7
Everything posted by inline6
Yeah, spensive. A little less than my first car cost me. Which is really insane... Took my N42 block to be cleaned and sonic tested last week. Should get it back this week. Still looking for some Glyptal if anyone has some sitting on a shelf. Otherwise, I guess I'll have to buy some new and then what is leftover will sit on my shelf... probably until I'm dead.
The crankshaft has arrived from Castillo's! Stroke came in a little less than I had hoped (3.165 instead of 3.188), but it was dictated by the factory stroke being a little under spec as well as tolerances when stress relieving the crank which happens during rod journal resizing. As was mentioned before, it probably isn't worth the bucks spent for the small amount of stroke increase I have ended up with. However, those of you buying Rebello 3.0 liter stroker motors are pretty much doing the same thing. Here are some large pics:
I took these off of my L28 with E88 head very recently... They are quite nice. They are the 4 screw (early) version that is desired. I had them rebuilt in 1994 with new Nissan OE: thottle shafts, thottle plates, throttle shaft bushings, jet nozzles, screws for domes, screws for float covers, and the hoses that go from the float chamber to the nozzles. I replaced the stock N27 needles with the "SM" needles which are the hot ticket for the L28 engine. I put some attention to polishing the domes some time ago. That is why they look pretty good. They could use a maintenance polish to make them really shine again. While replacing one of the shaft bushings during the rebuild, the aluminum around it broke. This was expertly tig welded (and run on the car since 1994 with no issues). Also, one of the air filter tabs was tig welded and redrilled at the same time. They do have some miles on them - probably 70k since the rebuild, but they work great. I have the heat shield also... If you think you are interested, I will post a few more pics. I was getting ready to sell them on eBay... I'm not sure on pricing because I haven't looked to see what they are worth yet. I know that Ztherapy ones are like $600, and these obviously aren't anything near that nice. My rough guess is $250, but let me look around and see...
Did you get some of these? I have a nice set of L-28 stockers from an N42 motor. Let me know.
Hmmm. Hadn't thought to use the carbide cutter... Thanks for that. A great example of when two heads are better than one. As for the rods, I am using Eagle brand for a Toyota Celica. My engine builder says they are ok, but not as 100% ready to go as others. That is probably why they tend to be more affordable. I forget the weight, but something like 560g vs. 710g stock - I think? I will be taking the block to my engine builder after I finish removing the casting flash. I don't anticipate any issues with the block... I better not have any that is, because it would be wasted time and effort to remove the flash only to find out that I should find another block. He'll spec out the block, proceed with mocking up crank and rods to see what we need spec-wise for the pistons.
Crankshaft should be arriving any day now. Can't wait... In the mean time, I've learned from reading the forums that combustion chambers should be polished - not glass beaded! So, I did that. You can see the undercut on the side of the chamber here. I was copying a 510 head I had done by Malvern racing long ago. I also learned from the forums that the N42 block is the one to use for 89 mm bore. Wow. I was going to use my F54 block. Luckily, I still have my N42 block from an earlier motor. How about this casting flash??? I spend a couple of hours with an air powered hand held belt sander... belts are 3/8" wide by 13" long, one of my latest tool aquisitions. Going through belts rather faster than I had hoped. I am using Norton 60 grit. Looks like it is going to take about 5 to do most of the inside of the block. Anyone have some left over Glyptal on the shelf? I don't think it takes a full quart to do one block, but that is the only quantity I can find for sale.
Are those carbs modified (tapered bores)... or standard bore? The openings look bigger than original. Also, why did you make an impression of the pistons? That was just to get an idea of the volume of the pop up?
I'm no engine builder, but I think it is somewhat common that bores are out of round by .001" even when freshly machined. At least, that is what I recall a performance L series engine builder telling me once. I recall him saying something about his cylinders being rounder than many because of his equipment (and something about honing technique) and that because they were rounder, engines he bored would break in quicker than some. So, I'm sure one of the more qualified will weigh in (and their comments should be worth more than mine), but I'm thinking all you may have to deal with a slightly longer break in period. Other than that, with fresh hone and new rings, I think you will be fine.
Yeah, he doesn't have what I need. I'm in no hurry. I've got 3 carbs that will make a good triple setup. Just need a couple of parts to finish the rebuilds. Will consider whatever people have. I could use a usable main body... Have two side feed float covers with one top feed... Anybody have some with age, heavy use, etc. just kicking around, let me know. G
I need a couple of Mikuni parts... I believe these are the same for 40 and 44. 1 float height/support spring - number 16 in the Mikuni manual. 1 throttle shaft spring - not labled separately in the manual (goes on the throttle shaft between the two bores. Could also use left side (when face bore entrance) throttle bracket, spring, etc. Could be interested in some 39 or 40 chokes as well (these are for the 44's)
I don't really think I need a full quart (which is how it is sold) to do one block. Just wondering if anyone has some usable Glyptal on their shelf that they think might outlast them before they ever use it again. Let me know.
I have a bunch of LD28 parts I'm looking to get rid of... and I'm in Barboursvile, VA. Let me know if you need anything (the crank is gone).
Nice. That makes for a really nice rod to stroke ratio. Pin height on those pistons is going to be what... about 25mm? G
$928 including shipping. The website has seriously cool parts for z cars... but most are way overpriced. http://www.rhdjapan.com
So the box is £160 plus shipping - which is currently $261US plus shipping. He sold me a cosmetic blem for a few dollars less... Here is the website: http://www.mjpshop.co.uk/product_info.php?id=113&pid=437 I paid by PayPal. Here is the contact info: Mike Feeney at MJP (Eastern Auto) Brentwood, Essex Here is a thread on zclub.net with lots of info about the box: http://zclub.net/forum/240z-260z/16484-air-box-fitting-tips.html
Yeah, I'm pretty sure that if I don't lick them, I'll only knock one year off my life. But, they are so pretty, I am thinking about licking them.
Interesting combo. How long are the FJ20 rods? I'll be using some Eagle aftermarket rods from a Toyota Celica. They are 5.428" long and weigh about 565 grams. Here is a link to some of my engine build info. These numbers have changed just a touch, but I'll update the info at the link soon: EngineBuild The air box I have is a direct copy of the TWM box by the way. I confirmed that - contacted the guy that originally made them. Now they are sold by someone else. Don't know if you plan on using a TWM box with the TWM manifold... Anyway, this one is much better quality than the TWM box (I got one of those with the FI setup I bought on eBay). This one is made of fiberglass. The walls are a bit thicker also. I think it was around $250 with no customs or duties. Let me know if you would like the contact info.
I believe I have one of those also - I saw it a couple of days ago. I think you got the injection pump from me? Garrett
How about this? http://cgi.ebay.com/ebaymotors/1968-70-DATSUN-ROADSTER-2000-U-20-WATER-PUMP-PULLEY-/330547935555?pt=Motors_Car_Truck_Parts_Accessories&hash=item4cf6313943#ht_500wt_1182
No crankshaft yet... getting antsy. Anyway, here are a couple of pics of the in air box (from England) and filter arrangement. I had to cut a hole in the firewall for the 3" inlet. Not sure where I am going to put the air filter yet. Probably will cut the pipe a bit shorter and move the filter out of the air stream for the radiator. Radiator is a crossflow unit from Jags that Run.
cyl head back from machine shop - ugh! Really?
inline6 replied to inline6's topic in Nissan L6 Forum
The first round of work was done by Citizen's Machine Shop - Richmond VA. I did not go back to give them a chance to correct things. With the type and number of problems I discovered when I looked it over, I decided I'd be more comfortable just taking it elsewhere. -
I got in touch with Bryan at Maloney Competition systems and had him fix the head. The level of detail is incomparable. Bryan determined that the head (already milled by the previous shop) had a slight bow to it (flat edge on original top surface showed this). L series owners should know that having warped heads is common and something that the machine shop should look out for. Before any remachining is done, the head needs to be checked for straightness, and then corrected via heating, if at all possible, on a perfectly flat surface to get any warp out of it. If your shop doesn't have experience doing this and the head is warped, IMO, you are asking for trouble by proceeding with machining. Since my head had already been milled on the head gasket surface, (and the head was still bowed on the top surface, that meant that the cam towers were out of alignment. He meticulously milled the cylinder head surface where the cam towers touch the head (not the whole top of the cylinder head, to account for the warping, which realigned the cam tower holes. Though I could turn the cam by hand before, now it turns with very little effort. That frees up some horsepower... Additionally, he fixed the seats by recutting them, took out all of the intake guides that had just been installed (one of them was cracked by the way) and machined the ends of the new ones like I wanted, and installed and sized them to fit. Finally, my combustion chambers were cc'd, and 1,2 and 4,6 were modified to match 3 and 4, as they were larger (thanks to the slight bowing/warping of the cylinder head (see, I told you that you should have it straightened before you machine any surface!) He also determined necessary lash pad sizes and then cut oversized lash pads (the only ones that were available at the time) to the sizes needed in a mill, and did final assembly. We're about to start on the bottom end now. I hope to have that done by June. Thanks John for the recommendation. If anyone is interested in having Bryan look at their stuff, he is interested in more L series work. As John stated, he is in Martinsville VA. Next time I go there, maybe I'll take some pics of his shop and put them up here. -
Delrin Steering Coupler - cracking?
inline6 posted a topic in Brakes, Wheels, Suspension and Chassis
I replaced my stock steering shaft ujoints, and I notice that my Delrin steering coupler has some cracking going on. I like the feel of it just fine, but I don't see a source for them. I do see a couple of poly versions available. Anyone have experience with both? If I go poly, am I going to loose some stiffness? Anyone know of a source for the Delrin ones? Garrett
