greenmonster80
Everything posted by greenmonster80
  1. Good news. I got a reply from Redline. Apparently they sent me the wrong mounting kit. What I should have gotten is something involving 1/2 nuts. It should be here soon. As for why did I buy TWM parts from Redline. Price is the main motivation. I was able to get everything $300 cheaper thru Redline. Plus they have been real good about working with me after I first contacted them during my stay in Iraq. I will also be purchasing their engine management system as well.
  2. Finally got my ITB'S from Redline. A warning is due as for the instalation. First off trash the carb style fasteners. They do not fit. The body portion is thicker than the old carbing bodies. There is not enough room between the outer wall and the actual bolt holes to run the washers and nuts to hold it together. Do not fret. Wth the help of my local Lowes I was able to solve this. A bit more fustrating than simply dropping the body on the manifold and tighten 4 nuts but it works with minimal hassle. Start off buying: (12) 5/16 x 18 x 1 1/2 bolts (18) 5/16 flat washers will need to grind a flat surface on one side to fit in the hole pattern. Important to still use I would think. Didn't want the bolt cutting into either the manifold or mounting surface of the throttle body. (6) 5/16 x 18 nylon lock nuts (6) 5/16 lock washers. On the bottom mounting holes I first placed the flat washer on the hole, ground surface towards the body, followed by the lock washer. Then holding the throttle body up off the manifold I squared the flat surface of the head on the bolt against the throttle body. With the flat portion touching the body push the threaded portion into the hole until the head clears the body and is in the cutout portion of the mounting surface. Now with both lower mounting holes filled, lower the body so that it hovers the manifold. Simultaneously thread the bolts into the manifold. Careful to not get ahead of yourself here. Uneven threading results in a bind on the other bolt. Once you get them down, time to give the top mounts a go. Starting from the manifold side install a flat washer onto a bolt and thread it thru. Pass thru the gasket and into the body mounting surface. Once the bolt starts to appear toss a flat washer on it. Again ground surface towards the body so the holes line up. As you raise the bolt up carefully start threading the nut. I went hand tight until I got the other one done. Once all four were in place I went to tightening them down in a staggered pattern. I used lock waashers on the bottoms to help with vibrations loosening the fittenings. On the tops there was no room to use both lock washers and nuts so I went with the nylon nuts to try keeping them tight during vibrations. I wish I could post pics to show what I am talking about. There are pics in my gallery though. Hope this helps someone else out. When I first realized the manufactures way didn't work. (using carb style mounting). I e-mailed them pics with a question of what now? I got no response so I decided to just try something. Should work just fine I imagine. One step closer to unleashing the beast.
  3. Well I worked up a list of everythhing I would need for a TEC 3 unit. Was going to use this to control my distributorless ignition and and engine management for the stroker turbo. Man are they proud of this piece. $3300. On top of what I paid for the ITB's comes out over $5000 for fuel and computer. Got to pull back and rethink my goals. Would like to have some money left over to put else where in the car. Anybody out there get cuts from these guys? Or another system that is as easy to reprogram as mods change? May have to stick to stroker and put off my plans for the turbine.
  4. greenmonster80
    turbo build
    I love the way the turbo sits almost exactly opposite of the altenator. Very balanced and uniform look I think. Can't wait for my build to continue. If only my rust bucket was coming along this good.
  5. Pay no attention to the missing bolts and semi loose fitting. Just checking on my spare motor to see how it all fits. Clearances are close.
  6. Stage two Spec clutch of the 240mm type. Going to be nice behind my turbo stroker and infront of my silvia transmission.
  7. Stock L20 piston comparred to Arias L28 standard bore piston. Noticably larger. Note the ceramic coating on the L28 piece. It is going into a nitros motor. My friends skyline. Motivates me knowing soon I will have my pistons back that are even larger. 89mm. Cannot wait to to it next to the tiny L20 piston.
  8. Brad, While I was in Iraq, I gave a shopping list to the wife and then stayed on her *** until it was finished. She got it from a friend of mine in Okinawa. She was there visiting family while I was gone. I have no need of my old unit. I believe it was a trust piece. It is in the classifieds. Not nearly as cool when compared to the tako-ashi piece. next I want to get it Jet Hot coated.
  9. It probably will not help any but I printed out the instructions that where posted. With the help of the Little Lady I can post an English translation. Give me a couple days to get it done and figure out how to post it here.
  10. Ok, clears it up for me. Thanks. Going to be looking for a way to lower my compression ratio. Moving to a P90 head and possible 2mm metal headgasket.
  11. greenmonster80
    BNR32 GTR
    My last love. I didn't want to sell it but I did. The last I knew she was being sold at Motorex. Anybody see it out.
  12. A pic from later in the night in Panama City. My friend and I both brought our cars. Man was this fun. Everybody else there had some new bling everywhere. Old style rocks..
  13. Had a good time. Took the family along. My car wasn't in good shape at this time. Next time it will be different.
  14. greenmonster80
    busted block
    Heard a tapping noise while racing down the street. Suddenly a LOUD BANG and sudden loss of power. Once I pulled over and opened the hood. Boy was I not happy.
  15. greenmonster80
    1st day
    This is the first day I had the car. Had the replace the mesh style enki's with watanabes quick. Just didn't look right.
  16. Sorry if I came across broken and unclear. I am building a 3.1 with aluminium pistons. I remeber reading somewhere that L28's produce some pretty hot temps. So I figured with everything apart I'd have the pistons ceramic coated. When I pick them up the comment is made that these puppies are good for turbo, nitro or supercharging. I would have never thought of using aluminium pistons in a turbo motor. But if this is sound advice I will be doing it. Looking for someone who has done this or understands more about this than I do. Are aluminium pistons safe in a turbo application?
  17. Finally got my pistons and rods balanced and fitted together. Got the tops of the pistons ceramic coated. I figured cheap insurance if nothing else. My machinists is telling me that these will now be suitable for nitros, turbo or supercharging. I know generally stock turbo pistons or forged aftermarket pistons are recommended here on this site. Is this guy setting me up for a return customer after my engine goes to crap cause I added a turbo set up? Does anyone have experience with running cast aluminium pistons in a turbo motor? To me sounds bad but this place has alot of racing history. Looking for thoughts, comments..
  18. greenmonster80
    gauges
    Someday I need to install these in my dash. Doesn't help me go any faster though.
  19. Suspension is used but will look like new after powdercoating and the camber plates are going to be cool as well. Looking for a nasty street stance.
  20. greenmonster80
    oil cooler
    Nothing crazy just a simple oil cooler with block attachment.
  21. Very rare. Took me a year to find one this nice. Going to look nasty combined with an ITB fuel injection.
  22. greenmonster80
    TD07
    TD07 is going to sit nicely with my new exhaust manifold. Tie it in with a Trust wastegate and we got one hella setup.
  23. Custom built. Picked up while in Japan visiing family.
  24. Picked up a new turbine exhaust manifold with external wastegate flange. it is an equal length runner unit. Much lighter than my last unit and I bet it performs even better as well. Plan to bolt up my TD-07 soon. Plan on posting some pics as soon as I am able to post attachments.
