proxlamus©
Everything posted by proxlamus©
  1. proxlamus©
    906081829
    Z32 transmission
  2. proxlamus©
    parts!
    whoo! A. Hoke adapter... Driveshaft short throw shifter flywheel etc etc
  3. proxlamus©
    shifter mount
    shifter mount for Z32 transmission.. 3/4" steel.. similar to A. Hokes mount he built for a buddy.
  4. I made this cross member out of 1" square tubing and tucked in some 3/4" steel tubing inside to make it a bit tougher.. this allows me to keep the stock 280z transmission tunnel ears.. they had to be trimmed down a bit for the transmission to fit. but its all good =)
  5. Update.. I used the stock slave cylinder in my swap.. I didn't need an extension with the slave cylinder hose.. everything worked out great.
  6. Quick question... when installing a battery cut off switch.. Do I wire this up to the POS + terminal or the NEG - terminal? silly question but I really don't have a clue
  7. odd place for a battery! any more pics of the battery gabe?
  8. Good thing the group buy isn't for Datsun Spirit Thank you for the write up and information though! im sure someone will do a search and come across this!
  9. Excellent work Ben!! your car is looking great now!!
  10. not even close to awesome... its hideous .. but thats my opinion
  11. While I had the flywheel off.. here are some pics... The weights MAY vary depending on how many times the flywheel has been re-surfaced or how it was balanced!! Fidanza aluminum flywheel Factory 240mm flywheel Factory 225mm flywheel
  12. proxlamus©
    Z32_swap012
    ACT pressure plate ACT clutch disc Fidanza aluminum flywheel and Z32 A. Hoke adapter!
  13. proxlamus©
    Z32_swap011
    new ACT clutch and Fidanza aluminum flywheel and A. Hoke Z32 adapter!
  14. proxlamus©
    Z32_swap008
    Fidanza flywheel and Z32 adapter from A. Hoke performance
  15. proxlamus©
    Z32_swap007
    225mm flywheel weight
  16. proxlamus©
    Z32_swap006
    240mm flywheel weight
  17. proxlamus©
    Z32_swap005
    Fidanza flywheel weight.
  18. http://forums.hybridz.org/showthread.php?t=138792 take a look at this Group Buy
  19. I've noticed some 12 gal NHRA fuel cells cost around $80-100... I'm confused why you guys want to spend nearly $700 to modify the stock fuel tank. Any particular reason? I don't want to be an ass but I am curious
  20. wow.. talk about a thread back from the dead!! lol
