Vivalawham Posted June 21, 2011 Share Posted June 21, 2011 Hello all, I have been trying for weeks (unsuccessfully) to identify the hose pictured below. It comes from the front (I think at/near the water pump?) of the block and curves around the driver's side, then attaches to a nipple on the underside (can't even see it looking from the side). Anyone know what it is? I've been to numerous car parts stores, scanned through both the Black Dragon catalog and the Factory Service Manual and I cannot for the life of me figure out what it is... Quote Link to comment Share on other sites More sharing options...
cgsheen Posted June 21, 2011 Share Posted June 21, 2011 PCV Valve? Quote Link to comment Share on other sites More sharing options...
Vivalawham Posted June 21, 2011 Author Share Posted June 21, 2011 That looks like it! Thanks! Quote Link to comment Share on other sites More sharing options...
Tony D Posted June 22, 2011 Share Posted June 22, 2011 I take it 'the underside' you refer to is 'the underside of the intake manifold plenum'.... In that case, yes, PCV by the looks of it and kind of by the given description. Quote Link to comment Share on other sites More sharing options...
NewZed Posted June 22, 2011 Share Posted June 22, 2011 The hose looks like it's split, or about too. If you plan to run a functioning PCV system you'll need to replace it, otherwise you'll have a vacuum leak that will be very hard to find once things are put back together. Quote Link to comment Share on other sites More sharing options...
