Do you want to keep it stock or do you mind modifying it for tire fitment. I had the same problem with my car. But I was racing it in SCCA B street prepared. I did this for bigger tire fitment. What you can do, if you want to modify it, is buy a stainless steel wheel cover off of a car trailer. You can get them from a farm sales place or even a place like Lowes. You have to cut the cars wheel well along the seam between the two halves and undo the outer wheel well seam (spot welds). After you get it out, you fit (cut to fit) the stainless steel wheel to fit that half of the wheel well. Take your time and weld it in. After that you seam seal every thing both inside and out. Then paint it to seal it and keep it from rusting again. If you want to stay stock, I hope someone can answer that one for you. One other thing you should do is to make sure to put the rim of the stainless fender against the outer fender and seam sealer it to the outer fender, do not weld it. Also a good time to seal the wheel well from rust as the Datsun did not come with any type of this. Good Luck! This is for rear fitment? You didn't say front or rear wheel well.
