Pyro
Everything posted by Pyro
If your turbo doesn't make full boost until 3500 rpm+ then that is a sign of a free flowing turbine. Which means that turbo can handle some valve overlap and would work well with a cam with around 270 degrees of duration on both the intake and exhaust.
Turbos typically like cams with more intake duration than exhaust. The theory is shorter exhaust duration makes a hotter and faster exhaust stream into the turbo. (pure exhaust) What turbo are you using? A stock turbo has a small turbine and makes lots of back pressure in the exhaust manifold. So stock turbos don't do well with any valve overlap. If you are using a more free flowing turbine then more overlap can be used.
Gages can vary. I have 2 gages, the same make and model, and one reads 20 psi lower than the other one. More important to see the differences between cylinders. A stretched timing chain can lower cranking pressure. Advancing the chain to the next position can increase cranking pressure by a large amount. Years ago on an old worn out 78 280z, my engine increased cranking pressure by 50 psi by advancing the cam from the 1st position to the 3rd. Check timing marks on the cam/sprocket to see if the chain has stretched.
Use the low speed part of the taurus fan. Cools about the same with 1/2 the current draw.
What turbo did you get from ebay?
I set a "bigger" cam a little tighter. try 0.008" (hot). Most aftermarket cams spec a tighter lash than stock. If someone puts in a regrind cam without increase the thickness of the lash pads, it will tick. Check to see if the lash pads are stock and if the cam is a regrind. Also check the wipe pattern. Aftermarket cams are louder than stock cams.
Get a used 96 to 2000 5.7 vortec engine. Comes with a factory roller cam and vortec heads. Should be able to get a complete engine (fan to flywheel) in good shape for less than 1000. May also be a good idea to get the transmission attached to the engine. I would also get the engine with the complete efi system and get that going too.
Zinc, ZDDP and camshafts - Does anybody worry about this any more?
Pyro replied to NewZed's topic in Nissan L6 Forum
Stock cams with stock spring will not have a problem with the new oils. High lift, fast lobe lifts, and stronger springs will create cam lobe wear issues. -
I run the T04B-H trim with a T3 exhaust turbine (stage 3). Boost comes on slow and steady, almost feels like a big non-turbo engine. Would work really well for an autocross car, due to the slower increase of engine torque. Makes 5 psi of boost at 3000 rpm and full boost by 3500 (running about 12 psi). The free flowing turbine allows 80 mph driving with 10 inhg vacuum. The stock turbine was at 0 inhg at this speed (starting to make boost). According to the compressor maps, my engine should be in compressor surge at 3000 rpms, but it isn't in real life. I miss the low rpm boost of the stock turbo but i'm not going to try low boost with this compressor due to the surge risk. This compressor is better when used with a stage 1 or bigger camshaft (higher rpm cam), or at least use a NA cam. Finally, the T04B-H clears the intake manifold with out the spacer that is required for the T04E-50 trim compressor.
Upgrading my SBC Aluminum heads should i get a new cam?
Pyro replied to logan1's topic in Gen I & II Chevy V8 Tech Board
I used the Hooker Super Comps for sbc conversion for a z. I bought them 10 tens ago so not sure if you can still get them. The headers required a little modification to get into the car because the headers were not designed for the setback position (JTR position), plus the scatter shield for the clutch was in the way, and I also converted to 2-1/2" collector flangers for more ground clearance. I also seen some early 70's corvette headers that fit pretty close, but still require mods. I brought the Dart 200cc iron eagle heads and used the springs that came with the heads. The springs were a little stronger than the springs recommended by Compcam for the 292H. I believe Dart heads came with springs for a roller cam. Anyways, the 292H would float the valves at 7200 rpms and pull hard to 7000. However, my best et's were made with 6500 shift points even though I would swear the engine was still pulling very hard past 6500. I have a 5" Autometer tach so I'm pretty sure about the RPMs. Good luck with your cam! -
I ran the 292H with my 350 powered z (t5, 3.90 gear, 200cc dart iron eagle, long tube headers, rpm intake, 750 carb). Great cam but a rough idle. Once moving the cam was very streetable. Useable power from 3000 to 7000. Ran a between 117 to 120mph in the 1/4 mile around 11.7 et. Did a best of 10.7 at 135 with a 175hp shot n02. With block huggers, single 2.5" exhaust, old fuelie double hump heads, 292h cam, rpm intake, and 750, it ran 12.7 at 110 mph. So, it drop a full second in the 1/4 mile with better exhaust and heads. 12.3 with better exhaust then 11.7 with better heads, installed in that order. After your head swap, I think the block huggers and 600 cfm carb are your biggest hp killers. And the hp will be choked off even more with the bigger cam. The performer intake and 5500 rev limiter is not good for the bigger cams. I would stay with the rpm intake no matter what cam you use. I don't like air gaps, but like the regular rpm intake. Also get a holley 3310, 750 vacuum secondary. Last thing, a bigger cam will need 20 to 25 degree of ignition timing at idle and use zddp oil additive to keep the cam lobes happy. -
I have run both and haven't notice a difference. I have been told that they can handle the same amount of power but both are on the weak side. Syncro's in the wc are better. Like I said, I have run both in my z with a 400+ hp 350 and a 200hp shot of n02 with drag slicks. They will last a long time if you don't slam the gears too hard. Avoid power shifts, fast shifts, and clutch dumps. I feel the GM T5 transmissions are stronger that the Z's rear axles and diffs, as my car tends to break those and not the transmission. You need to use the V8 T5 with the fine tooth splines (26 tooth), the V6 T5 has around 10 splines.
NA 3.1L=>head & camshaft questions. No shortcuts, max
Pyro replied to zredbaron's topic in Nissan L6 Forum
I had a new oil pump fail on me a few years ago. The lid didn't have enough clearance between the rotors and the extra drag wore the oil worm gear off the crank which also put metal in the oil which ate up the engine bearings. Now, I always disassemble my new oil pumps and check the lid clearance. And since then have found a few new pumps that were too tight from the factory. With a cam that big, I would just lock the mechanical advance in the distributor and set it to 35 degrees at idle. good luck! -
Use a stock NA cam (internally oiled, 1977+) in your P90 head and you will be fine. In fact, a stock NA cam works better then the turbo cam in my opinion. Good for another 500 rpms of usable power
Forget the dinosaur 327, use a LS engine. Used and complete 5.3s go for 500.00 in good shape then add mega squirt. Any Z year will work. Calculate the cost, time, and work involved then triple it.
I would swap the turbo cam for a stock NA cam. This is good for another 500 rpms of usable power and more HP. The stock efi system can handle 10 psi so 12psi would be easy to get with an FMU (same thing as the bell RRFPR). You can get a non adjustable FMU on ebay for 100 dollars (the bell is adjustable but cost $250). I would get a 5:1 fmu since you already have a stock turbo efi setup. I use 8:1 fmu's when converting stock NA efi to turbo. Next, I would add a 3" exhaust system. Small restrictive turbo's do better with bigger exhaust systems. An IC is required as you know. 2 to 2-1/4 piping out of the turbo to the IC is all you need. Get your stock turbo rebuilt at a turbo shop. With 12-13 psi and the above mod's, I think you could make 250 at the tires. This is about max for the stock turbo. First, I would add the NA cam, get the turbo rebuilt, install the IC, and turn up the boost to 10 psi and drive it like that for a while. Should make around 230hp with this setup. Do the exhaust, 12 psi and fmu later. You may be happy with 230hp at the wheels (265hp crank).
I built an exhaust system just like yours for a friend's V8 conversion and got the same results. The car was very hard to drive in. So this is what I did to fix it. 1. Installed a short H pipe right after the transmission. 2. Installed two 2-1/2" x 12" long Dynomax Bullets (one on each side, after the H-pipe). 3. Moved the Y-pipe all the way back to the diff. (as far back as possible). Now the car is very quiet while driving normally, but sounds really nice when driven more aggressively. Note: I'm not sure if the H pipe was required or not, as I did all the changes at the same time.
Do i still need a Fuel return line?
I recommend you change your whole fuel system. I have gone down the path of aftermarket carb pumps and have came across a better solution during my last V8 conversion. I would use the stock efi fuel pump (or like stock efi msd 2225) and an Aeromotive return style fuel pressure regulator set to 6 psi. The stock efi pumps are quiet and very durable and flow a lot of fuel, especially at 6 psi. After market carb fuel pumps are LOUD and don't last long (brushes wear out). -
The tool you need is a "piston stop tool". Screws down into the spark plug hole. Remove ALL the plugs and insert the Stop into the #1 cylinder. Put a racket on the crank bolt and rotate CW slowly and easily. When the piston hits the stop, mark the balancer at the zero degree mark. Then rotation the engine the other way (CCW) until the piston hits the stop and again mark the balance at the zero degree mark. The center point between the two marks is the real TDC. Balancers slip over the years. I have seen them 20 degrees off and still appear to be working. However, a balancer that is that far off will not last much longer.
FYI, Do not use glass packs with bumps inside the tube. Use the glass packs with perforated holes inside the tube. Glass packs with bumps are very restrictive. I recommend Dynomax Bullet Glasspacks, as these are made with the new perforated hole design. For up to 200 to 250hp, I recommended a 6 into 1 header, single 2-1/2 inch exhaust system with mandrel bends to get around the rear end. And one dynomax bullet in the tunnel and a turbo muffler out back.
The only difference between the AT turbo and MT turbo pump is the spring. The AT has a lower pressure spring so the cooler doesn't blow up.
That makes no sense to me. A stage 3 turbine making full boost at 2500 and afr's in the 10's and 11's with NA injectors and with no extra fuel pressure. All I can say is, with these results, you should be good to go. A FMU is a fuel management unit. It is what people use to add boost to an engine that was originally a NA setup. It goes in the fuel return line and increase fuel pressure only during boost. But it seems you don't need one, with afr's in the 10's. Have fun.
At what rpms is it reaching full boost? What fuel pressure are you using? Did you get a FMU? How much ignition timing?
