inline6
Everything posted by inline6
  1. Interesting. I wonder what the stroke is and what the rod journal sizes are. Maybe I'll ask them. I am planning on running Honda sized rod journals. I'll be needing 90 mm of stroke though.
  2. Thanks. Sent you a pm. You need to source some stuff in the US? I am sure I could help with that.
  3. Bump. I wasn't very clear with my first post. I am looking for someone in New Zealand or Australia to buy some parts for me off of trademe.co.nz. I can't register to buy parts on that site being that I am in the US. Looking for someone to buy some stuff for me and communicate with the seller on my behalf. I will pre-pay auction amounts, plus additional for your time. Thanks. Garrett
  4. Very interested in hearing more about this. I have been intrigued about the stroker billet cranks that Crower made for Rebello over a year or maybe even two ago now - per the Youtube video. These were "greater stroke" than the stock V07 crank, but I haven't heard anything more about them. I plan to get a billet crank for my next engine and consider Dave to be a top 2 source for it. Wonder what this new one is...
  5. I am looking for some engine parts that I know can be found in NZ and not in North America. Please pm me for details. Garrett
  6. I have some questions about your block. Can you tell if the front three and back three cylinders are siamesed? That is, are there no coolant passages between 1 or 2 or 3 and none between 4 and 5 and 6? Instead of separated/isolated castings for each cylinder, is each set of three connected/contiguous? And by contrast, there are cooling passages between cylinders 3 and 4? Could you post some more pictures of it when you get a chance? Front, back, and the two sides? The pistons you have mocked up are 89 mm diameter? Garrett
  7. I sold a pan like that when I parted out a V07 a while back. I would think it wouldn't be "too hard" to find. I'll keep an eye out. Sorry if anyone is annoyed with the digression. We can move the theads for getting the V57 blocks to another thread?
  8. I think I would like two also. That is four or five already.
  9. Ok, so you have a friend who can source these blocks? I am seriously interested in obtaining one. And I might be able to get others interested in a group buy. The V57 block never came the the US from what I can tell. Looks like it might be the version that was used for the factory supplied LD28T (turbo) as well as some industrial and marine applications. Garrett
  10. Thanks for the pics. Your block is a V57 casting... which has external ribbing. You have a completely different animal there than the LD28 that came to the states. I found this image of a V07 block in another hybridz thread. Very different even just looking at the exterior, if I am seeing this right. Regarding uploading pics, look on the bottom right of the blank post area for the next post in the thread and you should see a button labeled "more reply options". If you click that, you will get more functionality exposed including the "choose files" to upload option. Maybe a group buy of V57 blocks from you is in order!
  11. Thanks for the update. My engine builder recently completed making some mandrel adapter rings which, as I understand it, will be used to locate/hold the block while they bore it out.. We are going to bore both an L28 and an LD28. With the L28, we're going to go to something like 92 mm (I forget precisely the number). We are trying to remove all of the bore so we can examine the thickness of the deck and the bottom shelf of the bores. This is just to provide any information that may be helpful with regard to liner design. With the LD28, we'll try to go to 89 mm, but given others experiences that we know of here in the states, we aren't giving that a high percentage of success. This is why I find your information so intriguing. Anyway, if upon examination of the L28 bored out we see there is still promise with using a wet liner, then if we break through the LD28, we'll keep going until the bore is gone on that one also. Then we'll have to see if we can come up with a final design of the wet liners. Thanks again for the info. I wish I had your block.
  12. Any updates, Speedtripper?
  13. Anyone have any dry sump parts for the L6? I am looking to switch from a wet sump oiling system to dry sump. Garrett
  14. My Maxima block will be machined this week and we'll see what is possible with it. The plan is to go to wet liners. It would be amazing if the block will take an 89 mm bore. I don't think it will. If we break through, we'll keep going to 88 or so mm and examine the height of the deck and the height of the floor of the block. Should know more soon. I wish I could get my hands on a block that would take a bore of 89 mm. I tried looking for a Nissan Patrol diesel block on a couple of auction sites in South Africa. Nothing on either of those.
  15. Uggh. Need to be able to drop the engine down at least 3/4". Thanks for taking the time to measure and provide the pic.
  16. I've never come across this one before - automated engine block machining? Automated transmission assembly? Early computer aided design (CAD)? Definitely some interesting footage:
  17. I got the diesel LD28 block I was looking for. Thanks to those who offered.
  18. So, you've sonic tested after boring and have 3 to 5 mm? Yes, very interested in seeing more about this engine. I am exploring using an LD28 block for a new engine. My engine builder started examining the one I just sent him. It came from a US spec Maxima. He knocked out the front and rear freeze plugs and estimated the bore thickness at around .220". However, he notes that there are spaces between the as cast bores, meaning none of the bores are siamesed. He's going to sonic test a few of them to see what we're faced with. IF the bores are around .220" thick, we MIGHT be able to bore to 89 mm and have .120" (3 mm wall left). He is very doubtful... Maybe those Patrol engines are different?
  19. Yes, that would be helpful. I was planning on buying one soon so I could take measurements. I'm not sure how to go about lowering the engine as much as possible, thus the reason for the post. Dropping the engine means dropping the front of the transmission. I assume dropping the front of the transmission means dropping the back also (will need a custom transmission mount). My initial thought is to lower the engine 3/4" to compensate for the extra height of the LD28 block. That would put the header (and custom exhaust) back in the same location as it was with the L-28, and solve the hood clearance problem. But, while I'm here... I figure I need to explore the possibilities.
  20. Anyone running a dry sump set up with an ARE pan? I'm looking into it and thinking about lowering the engine. I'm interested in lowering it by using custom or modified engine mounts. Curious if anyone has done this or something similar. Garrett
  21. I saved these pics from somewhere online years ago. This guy was doing a very accurate/faithful restoration and had this bracket custom made to be like the original. I made a simple L shaped bracket and bolted it to this same location you see in the third picture (pic is not my car). There are two nuts already welded to inside the car frame that are there specifically for the fuel pump bracket. I made my bracket out of .100 thick mild steel. You'll want to make it longer than the height of the fuel pump so it can serve as a shield to keep road debris from bouncing up and hitting the pump, hooking on the pump, etc. You can find rubber grommets at auto stores that are the right size - I think I got mine from Advance Auto. Regarding wiring: I recall being able to find several people who wrote about it online, perhaps on this site. I remember reading about members who wired in auto "cut-off" switches of different types... so the pump turns off in an accident situation. You would be wise to so. On my 12/70 series one car, there is a factory connector "taped" to the wiring harness in the center of the dash with blue tape. If I recall correctly, you can get power to the pump (key position "on") by putting a fuse like this in place on that harness connector (thereby joining the two connections in the harness plug). On my car, that wiring goes to the electric fuel pump location in the rear of the car - I believe it shares the wiring for the tank sender unit. My pump was just like the one in the picture above, it only had one wire, and it was for the 12V power. My pump body had to be connected to ground for it to operate - again, like in the picture above.
  22. Hi Rick, Thanks for the note. I have paid for one that will be shipped to me in a couple of days. I'll let you know if the deal falls through. Garrett
  23. The google site specific search works in Google images also. So, if you are looking for pictures of something specific on hybridz... voila!
  24. I typed this up for my engine builder via email, so I'll share it here also: There is a section of the Honsowetz book about bending heads: If a significant amount of welding is to be done or if only a little amount of material can be milled to straighten the head after welding, it is best to bend the head backward-up at the ends. After bending, the head gasket surface will be convex. This pre-bend will compensate for warpage that bends the head in the opposite direction (concave) that occurs when the combustion chambers are welded. The amount of preload or bend depends on the location and amount of heating or welding. Bolt the head upside down to the deck of the stripped block. Support the head off the block with a spacer block at its center. The spacer should span the width of the block, be approximately 1-in. wide, and at least 0.100-in. thick. Secure each end of the head to the block with two short head blots. Gradually tighten the bolts and check the bow in the head with a precision straightedge and feeler gauges. You'll need a 36-in. long straightedge for checking a six-cylinder head; 24-in. will do for a four cylinder head. With the straightedge flat against one end of the head, check the gap at the other end using your feeler gauges. How much prebend you should put in a head is subjective. It depends on how much welding will be done. This is something you and your welder must judge. Use the following as a guide: For small to significant amounts of welding, pre-bend 0.020-0.040 in. for a four cylinder head and 0.020-0.060 in. for a six cylinder head, respectively; 0.020 in. if there's a minimal amount of welding to be done and 0.040-0.060 in. if you're going to do a lot of welding. If you guessed right, your weld-repaired head will only show 0.005 - 0.008-in. warpage after it has cooled. Use your straightedge and feeler gauges to check. Whatever is required to clean up the head, the same amount must be milled from both sides. Welding Combustion Chambers to Increase Compression: As mentioned previously, the head must be absolutely clean before you can weld the combustion chambers. This applies to both old and new heads. Polish the chambers with cartridge rolls, then with a rotary brush. Bend the head backward the maximum amount because welding all combustion chambers is a significant amount of welding. Therefore, using my recommendations, a four cylinder head should be bent backward about 0.040 in and a six cylinder head about 0.060 in. Instruct the welder to "jump around," or weld a small amount in one area at a time. This will keep welding heat from being concentrated in one place, thus helping to reduce warpage and prevent cracking. Honsowetz also has a section on straightening heads. Basically, it consists of bolting the head upside down on an engine block and using a spacer and bolts as above. He says to tighten the bolts until the head is bent backward about 1.5 times the amount that it is warped. He again uses a straightedge and feeler gauges to set it up. Then he describes using a acetylene torch with a rosebud tip to evenly heat the entire head to 350F. He describes using temperature indicating crayon or paint and marking the head in many locations. It can take up to 30 minutes to heat the head to 350F this way.
