mr280zx Posted July 11, 2011 Share Posted July 11, 2011 i try to fit the center cap to 513 xxr wheels for the front but it wan't fit why?? also i see alot of zee have the same problem just for the front wheels.the tires is 245-45-16 and the wheels is 16x8.5 zero offset.someone told me i have to but spacers about 1/4 or 1/2 is that correct? Quote Link to comment Share on other sites More sharing options...
tehrick88 Posted July 15, 2011 Share Posted July 15, 2011 Yep. You need spacers. That's what I was told by a guy at xxr anyways. Quote Link to comment Share on other sites More sharing options...
Ducer Posted July 15, 2011 Share Posted July 15, 2011 (edited) i try to fit the center cap to 513 xxr wheels for the front but it wan't fit why?? also i see alot of zee have the same problem just for the front wheels.the tires is 245-45-16 and the wheels is 16x8.5 zero offset.someone told me i have to but spacers about 1/4 or 1/2 is that correct? Center cap is fitment/ manufacturing issue I assume. Use a dremel and sandpaper fix. I hope you're not tyring to fit the Z center caps on the XXR wheels!!? I don't think XXR 513 came with 8.5" wide. XXR only makes 16x7 and 16x8. You want to put 16x8.5 in the front? You run 225/35 or 225/45 not 245/45. Spacer = only for clearance of caliper or clearance of the wheel not touching the shocks/springs. depending on the wheel and how it sits, if may ore may not clear your caliper, you use a spacer. How thick? depends on how much the wheel face needs to be away from the caliper. Wheel/tire rubbing against shock/springs, you use spacer to move out. How thick? Depends on offset of wheels, how much you need to go out so it does not hit shock/springs? There is not answer to your question, it all depends on your wheels, the style, the offset. Spacers come in slip on 3mm, 5mmm, 7mm, 8mm, 10mm 15, 20, 25mm, anything after this is "spacer/adapteres" that is bolt on roughly. XXR does not make 8.5" 513's as far as I know. BE MORE SPECIFIC IN YOUR QUESTIONS, and your information may be Wrong. Edited July 15, 2011 by Ducer Quote Link to comment Share on other sites More sharing options...
mr jdm Posted September 18, 2011 Share Posted September 18, 2011 (edited) Center cap is fitment/ manufacturing issue I assume. Use a dremel and sandpaper fix. I stumbled across this post from search results. Use a dremel and sandpaper to fix the center cap not fitting What a classic response from somebody who clearly doesnt have first hand experience at what the issue is. A classic post. Edited September 18, 2011 by mr jdm Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted September 18, 2011 Share Posted September 18, 2011 I have the same wheels, 513 in 16x8. I was also told by the seller that my 225/55's wouldn't fit, which they do. They rub on the rear only slightly on hard bumps. Another brand of 225/55s could fix that. Anyway, he was right about the center cap not fitting. The best solution I have seen is to paint the spindle bolt cover the same color as the wheels. Quote Link to comment Share on other sites More sharing options...
ComicArtist Posted September 18, 2011 Share Posted September 18, 2011 The grease cap sticks out too far on the front for the center cap to fit. You either have to run a spacer to push the wheel out or get different caps. Quote Link to comment Share on other sites More sharing options...
Tony D Posted September 19, 2011 Share Posted September 19, 2011 I stumbled across this post from search results. Use a dremel and sandpaper to fix the center cap not fitting What a classic response from somebody who clearly doesnt have first hand experience at what the issue is. A classic post. It's an M.O. The answer is the XXR's have a 'flush fit' style cap, and this gentleman from Kuwait is having a problem with the center bearing carrier of the hub protruding too far so the 'cap won't fit'... This is why most people don't run the front caps. Your answer is to either find a cap with sufficient depth to accommodate the Z's protruding outer bearing race holding section of the hub, have one made, or run without them. The 'flat cap' that comes with the XXR's won't fit. You could space them to get more depth, but unless you remove the hub and install some longer wheel studs thread engagement with even a 5mm spacer will start getting tenuous. I wish I could give you an answer for 'what cap fits' but I've not measured the XXR's center hole, nor it's relative position to the hub's dust cap (what you need to clear.) Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted September 22, 2011 Share Posted September 22, 2011 Best way to get it to fit is use some black pvc piping and silicone the cap to the pipe. Then just sand/shave it down to fit inside the wheel over the dust cap. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted September 22, 2011 Share Posted September 22, 2011 How would you duplicate the retention in that case? I say just paint your grease caps. Quote Link to comment Share on other sites More sharing options...
