It's not really that far off topic, as it pertains to manufacturability of Rob's diff mount/subframe.
Manufacturers don't genrerally hold the position of every weld nut/mounting point on the unibody to very rigid specs. This would be very expensive, and it's simply not needed for everything. Things like the suspension pickup points and the headlight mounting system are usually controlled to tight tolerances - the suspension for obvious reasons, and the headlight mounts so that they don't run into certification problems and so the headlights can be aligned quickly at the plant. There are certainly other things that require tight tolerances, but those are the ones that I can remember offhand.
Now, let's look at the diff strap mount - if you look closely, the mounts themslves are a couple of tabs that were welded onto the unibody, possibly by hand (I don't know what the manufacturing processes looked like at Nissan in the 70's). The diff strap will still work just fine if that mount is anywhere within an inch of nominal. This was almost certainly not lost on Nissan's engineers when they designed the unibody, and I doubt seriously that they spent much effort on controlling the positioning of these mount points. It probably doesn't really move around by an inch from car to car, but 10cm (sorry for mixing units) wouldn't surprise me a bit - Rob's observation of the slotted holes in the tabs on the strap mounts indicate that they were not counting on the positioning of the weld nuts with respect to each other in the same tab to be repeatable to better than ~3mm. So, I doubt that they did any better of a job of locating those tabs in three dimensions in the unibody itself.
Now mind you, I don't have any proof of this for these particular mounting holes, and it's possible that the diff strap mount's close proximity to a suspension mounting point (which are generally well controlled) might help mitigate the problem. It would be a good thing to verify on several different cars - just something that I've suspected for a while, now.
