inline6
    6
Everything posted by inline6
  1. So, I'm spending a bunch on building a 3 liter bottom end. I bought a standard L28 crankshaft and had it sent off to Castillo's Crankshaft Service in CA to be worked on. Here is a pretty cool article in Turbo magazine about them and the work they do: http://www.turbomagazine.com/tech/0610turp_castillo_crankshaft_service/index.html I am having the crank offset ground, lightened, and balanced. I thought the note I got from them earlier this week was really interesting... The stroke on the stock crankshaft is not quite "stock". Read on: I read your info sheet to what you need on your nissan crank. Stock stroke is 79mm = 3.110, increase to 81mm = 3.188. I checked your crank with my stroke gage (Starret 0-5 inch travel). What it actually measures is: •#1 Rod 3.103 •#2 Rod 3.103 •#3 Rod 3.104 •#4 Rod 3.104 •#5 Rod 3.102 •#6 Rod 3.101 So, your lowest stroke is .009 short from 3.110=79mm. Your stock rod journal size is 1.967 std. Finish size for 3sgte rod is 1.8892/1.8898 from the Clevite book. So, actual difference is .078. That is exactly what I need to make the 81 mm stroke, but we are short on stroke from factory... Remember, the #6 rod is 3.101. So, if I add .063 to that, rough stroke is going to be 3.164: the .063 is the difference from stock journal size 1.967 to 1.904 which is .015" from finish size 1.889. I rough finish rod journals .015" oversize from finish spec, then I straighten the crank prior to final finish size because the crankshaft will bend upon stress relief. I might be able to get another .010" on stroke when finishing the journals... so it should be 3.174 stroke when finished. This will still be short .014" from 81mm = 3.188. So, I have read several posts here on hybridz.org indicating different amount that pistons stick up above deck (L28). Range has been .012" to .022" I think. Seems like if my crankshaft was off by .006" to .009" then we have found part of the problem. Variability of manufacturing tolerances is something I have known about - that it exists... but this hit home in a different way. I think center to center on the rods is likely to be more accurate to factory spec. than crankshaft grinding. Not sure what I base that on, just seems to mee like crank grinding wouldn't be as precise. Anyway, I thought I would pass this info along. Good thing I haven't ordered the pistons yet because the pin height (compression height) just changed.
  2. inline6
    From the album: Click for photos
  3. What is the bore of the head gasket? Same as cylinder bore??? For example, on the motor I am working on now, the bore will be 89 mm, but the gasket will be what... 90.5 mm or 91 mm? Won't make much difference in CR (on my engine calculator, substituting the engine bore for the gasket bore raises my CR by .03), but as long as you are taking the time to do the math...
  4. Cometic quoted me a .043" copper head gasket for $162.16...
  5. Good info. So folks! It looks to me like it is going to come down to whether there is interest
  6. HKS went away... Kameari just jumped in price. I'm thinking they will go away at some point also... Did I call them? $3800 on the engineering upfront is the word I got... I hoped to see a lot of interest to this post - 50-100 people? Other similar applications from Cometic such as the RB25 head gasket are only $177. I don't see why each gasket would be priced at over $300 My quick break even math looks like this: Kameari = $310 Target Cometic L6 head gasket price = $200 Engineering investment (a one time deal) = ~ $4000 So, you take the $310 minus the $200, which gives you $110. This is the investment, if you will, per person, which is only needed to figure out how many people we need to offset the engineering costs. Divide $4000 by $110 gives you 36.36. So, if the gasket price itself could be $200, we'd need 36.36 people to pay $310 to offset the engineering cost and they would get one gasket. So, what happens when you get 50 people? With 50, the engineering investment cost per person drops to $80. Gasket is still $200. So now we're getting in the ballpark of $280 for a Cometic MLS. Ok, how about 70 people (or gaskets actually as some will want more than one). $257.14 per gasket. So, they make them for RB motors, of which there are how many here in the US? 10? 100? 1000? And how many L6's are there in the hands of performance oriented folks like us? I am hoping everyone will still indicate your interest. The Kameari at an offer price below the buy it now might be a good short term option for some, but I'd like a Cometic MLS and I'd like to know who else is interested in them as well. I was planning to pursue the matter only if I got a good response from you folks. Something tells me they would be willing to sell the gaskets for $200 - $250 if they had an order for over 70 of them that also covered their engineering costs.
  7. What I'd like to know is, who would be interested in a MLS head gasket from Cometic? MLS (Multi Layer Steel) gaskets seem to be the ones most desired for high performance L series engines from what I can gather. Right now, availability is pretty bad -- HKS ones appear to be no longer available. Kameari are available for now, but recently jumped to $310 for the 1mm, and $365 for the 2mm. There is also one available from Nismo in a .6mm for $150. Tomei appear to be available on some websites anyway, but who knows if they are in stock? Looks like maybe $290 each? If you would be interested, then please indicate the following: What thickness? What bore size is your motor? At what price you feel it would be worth switching from those that may be available: $150 or $200 or $250 or $300 or a dollar under the cost of the Kameari Theoretically, if there is a lot of demand for these things, there is a possibility we could get them made. I don't think this qualifies as a "group buy" post because the cost of the gaskets is unknown at this point. The only thing I do know is that there is some up front engineering cost before the first one could be made. So... let's find out the level of interest and if this is worth taking to the next level. Maybe this could evolve to a group buy.
  8. Hi Pete, I think your gasket volume is off a bit. The head gasket has a bigger bore than the piston diameter, yes?
  9. Can you send me any close up pics? The reason I am sending it to the crank grinder is I am building a custom stroker motor via offset grinding... Are the keyways and where the dampner sits on the crank in excellent condition? Flywheel bolt threads are excellent? Any of the mains journals need polishing and are they standard size? Garrett
  10. I need a nice L28 crankshaft - no messed up keyways, std main bearing size (rod bearings less critical), and no excessive rear main seal wear. Looking to locate one on the west coast as I want to send it to a crank grinder on the west coast which saves time and shipping cost from here in VA. $45 for a nice one? Garrett
  11. Are the Kameari or Tomei head gaskets reusable? Price on these things is rediculous. I don't think I want to mess with copper... Any other (cheaper) options available in a 1 mm thickness? What about other options-- like installing some king of O-ring and trimming the Felpro standard gasket to work with those? Garrett
  12. I am still hoping to get some real world experience regarding piston to valve clearance... I saw a post where 1FastZ indicated he had .050" on the intake valves, but he also mentioned he was running titanium retainers... I am looking to order custom pistons... It would be great to have this info before I do that. Garrett
  13. I'm filling out the custom piston form for CP/Carrillo pistons and I'm not sure what info they are looking for in a couple of the boxes on the form. I'd like to complete the form and get it to them for rough estimate on pricing - I will have my machinist/engine builder look through all the info to confirm everything is correct before they start machining... But, I'd like to know what these are now: "Flat/Angle Mill How Much?" These will be flat top pistons with valve reliefs. I am guessing that "Flat" is what I put here. However, they will not be flat with the deck surface. With a 1mm thick head gasket, I want the pistons to be .015" above the deck... this gives .024" piston to head clearance, which from reading the forums here is pretty much the minimum that will work. By the way, I don't see where to put info regarding location of the valve reliefs nor depth of them... "Deck Clear" Elsewhere on the form, they ask for "Comp Dist" which I believe is compression height. Could "Deck Clear" be the amount the piston goes above deck (the .015" mentioned above)? "Lift/Lift at Overlap" followed by "Int" and "Exh" in close proximity on the form. I have various cam specs that came printed out on a sheet of paper with the cam I bought, but no "cam card"... Next is "Lobe Separation" which is 104º from the info I have on the cam. And next to that field is "Installed @". What is that? Then comes "Free Drop"... again followed in close proximity with "Int" and "Exh" I have no idea what that is. The rest I think I have figured out.
  14. I found this thread in the other engines forum to be quite helpful: http://forums.hybridz.org/index.php/topic/96128-borestroke-and-strokerod-ratios/
  15. So, I got my cylinder head back from the machine shop recently... New cam (kind of big). I put it on my F54 short block (which is stock) and I don't have enough piston to valve clearance. So, I had already planned to build a shortblock with forged pistons to work with the cam (rev limit of 7700 RPM). Lack of PTV and winter coming on makes the timing right to pull the bottom end apart and get forged pistons with the valve reliefs I need. So, I've been reading about strokers in the archives... Given that my cam is good for 7700 and the car is almost entirely for track use, what combination makes the most sense for the bottom end? A 3.1 stroker, or something else? I note with some interest, the following: The stock L24 bore and stroke is 83 x 73.7. Dividing bore by stroke, I get 1.126. The stock L28 motor, by contrast has an 86 bore and 79 stroke. Dividing bore by stroke, I get 1.089. It is mentioned in the archives, and of course it is fairly universaly understood that smaller displacement engines with smaller strokes tend to rev higher and typically make less torque over their given speed of operation. Now back to the stroker. Most commonly, the bore and stroke is 89 and 83. Dividing bore by stroke, I get 1.072, which is close to the L28 number. Again, interestingly, taking the same 89mm bore and dividing it by the standard l28 stroke of 79, I get 1.127 -- basically the same as the L24. So... would the characteristics of an 89mm L28 with the stock 79mm stroke be more similar to the L24, (i.e. be a more rev happy motor than the 3.1 LD28)? To be honest, my main concern with going the standard 3.1 LD28 route with this motor is that the cam won't work well with it. I've seen some comments in the archives about it being pointless to rev the LD28 beyond 6500. Is that the case? And if so, what about the 89/79 combo I mention? Would that be a better route if I want to turn some more RPM's (7700 to be exact)? Garrett
  16. All good there. I got the head back from the machine shop recently. Valve springs are designed and intended for use with the cam. I'm using shorter valve stem seals than stock (Ford Capri V6 as mentioned in threads here on hybridz).
  17. Thanks for the reply. By timing set, do you mean a degree wheel? I did not have anything like that on it yet. I just mocked everything up and rotated he engine around two full crank revolutions. I do have a degree wheel that I can use... But, I've been reading old posts and came across a comment from Tony that not having the cam dialed in when doing the clay test is ok as generally to get it dialed in usually involves less than 4 degrees one direction or the other, and that amount doesn't make much of a difference in PTV clearence. Thread where he mentions this is here: http://forums.hybridz.org/index.php/topic/84616-headpiston-clarification/page__p__802326__hl__%2Bpiston+%2Bvalve+%2Bdeck+%2B__fromsearch__1#entry802326 If I had something close to the right minimum PTV (whatever that is), I would go through the extra effort to go ahead and time the cam and remeasure. Of course, if I am now looking at putting valve reliefs in pistons, I'll need to do this as a next step anyway. Regarding the piston above deck being .030" - reading through several threads here at least, it looks like there are differing amounts for stock L-28 flat tops... However, Braap indicated in this post that he had never seen less than .019": http://forums.hybridz.org/index.php/topic/58127-best-way-to-achieve-piston-to-head-clearance/page__hl__%2Bdeck+%2Bbraap+%2Bpiston And then in this post, he gives a much larger range (.012-.022") but I haven't found reference to anything above .025" - until now that is :)http://forums.hybridz.org/index.php/topic/75849-warning-mn47-clearance/page__p__722093__hl__%2Bpiston+%2Bvalve+%2Bdeck+%2B__fromsearch__1#entry722093 Mine is measuring out to .017 - .018" above the block deck with my dial caliper and magnetic stand (again all carbon removed - with carbon it was .022")
  18. I did some searching in the L6 forum and came across a post that said these were the minimum piston to valve clearances to run: .080" intake, .100" exhaust minimum Has anyone run anything less than this successfully? Here is some info on my combo: Stock bottom end - F54 L28 with flat top pistons. I measure .017" to .018" piston height above deck (all carbon removed from top of piston). The head (E-88) has been milled a few times over its life, just to straighten. I'm guessing .010 - .015" has been removed from stock. Anyone know the stock thickness? Manley stainless valves - stock exhaust diameter and stock l28 intake diameter. Cam: Intake Seat duration 320 degrees .050" duration 290 degrees Valve lift with zero lash .565" Hot valve lash .015" Net valve lift .550" Exhaust Seat duration 315 degrees .050" duration 274.8 degrees Valve lift with zero lash = .565" Hot lash = .015" Net valve lift =.550" I put clay on the number one piston. I put on the Nissan stock head gasket (a used one that measured .050" thickness). I put the head on with a couple of head bolts just to snug it down. I put the number one and two rockers in with zero lash... Looks like I have about .030" clearance on the intake valve and maybe .025" on the exhaust. By the way, while I was searching through old threads, I came across info that said I should run .022-.025" deck height. That is interesting, because with the stock head gasket from Nissan, I calculate that you end up with .050" minus .018" (piston pop up) which gives .032". A 1mm head gasket would put that around .022"... Garrett
  19. Please let me know if you have one and how much you want for it. Thanks.
  20. In case someone needs this info - My 12/70 240z has 5/16" OD (might be 8mm) supply, and 3/16" OD return, and 1/4" OD vent hard line (the one on the driver's side).
