As most people are probably aware, cooling a Z is not an easy task.  Stock 240’s ran hot without any modifications, and once you start increasing the horsepower, driving in the desert, and/or adding air conditioning it gets even harder to keep your Z cool.  I’ve been working hard to keep my Z cool, and I think I finally have a solution that keeps my modified LT1 V8 240Z cool even on hot days with the A/C blowing nice cold air.
The solution isn’t just one thing, it’s a combination of things that all work together to get cool air through a radiator that’s as large as possible and then force the hot air out of the engine compartment.  My solution consists of the following:
Radiator Ducting:  I worked on several designs and created several iterations before I created what I feel is the best solution aesthetically and functionally.  It still keeps the same grille opening but ensure that air is routed directly through the radiator starting with a smaller opening and opening up as it approaches the radiator.  Everything is sealed as well to ensure air doesn’t escape.
Radiator:  I’ve gone through three different radiators starting with the JTR radiator, moving onto a 3-row all aluminum model, and then finally a Monster aluminum 4-row.  I used the Champion radiator MC110 which are all aluminum, has 14-16 cooling fans per inch, and incorporates brackets for OEM mounting.
Fan:  Even with ducting most people are going to need to pull in air when running AC or sitting in traffic on a hot day.  I used the dual speed Taurus fan which pulls about 2500 CFM on low speed and 4500 on high.  These fans work great and are fairly cheap and easy to find.
Hot Air Venting:  I noticed that when my car would run hot it would cool off if I kept it running and I opened my hood.  So I figured that I need to find a way to get that hot air out without opening the hood.  Since I already installed gills (fender vents) I decided that I should cut out openings in my inner fenders and install fans to force air out.  These work great for me and made a big difference with my setup.  You may not need the same level of cooling but getting hot air out is important.  You may be able to get away with just using a vented hood or inspection lids or the hideous looking (in my opinion) Datsun Competition Hood Scoop.
