280zx 2by2
Everything posted by 280zx 2by2
  1. i say screw the car, its automatic who needs LHD anyway no, just kidding, if you ask me(i have a leak problem)out of sight out of mind
  2. thanks, ill check it out, do they have a website? nice z, if i had the money the style of your z is what i would go for but the style im having to do is the basic lower front bumper and mabe a set of 82 front/rear bumpers but luckily i have a nice set of 14in enkei rims... thanks for the info, if it wasnt for the $4.00 gas id go up there this weekend
  3. was the backfire and actual pop back fire or just like a , well its a hard to describe sound...kind of like if the extra fuel in the exhaust didnt ignite all at once but burned slowly my car sounds like the second one but that still dosent explain your RPM loss mabe your cat burned up? check and see if exhaust pressure is different... good luck.
  4. but this guy is going from turbo to NA injectors try spraying some carb cleaner in the filter and give her a crank and did you give any mind to this? "check the fuel lines that go to the fuel rail and try switching them start the car and see" my car sputtered one time and after wouldnt start when i changed my injectors and it turned out this was my problem
  5. i have heard the T5 is the same as the one in the 80's mustangs, is that right or am i all wrong?
  6. wont oil smell like that if i gets water in it? i have a few oil drip pans outside and they have that sour water/metal/oil smell
  7. waste of money, the car should at leeast fire and turn over for a while with the NA injectors, the fuel rate is only a little lower for na injectors chill out turbo injector juys, T injectors and regulators are still good but MPG is good too i got a ?, are NA and Turbo regulators the same?
  8. no it looks clean i payed 2100 for an 81 GL 2+2 t-top with a real good interior and several rust spots
  9. try taking off the filter and play with the throttle and see what happens only thing else i can think of is a ring failing but you have the same compression so DO YOU HAVE ANY OIL IN THE CAR? that was to sound dramatic
  10. i cant wait to find a 240z to restore and to swap my L28 into
  11. i want a pair of 82-82 tails or a piar of those cool cool shaded ones above
  12. i found a 82 280zx for sale in waycross GA and decided not to get it(cost too much and was very rusty)i liked the way the 82-83 bumpers looked on it though and wondered how much trouble it would be to swap my 81 bumpers with 82 bumpers is there somewhere that sells new or reman bumpres besides a junkyard? also could i just paint my bumpers? they are the same basic shape... my 81
  13. check the fuel lines that go to the rail and try switching them start the car and see, if that dosent work if you live near valdosta GA let me buy your car(jbarfield@windstream.net) if it works give me 200$, just kidding
  14. if you do i would like to know if you have found any z cars in any junk yards also there is a very nice but rusty 82 280zx for sale in waycross GA at a place called buddys auto mart...$2400 to me it was a little much
  15. hi im 16, the youngin of the bunch, im poor and cant aford to restore a 240z or 280z so im restoring a 81 280zx 2+2, i got all my info from these forums and common sence (some times that dosent work) also at my school have a good automotive class that i take, it helps a little
  16. thanks woldson, ill read over this and see if any infocan transfer to my 81, some should...
  17. im pretty sure bout no vacuum leaks but not electrical, whats making me angry is that it could be any one of the sensors or a combination and i cant wiggle all of them at a time i just need a list of all nessisary sensors or any electrical wires or vacums that are needed for the car to start
  18. thanks even if thats not the problem that could really help me if i get the car running agian!!!
  19. looks simular to mine, just a little shorter... http://www.cardomain.com/ride/3013231
  20. stock replacements, dont get me wrong, this car worked fine before except for injector leaks Gollum, your swap was a much larger increase in size (stock to turbo injectors)mine was really sorry stock to correctly working stock, could this need for a tune aply to me? also, how do i do the tune?
  21. fuel cut in afm. sorry for my ignorance but what is this?
  22. are ther any more of those kind of nessisary sensors or switches? i have every thing needed for combustion i just dont have combustion, its something to do with the computer and or sensors
  23. ok i put on the new harnesses today and it still wont start, i have spark i have fuel pressure i have air im sure i have compression i read last night where the temp sensor or some sensor(may have been the 02 sensor) would keep the car from cranking any input or questions would be great
