Jethoncho
Everything posted by Jethoncho
1978 Datsun 280Z RB25 Restomod
Jethoncho replied to Jethoncho's topic in S30 Series - 240z, 260z, 280z
The windage tray I attached to the previous post from yesterday is a completely new fabricated part. The louvers are reversed from the original to compensate for the pan/sump being reversed. I’m gonna try to be a little more active with my post cuz I think it helps keep me motivated! Thanks for following my thread! -
Today’s project was to fabricate a new windage tray for my modified oil pan. The oil pan is now complete except for leak check of all my welds. I ordered an extra pan gasket today, once that arrives I’ll bolt the pan down to the aluminum slab that I have then pressurize it through the drain hole and soap check the welds...once that’s complete I can finally close the lower end on my engine. -
I like this idea, since I already have a slab of billet aluminum I bolted it down to to prevent warpage i’ll Just bolt it down to that with a pan gasket and pressurize it as you suggested. Great idea, thanks!
Did you have any issue with leaks? I’m trying to think of a good method of leak checking my welds.
Thanks for responding to my vent session...I appreciate your feedback! -
Thanks man, the second attempt was definitely yielded a better result plus I had the original pan to cannibalize. The slap of aluminum was scrounged from the shop that maintains the aircraft I fly. It was so billet material they had laying around and the were good enough to give it to me. I drilled and tapped it so I could bolt the pan to it to limit warping during the welding of the flange. Worked great!
Put most of my bare metal in epoxy primer this week. No more chasing flash/surface rust. Not too bad for spraying in my rather dusty garage. -
Here are a couple photos of my BC Racing coilovers mocked up in the rear of my car...to cure the clearance issue with the cv joint I lowered the T3 tabs so the are off the end of the BC weld on mount. As far as camber issue my T3 lower control arm are currently extended out on the bottom and the T3 camber plates are adjusted out, once the lower control arms are adjusted in the upper camber plates will bring the rear camber in spec. I’m very pleased with the mock up and happy to be able to use BC stuff on all four corners. -
So I threw in the towel on my first attempt at modifying my oil pan to a rear sump. I didn’t like the way it was going...I decided to start over so I bought a new front sump pan. Here is my frankenpan for my RB25 (attempt number 2) I converted it to a rear sump. First, I sliced off the mounting flange and reversed it. This required quite a bit of additional mods as the shape isn’t exactly the same. Then once this was done the sump had to be addressed since the engine sits in the car at approximately 12 degrees tilt to the left. This meant the sump bottom would now tilt 24 degrees...I sliced off the sump which again was no where near the same shape when reversed. It was necessary to graft in a couple of pieces from a donor pan that I had to account for the different shape on the new front of the sump. I still have to address the windage tray but I intend to just remake it so that should be fairly straight forward. The primer shows the areas that received modifications. I guess I could have gone out and bought a pan from one of the vendors that make them but I wanted something that looks OEM and I enjoy the challenge.
Is anyone else going crazy with S30 vendors? Retro-Spec Carbon is driving me crazy, my parts were suppose to ship 12/21 (after over 4 month of waiting)...they didn’t, Techno Toys Tuning orderedrear end swap kit, shipped me incorrect axles and CV boots (after 2 months still waiting for correct axles). Apex Engineering, promised two weeks on their cross-member with RB mounts after 4.5 weeks still waiting... These guys are niche companies so I guess they can get away with these kind of shenanigans. Seems to me they would quickly go out of business if there was greater competition. -
Finished the repair yesterday... Complete the butt weld patch and added the plug welded reinforcement panel..I’ll likely dress down the plug welds but structurally it’s repaired. -
Thanks! I think the reinforcement and the failure of its seam sealer is the cause of the rust in this area. -
Not very glamorous but very necessary...removed the reinforcement panel to get to the obvious rust behind it. Cut out the rust damaged panel then fabricated a replacement panel. Butt welded (tacked in) te patch panel. Still need to complete the welding then fabricate the new reinforcement panel to install over the patch panel. Not sure what the reinforcement panel actually does as it was original fabricate from very light 20 gauge material. Anyway, the new patch panel and reinforcement panels are going to be 18ga so they will have greater structural strength then the original stuff. -
Hello, I get what you are saying but you have to remember that offset is based on the distance from the wheel centerline. On the 8.5 inch width wheel you had a +4 offset or 4mm closer to the outer lip of the wheel based on the center of the wheel being an equal 4.25” from front or rear lip. Then you added 1 inch (or 25.4mm to get with the same measuring system used in the offset). Remember while you added this to the back side of the wheel it also moved the wheel’s center line by only .5” or 12.7mm. So if you measure from the new wheel centerline and add the old offset you are sitting at +16.7mm offset on the widened wheel. I did a rudimentary drawing to illustrate my opinion. You can use the new changed centerline measurement (121mm) minus the unchanged distance from from the outer lip (104mm) to arrive at the new offset of +17 (rounded off from +16.7). I hope it helps.
Back to metal work the past couple of days...finished welding on the left rear quarter replacement. It needs a little hammer and dolly wok but overall I am happy with how it turned out. Next the forward section of the left door jamb had a bit of rust neat the hinges. It wasn’t rusted through but I cut it out and replaced it anyway. The upper windshield frame had a small area of rust through...it took a small 2” by 0.5” patch welded in to correct this area. Still to go on he left side...small area on the floorboard (7”x10”), this will be a little work since it’s in the area where there are two drain holes and some bead rolling. I did take a little diversion to restore a 240Z steering wheel that I plan to use...I bead blasted the metal to remove old paint and surface rust. Next I repainted the spokes with POR15 satin black. After a day to dry/cure, I sanded the simulated wood and newly painted surfaces with 600 grit and applied thee coats of satin clear coat. I am extremely pleased with the outcome...too bad I’m likely a year away from installing it but it is gratifying and does help to keep me motivated. -
Thanks to those that reached out to me regarding the CV boots clearance on the lower BC coilover mount with T3 mounting tabs. I returned from four days on the road and decided to tackle this dilemma...I previously mocked up the rear suspension and figured out BC sent me a set of front coilovers instead of rears. I contacted BC while I was on the road and they were kind enough to send me a set of rear shocks and springs so I disassembled the rear and built it back up with the new parts while also incorporating T3 camber plates. To use the T3 camber plates T3 sent me bushings meant to integrate their camber plates with the BC coilovers...I decided I wanted to use the BC bushings instead so I took the BC nut and pillow bushing and turned (lathe) the bushing portion down to 15.76mm to fit inside the T3 bearing in their camber plate. Next after building up the rear coilovers with the correct parts I mocked in an axle and I have good clearance on the CV boot. I attribute this to the fact my lower mounts are likely front mounts and my T3 tabs extend beyond the lower end of the lower mount by a little over an inch or so. My lower mounts have a reduction in diameter about 4 inches from the lower edge so I attached the T3 mounting tabs even with the upper edge of the larger diameter on the lower mount. I posted up a few photos to illustrate what I’m talking about. With the T3 camber plates and T3 lower control arms I don’t anticipate any issue with camber adjustment either. -
I’ll be updating this thread as I progress. The BC Coilovers are new but they shipped me a set of fronts that are currently mocked up on the vehicle. BC already sent me some replacement parts to swap out to correct this issue. Once I get these swapped out and install the axles I’ll get some more photos up. I am traveling for work so it will be a couple days. -
Your rear setup looks great! I appreciate your input regarding the requirements to run T3 style tabs on the lower BC Coilover Mount. This is helpful...I’ll keep this thread updated as I make progress.
