joem64
Everything posted by joem64
Hey, thanks for the response. I kinda figured that was a possible answer... I look forward to getting my 5 speed up and running as well. thanks joe
Mr. Bob... was your issue with the neutral switch resolved?? I have that same tranny, but do not have a tapped hole where the red arrow is pointing to.... has me a little confused. It's just a blind hole, no threads. Maybe the engineers used a different trigger for the neutral position. thanks, joe
Anybody have the 2 pieces that reinforce the oil pan flange for any of the L engines?? Mine were destroyed, need something that will be workable. Either that or if someone has a jpg I can bring it into Fusion 360 and model and create toolpaths. thanks joe
Thanks for the reply and info. I did not see any 'cwc' marked anywhere on the cam. Back journal is stamped 'erson', '280n' and '1187'. I could take the cam to my local machine shop, they should be able to measure hardness. I'll check out the FB page. thanks again joe
- 9 replies
- l28
- degreeing cam
(and 2 more)
Tagged with:
I believe it is new, not an original nissan cam. The width of the lobes is quite different. you agree?? joe
- 9 replies
- l28
- degreeing cam
(and 2 more)
Tagged with:
very nice. Gotta love the spring/valve height measuring gizmo!! Looks like a lot welding there as well. joe
- 9 replies
- l28
- degreeing cam
(and 2 more)
Tagged with:
I guess my intended audience is DIYer's or anybody who's looking for a little more info. you're right about the lash pad sizing. It wasn't blind luck, maybe a decent guess. I made sense that with the new cam having the same base diameter that a closer to stock pad would be required. I thought it might help me figure it out by going thru it and explaining it. I'm always open for comments and help. joe
- 9 replies
- l28
- degreeing cam
(and 2 more)
Tagged with:
Because I haven't seen any videos talking about lash pad sizing, cam degreeing, degree wheels, or TDC on an L28, I figured I'd take a shot at it. Please excuse my video production qualities or my lack of expertise. Like i said, just wanted to take a shot at these subjects. Please comment if i've missed something big or small. thanks joe lash pad sizing.... https://www.youtube.com/watch?v=TQSf2TinWc4&t=215s TDC short block....https://www.youtube.com/watch?v=SvcXhv-HZ_0 TDC validation with head installed ....https://www.youtube.com/watch?v=09AJpZ9z0EY Intake cam lobe center validation... https://www.youtube.com/watch?v=895VzDZA8pA
- 9 replies
- l28
- degreeing cam
(and 2 more)
Tagged with:
82-83 l28et distributor plug pics please!
joem64 replied to l28et280z's topic in S130 Series - 280ZX
Hey, thanks for response, i've already talked to our friends at vintage connections. -
Is there a mfg name or model # on the plug?? I need to locate one as well... or start searching thru salvage yards... always a good time.. joe -
Fellow Enthuziazts... I'm in the process of resto-modding my 73 240z. I purchased the AZC coil overs, they are very nice. The car is in the process of being painted, and I'm redoing the suspension myself. I've had just about every part of the car acid stripped, and i'm ready to assemble the suspension. Want to weld, paint, assemble, and send to shop for installation on the body. Unfortunately, i really can't mock up the rear coil-over setup with body, because it's all completely apart. This is just a street car, maybe the occasional autocross. I'll probably get some 235/40 17s or something close to the original tire OD. I probably won't lower the car more than inch. Can anyone share what height or dimension was used to locate the new coil-over tube?? I cut the original strut tube at 3.5" from the casting per AZC's directions. thanks Joe in SE WI.
Hey, I went with the American AutoWire Hiway 22 kit for my 240z. It's a pretty nice setup, but the main terminal block is not exactly small. I will be running a megasquirt and fuel injection pump and such so I went with the larger unit. joe
beautiful Z car. i'm installing the same coil overs on my 240. How high did you weld the new tube from the bottom casting?? I cut original strut tube at 3.5" per AZC directions. I'm going to run the same size tires, and don't want to drop more than inch. I got the body in the shop getting painted, and don't feel like mocking it up... just want to weld it and paint everything up. thanks, Joe in WI
Was talking to a gentleman at one of the larger Nissan parts suppliers today. Their site doesn't go back to anything earlier than '84. He gave me the name for a website that specializes in early Datsun/Nissan parts that are not listed on the site. The site is http://www.carpartsmanual.com/#ManualsMenu It's pretty extensive and it has Nissan part numbers. Fantastic resource for us early Z car and Datsun restorers. joe
Looking for a kit for the retaining rings, o-rings, and other stuff to rebuild my half-shafts for my 240z. Does anyone know what's available out there? thanks, Joe in WI
Need to find a source for the stock nissan oil galley plugs for a 280ZXT block. I had removed the plugs myself, and my machine shop didn't realize they were needed(they work primarily on american engines) My fault, on several counts. So, i'm just trying to find a source for these friggin things... anyone have one? Just want to tap them in, and start the final assembly process. thanks, joe in WI
Thanks for all of the replies. Figured someone has done this already....thought it was the 'thing' to install E31 heads on 280Z blocks... I've had my block bored out 1mm over. I'm not sure what's what when looking at the holes and such, what's oil, what's coolant. Interesting. thanks again, i'll dig a little myself and see what i figure out. joe in WI
Building a street car with an F54 block and an E88 head. Should the head gasket match the block or head?? The 240 block deck looks quite a bit different than the 280zx block deck.... joe in WI
Hey, Mr. Youseff, did anyone respond to you?? I'm installing a E88 head on a F54 block, and I to have some questions about what head gasket to purchase... joe in WI
Z persons, I recently grabbed myself an F54 block for my 73. Stock bore is 86 mm, and I want to open to 88 or 89mm. Don't need forged pistons, this a NA, street car, occasional autocross. Doesn't seem like there are too many piston makers out there. Any info would be greatly appreciated. joe in Racine WI Restomod: 73 240z, megasquirt seq FI and COP, coilovers
Z car fans, Looking at different kits for my 73 240z. Need a kit for the street and occasional autocross. I received instructions for two different kits, and to my surprise they were the same instruction, and very poorly done. I've attached the instructions if anyone would like to take a look. Looked to me like it was translated from another language, probably Japanese. I'm basing my purchase on a lot of things, and one of them happens to be the fabrication/installation instructions. Can anyone share with me the BC Coilover instructions?? I contacted the mfg, and they have not disclosed the information yet. thanks, joe in SE WI NISSAN 280Z INSTRUCTION.pdf
I know it's 4 years later, but do you still have fuel tank?? Joe in SE WI
Hey everyone, Looking for a clean 240Z fuel tank, any year should work, i believe. Joe in SE WI.
