the pump will flow what it can---if the vents went back to the inlet, it's the same as looping the heater core hose---too much when it's not needed. The stock external bypass lines on the 73 and 74 cars WERE CLOSED by thermostatic valves once the water in them reached 170 degrees F. After the engine is warmed, and the thermostat open, the need for bypass lines back to the inlet of the pump ceases to exist---you have an open flow loop through the radiator and no need for low-flow bypasses. If you could close them both off it would be ideal as then all water was cold into the pump, and all hot water exited to radiator with absolutely no recirculation at all of hot water to the pump inlet. The routing of the turbo to the inlet of the pump is for expedience. Doing it to the radiator would entail all sorts of tubing off-engine and to the radiator, and would not work as a bypass when cold...so it's a choice of expedience more than anything else. Ideally, you would tap pressure from the output of the pump, through the turbo and into the upper t-stat housing...that way after shutdown you would have cold water from the bottom of the radiator given a direct pass through the turbo as it warmed, and up to the high point of the engine---a thermal siphon after shutdown. But expedient that setup is....not!
D'OH, I just got the PM from Nigel. I'm sorry guys, I thought I had already posted my 'quick measurements'!!! This is a cut n paste of the PM I just sent him back: I didn't post those already? Let me see, the notepad is right here... On the 'B' the countershaft has four gears, the largest being forward on the transmission, towards the bellhousing. The gear widths on the countershaft are 18.0mm on each of the four gears. The gear they mesh with on the main cluster gear assembly are all 18.3mm wide. On the 'C' countershaft, the first gear forward (the largest one) is a total of 20.0mm (19.9mm?)wide, including the 'hardened spacer' I spoke of. The spacer itself is 1.7mm thick...Meaning the gear itself is 18.3mm thick. 0.3mm wider than the 'B' box! The gear it mates with on the cluster gear is 20.3 mm wide which is no doubt wider and stronger. The next gears in succession appear to all be 18.3mm wide with mating gears similarly sized. So the big increase in strength appears in the first gear assembly, and then at least 0.3mm wider gear using all the available cluster gear for power transmission in the 'C' as opposed to the 'B'. The gear cluster seems much tighter stacked due to the wider gears compared "B" to "C". I thought I posted this some time ago. This notebook has been sitting by my chair for some time...all sorts of crap written next to and around it. If you want to post this to the original thread, feel free to... Some of the measurements were taken pretty quickly with a vernier caliper, but the changes in width were obviously more than simply a measurement error---when they sit side by side, you can see the "C" box has a tighter cluster stack, and simply looks 'beefier'...
I would also call B.S. on this without a V.C. Section Referenced. This paint is no different than any old 50's British Car with aluminum coachwork that is brightly polished. FMVSS compliance is one thing, local Vehicle Code Compliance is another. But I don't see 'technically illegal' and unless someone here has been cited or can show me the Vehicle Code Section relating to 'distracting paint jobs' I'm standing pat on my thoughts on this.
You paint that over black paint which has already been buffed and polished! Just skip the superfine metallic chrome overlay and you have a killer gloss black paint job. Application of that stuff is not as one would normally expect!
