I sent this to Fidanza via e-mail not long ago
Hello,
I recently purchased a Fidanza aluminum flywheel for my 1983
Datsun/Nissan 280zx turbo. (I have a 1978 Datsun 280z with a '83 turbo motor) Part number 143281.
Attached are 7 pictures comparing the stock 1970-1983 non-turbo 225mm
friction surface flywheel and the stock 1981-1983 280zx turbo flywheel
(also found in 2+2 cars which have a back seat) which has a 240mm
friction surface on the flywheel.
Picture titled "fidanza flywheel003.jpg" shows all 3 flywheels side by
side. The Fidanza on the far left, the 240mm flywheel in the middle and
the 225mm on the far right.
Picture "fidanza flywheel002.jpg" shows the 240mm flywheel on the left
and the 225mm on the right. Notice how the 240mm flywheel has 9 total
bolt holes, while the 225mm only has 6 total?
Picture "fidanza flywheel004.jpg" shows the 225mm pressure plate on
the Fidanza aluminum flywheel. All 6 bolt holes line up properly.
Picture "fidanza flywheel005.jpg" shows the 240mm pressure plate bolted
to the factory 240mm flywheel. All 9 bolts line up even though the
pressure plate is aftermarket. (ACT (advanced clutch technologies))
Picture "fidanza flywheel006.jpg" and "fidanza flywheel007.jpg" show
the 240mm ACT pressure plate on top of the Fidanza aluminum flywheel.
The outer bolt holes line up.. all except the middle bolt holes. From
what I can tell... the bolt holes are drilled properly for the 225mm
pressure plate (6 total bolts) while the 240mm has 6 of the 9 bolt
holes drilled properly. The center bolt holes are offset improperly.
Picture "fidanza flywheel001.jpg" shows the ACT 240mm pressure plate
slightly over extending over the surface of the Fidanza aluminum
flywheel about ~ 1/8"
Overall I can determine that the Fidanza flywheel is drilled properly
for any Datsun 240z/260z/280z/280zx non-turbo and non 2+2 application
for the 225mm clutch and pressure plate. However; the flywheel has 3
bolt holes that are off for any Datsun 280zx turbo and 2+2 application.
6 of the 9 bolt holes line up properly which follows the 225mm bolt pattern.
