steve260z
steve260z last won the day on January 18
steve260z had the most liked content!
About steve260z
  • Birthday 04/19/1967
  • Gender
    Not Telling
  • Location
    San Antonio, TX
Recent Profile Visitors
steve260z's Achievements
Newbie
  • Dedicated Rare
  • First Post Rare
  • Collaborator Rare
  • Week One Done
  • One Month Later
Recent Badges
  1. Just did a Dyno run. Never mind the Rpms on the results. Used an external tach which wasn't tied into the Dyno. 175 hp and 204 torque. Dyno 3.1L 1-5-2024.pdf
  2. Get this pump. I use it https://www.racetep.com/manufacturer/carbs-and-injection/weber/electric-fuel-pumps.html
  3. What model do you have for sale? Thanks Steve
  4. Here you go. Good site https://www.oocities.org/inlinestroker/index.htm
  5. Replacing the fuel float. Didn't have to drop the tank. Just removed the straps and pulled it down. Not to bad
  6. Look forward to the jet comparisons!
  7. U need to give us the jets...all of them you are using
  8. How does it run now? Also, buy an O2 meter. That is key
  9. For the record, here is my deal which I'm chasing down: Ok..Have a stroker with triple Weber 40s, Datsun distributor, 34 degrees all in, carter low pressure fuel pump, plugs look good, brand new fuel filter, dead headed carbs, old return line vented to atmosphere, Crane ignition module...Think thats most of important parts, just ask for whatever I've neglected to mention. After 10 minutes of driving, when I come to a stop the car will act like its going to die or will die. This occurs about 50% of the time. If this does not occur I can let the car idle in the driveway and it will start acting like its going to die and will eventually within the next 30 minutes. I can then restart in the car with about a 4 or 5 second crank. Now, if its not in this state of just dying I can turn the car off and restart with a 1 or 2 second start...I think the clues lie here in this 4-5 second crank to start. Now, I've but a voltmeter on the battery as the car dies and the meter reads a consistent 14-14.3 volts while running and dying. When the car dies I can still hear the carter fuel pump running. When it dies the O2 meter will drop down to about 10 AFR from the usually 12 at idle. Now, not sure if this richness is caused by the actual problem or just the result of low bouncing idle at the point of dying which would mess with the vacuum signal the carb sees. Obviously I'm freaking stumped. As mentioned above the 4-5 second crank time on restart is interesting. I've been thinking maybe the fuel is getting too hot, pump is crapping out (only 5K miles on it), all kind of esoteric different Weber ideas and many other ideas... And the thread...http://forums.hybridz.org/topic/127405-strange-dying-issuetake-a-shot/
  10. In short I have the same problem. Try replacing your coil. Only $35 bucks. Autozone has them. Also, check all connections for corrosion, as mentioned fuel filter, battery voltage when the car starts acting up.
  11. Basically no. The chain and tensioner need the sprocket on the head to remain tight
