PA240
Everything posted by PA240
  1. Your going to make the rear quarters in autocad? lol good luck
  2. Keep looking there is more info out there. Stony has done the z31 spindle swap. You need the steering knuckle and spindle from a non turbo z31. With some washers the 240z lower ball joint will work. The tie-rod ends will need to be lengthened to work with the new knuckle. You also need hubs from a turbo z31. As far as i know this hub will allow you to use a z32 rotor with the z32 calaper. Im not sure of the proper years that work though. 240z coilovers should fit the non turbo spindles. You will also need some way to adjust caster and camber.
  3. Are you using a 240 steering knuckle or is it from a z31?
  4. Where did you get that fuel door. It looks very clean
  5. Im also happy everything worked out
  6. I think that hose should go to the charge pipe before the plenum. http://www.skylinesaustralia.com/forums/print.html&client=printer&f=8&t=181826
  7. We mounted the battery box.
  8. I wish i knew how to move my build thread to this section.
  9. I thought stance where made in china like the rest of the cheep coilovers.
  10. subframe connectors are a good place to add strength. hear is an example of mine this is the back. its a solid peace up to the front.
  11. is in over his head lol
  12. Im tying to find the best rearend setup for a 72 240. I want to use an r200 diff and cv's. I would also like to use 300zx hubs, e-break and clappers. So far i have only been able to find the techno toy tuning backing plates. They look like they would give me everything i want. Has anyone had any experience with these? Im not to fond of the way the strut ties in. Does anyone else have another solution? thanks neil
  13. I made some ss gastank straps
  14. We got the gas tank mocked up last weekend. we also added this gusset.
  15. The ebay intake is nice, but like people have said quality can be an issue. Like all ebay (china) parts there is no quality control. My freddy intake does not have any casting problems. I just had to open a few holes to get everything to bolt up. Why do you want to go with this intake? are you planing on upgrading the turbo?
  16. to run its best you should tune
  17. Yes i know. The plan was to go 2jz but the deal on this motor was to sweet. Any idea how i can get this moved to the rb forum ?
  18. Philly_G35 that came out nice. Where did you get the replacement quarter ?
  19. I have seen that car on observedtrials.net, are you a member there?
  20. So the top two fittings are oil returns? and the bottom is the pickup? What are the advantages to this setup?
  21. The cf looks sick. How is the quality and fitment? you got them from motorsport right? The harness looks fine, just missing those 2 relays by the ecu
