Everything posted by TheMission
I Thought about that... since I'm not running any heater/fan setup in it... there is TONS of room to get at things. It's one of the reasons That I tentatively mounted the dash, just to see what space I had to work with. With the dash on, It's actually not tough to get at it from the left or right, and I'm going to run a custom panel where the heater controls/vent/stereo used to be, so I can make that removable if I really think there will be an issue. I'm now going to take the dash back off... as it's easier to do the wiring / relays without it there now that I have good pics and know what space I have to work with. I'm going to replace all the fuses in the panel with these - Light up fuses from Waytek. So it'll make it really easy to replace/diagnose issues with fuses as a result of where I chose to put it. In my build, there is just too much room there NOT to use it for the wiring and relay setups.
Sometimes you just have to say what needs to be said... Elanor... well, the design is for FORD, not a Datsun. The concept is neat for a picture, but in life, I'd imagine it'd be an object of ridicule, solely for the fact that so many of the design elements are taken from such a distinctive and recognizable icon.
Well... fun day! I had the day off, since I've worked the last 10 or so days straight at work, so played a bit with the car! Got the lock coversion and power window conversions in and tested - Finished the wiring of 2 and 0 gauge wire up to the front from the rear odyssey battery location and finished the brake lines getting run. Brake Booster and Clutch Master Cylinder Mounted Close up of the EZ wiring Fuse Box in it's location RAAMMat'd firewall and tunnel, (used extra pieces to hold down the wires for now) - All the silver will be covered with black closed cell acoustic foam from RAAMMat too. New Carpet Test Fitted over the Tunnel Lines from the rear to the front (Ground and Power) Ground will go to Frame at where the engine grounds will go, Power will go to solenoid and to the inside from there. Lots of work for 4 hours.
Full on resto mod of a 240Z
TheMission replied to Blakt Out's topic in S30 Series - 240z, 260z, 280z
If only... I've surrendered to the fact that a build of this level is only possible with one key factor, unobtainable to me. $. - Something that I think even Blaktout would attest to, as he'd pretty candid on the chunks of change he's put into the project! But, with $$$ invested, attention to detail, and picking the right people to do the work, at least we have an example of what's really possible! -
Woot! - Sourced my SR20DET with new clutch/CAS/vildini mount/wiring, etc.... only a few weeks till I get my hands on it and pretty much follow this thread post for post to clean it up and get it set up for my wishes. CLICK HERE FOR AN AMAZING SR20DET thread I love that thread... so in depth and up my alley!
I've seen a ton of vinyl wrapped cars for promo stuff from Scion and other Businesses and over time, it just looks worse and worse... And this is long life printed vinyl that's running thousands to install. I'd be interested in real facts about longevity, as a weeks worth of work minimum and (for those of us without vinyl "connections") the significant cost... I don't see it as a better option than paint, as paint will last much longer than 4 years and will end up costing less in the long run for the same styles and "looks"
Heating won't be an issue... There are thousands of urethane products on the market for modern sport compacts and few, if any, issues. All the body kits I've ever installed, and even the factory stuff from Toyota/Scion I've used is urethane and very, very resilient.
Any tips for mounting a fuel cell?
TheMission replied to Roostmonkey's topic in Fabrication / Welding
Someday I may think of forking out thousands for an ATL or such, but still think it can be done better than above, so I gave it a shot - I still went with the cheapo setup and if I have too many issues I'll let you know... I still am under the floor, but I am up higher than the pics above due to how I set it up and most likely the tank I chose. Sloshing with foam and starvation issues may hit me, but I can always make a secondary can and run a low pressure pump to that and high pressure away to fix that little issue. I may have issues with the return and vent lines where they are at, but I can always make lil' boxes to section them out of the cabin if I get flack for it. Here's pictures of my install. First, the hole Here's the mount I welded up and painted... (I used 1/2 inch weatherseal padding on the sides of the mount that support the fuel "Cell" to protect the tank from flex and possibly cracking issues) Here's the tank in a test fit shot to show how and where it sits This shows how "Low" the tank sits... It's actually impossible for it to hit the ground, as the mount would hit first anyways, but still is a tad higher than the lowest point of the rear transaxle assembly (it looks off kilter in this pic, but I just took these for reference shots and it sits perfectly level currently) Here's the panel with the vent line hooked up. I may end up just making little boxes to cap off the lines and keep them seperate from the cabin, which would be easy enough The "Fuel Door" is a dragster access panel from jerry bickel racing and seals off the tank from the cabin and allows quick access for fill ups... The side panel in the bottom right is a removable panel to access where the odyssey battery is, as I have a little mount for the battery under the panel now as well. -
Just cause you CAN, doesn't mean you SHOULD... but, there are always those who want to do it for the heck of it.
^ Definitely Agree.
Looks like you have some of the same fun ahead of you that I now have behind me... If you curious about fuel cell fun, I too have shaved the door and placed a cell in the back and can send you some pics of my fun... Good luck! Just keep at it.
Wow... amazing work! Relay Extravaganza! I've been hammering out my own pictures trying to put my mind around wiring my z with an EZ harness, as the turn signal switch and wiper motor switch are fun to diagram and figure out, but man... this is some work you have going for you to build from more or less, scratch.
Wow... as I watched this build over the months, I was like... how can even this guy afford this right now in the economy! (no surprise you have some funds backing you) Guess it's as hard on you as it is on the lower-budget guys around here too, like me. Props for the inspiration, as I'm doing as much as I can in the spirit of what you are doing, but without much of the meticulousness and without the ability of outside labor due to cost (and my intense curiosity and desire to get my hands as dirty as possible in it). The end result is incredible, and your engine bay is designed so, so well... I'll only be able to get pieces of that in the end result, but you surely have set a solid standard to walk toward for others. -
125 dollars for the vinyl? that's amazingly cheap... wonder how many "years" the vinyl is rated for. I'd be scared, especially with flat black and all that work on how it handles the conditions. I guess for a california car, it'd be a least a possibility, but the roads/weather/pollen and all the other things attacking that vinyl, aside from whatever son it gets, makes me think that all that work is going to be less than ideal in a year or so, where paint, if maintained, could last for many years.
Wow... cha ching... Now that's a pricey build! Beautiful and I love the engine, especially after sporting one in it's intended home for a long while...
Almost enough inspiration to learn how to mold urethane myself or locally source a cheap shop that does and develop these! They'd be so much easier to install cleanly and would surely last longer as well.
Are bump steer spacers REALLY needed
TheMission replied to Kevlars30z's topic in Brakes, Wheels, Suspension and Chassis
What a nice guy Prox is... reposting that info... -
From the album: Progress Pics
"Vortekz" Vortex Generator Install How To
TheMission replied to Challenger's topic in Body Kits & Paint
Bump from forever ago... But, I just picked a set of this up and will be throwing them on soon... Love the way they look on the Z and probably couldn't hurt for functionality. Pics will come soon. -
Looks awesome... great call there... might jump on this too.
Old rubber brake line wont come off
TheMission replied to logan1's topic in Brakes, Wheels, Suspension and Chassis
Congrats on the tenacity! I had similar issues and since I was scared I'd break something, I took steps and researched a bit, as if I broke it, I could learn how to fix it! - I still have the bookmark... Brake Line Basics -
Passenger will work as well... I just did this same thing, as I got a used door and it didn't have it. I found a local guy on craigslist with a bunch of Z's who'd part with that little part for nothing really. Should be a little channel 4-5 inches long, with two bolts permanently on it? Hope you can find someone local... hard to find on ebay for sure... (I couldn't)
Yikes, looks like it came out of the 70's... oh wait, it did! Seems to break up the clean roof line of the Z. I don't know if I'd personally keep it and invest in new vinyl to make it perfect, or scrap the look and put the work into removing it and the body work that would surely be needed as a result of it's removal.
On my '72, the front and rear turn signal light powers go through the hazard switch before they hit the turn signal switch, when hazards are turned on, the power goes through the hazard switch to the lights and negates the turn signal switch. When you have problems with your signals and turn the hazard switch on, does that work properly?
