zmainiac Posted August 5, 2011 Share Posted August 5, 2011 Well the z and new dyno are both ready to roll so it should be a fun weekend. Stock block, rebuilt head, mls gaskets, haltech e6k, t67 turbo, 1000 cc injectors, custom satan plenum and exhaust manifold. Should have my built vg35 back by the end of august but this should make some power until then. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted August 5, 2011 Share Posted August 5, 2011 Nice... is it a SS model? Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted August 5, 2011 Share Posted August 5, 2011 What dyno is that? Quote Link to comment Share on other sites More sharing options...
sq_creations Posted August 5, 2011 Share Posted August 5, 2011 So what numbers did you put down? Can we see more pictures of the setup. Quote Link to comment Share on other sites More sharing options...
zmainiac Posted August 9, 2011 Author Share Posted August 9, 2011 Should tune it tomorow. Its a brand new dynocom 5000 eddy brake 2wd dyno. Right now its a stock 87 na block, rebuilt heads, stock cams, spec stage 3 clutch, 1000cc injectors, haltech e6k standalone, tt fuel pump, precision 38 mm wastegate, tial 44 blowoff, vacuum actuated cutout, satans custom plenum, log manifold, fuel rails, t67 turbo, etc. I have a vg33 at the machine shop being bored to a vg35 with brc forged pistons, scat rods, jim wolf s2 cams, adj. Cam gears, etc but they are taking their time so i thew this motor in for now. Going for the fastest, most hp stock block z31 which is 480whp and 11.6 Quote Link to comment Share on other sites More sharing options...
zmainiac Posted August 9, 2011 Author Share Posted August 9, 2011 Pic of it coming together. Quote Link to comment Share on other sites More sharing options...
zmainiac Posted August 10, 2011 Author Share Posted August 10, 2011 Its not a shiro Well, got a baseline run in today. It made 317/348 at 15 psi but my intake manifold broke and i let off at around 6k as it went pig rich. The divider in the manifold broke off inside and was rattling around. Other than taking a couple of minutes to figure out where the rattling was coming from everything is ok. Should have better numbers by next week. Not going to post the graph as it is rough at the end. Quote Link to comment Share on other sites More sharing options...
zmainiac Posted August 17, 2011 Author Share Posted August 17, 2011 Here is a little video teaser. Not done tuning it yet but it is coming along nicely. Took it out tonight to get more gas and it felt good. Yes i am going to be getting a steering wheel soon in case you are wondering. Quote Link to comment Share on other sites More sharing options...
zmainiac Posted August 17, 2011 Author Share Posted August 17, 2011 Here's the youtube link. Quote Link to comment Share on other sites More sharing options...
zmainiac Posted August 23, 2011 Author Share Posted August 23, 2011 made some more adjustments and did a couple of pulls with load. This is still at 15psi. Can't wait for a little race gas and 20 psi. Going to the track tomorrow to see what it will do. Quote Link to comment Share on other sites More sharing options...
1985Z31Turbo Posted September 6, 2011 Share Posted September 6, 2011 (edited) Awesome! Please keep the posts coming! 1000cc injectors seem really large. I thought 500cc was good up to like 700hp or so? But, first to admit I'm not sure. Edited September 6, 2011 by 1985Z31Turbo Quote Link to comment Share on other sites More sharing options...
260DET Posted September 8, 2011 Share Posted September 8, 2011 (edited) made some more adjustments and did a couple of pulls with load. This is still at 15psi. Can't wait for a little race gas and 20 psi. Going to the track tomorrow to see what it will do. There is something wrong with that dyno sheet, power should not drop off so drastically from 5700rpm on. Back to 100hp at 6500 is ridiculous. Almost 250 at 4000 is good. Edited September 8, 2011 by 260DET Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted September 8, 2011 Share Posted September 8, 2011 If he lets off it's not wrong. Looks like a slow lift. Quote Link to comment Share on other sites More sharing options...
Z31Turbo Posted September 9, 2011 Share Posted September 9, 2011 So how much can these stock bottom ends deal with ? 400? 500? Quote Link to comment Share on other sites More sharing options...
260DET Posted September 9, 2011 Share Posted September 9, 2011 (edited) If he lets off it's not wrong. Looks like a slow lift. Yeh that's probably what it is but why back off at ~5700rpm, with those specs run the sucker up to 7k. It should make power to 6500 at least. If not look for restrictions. *** dyno operator. Edited September 9, 2011 by 260DET Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted September 9, 2011 Share Posted September 9, 2011 Yeh that's probably what it is but why back off at ~5700rpm, with those specs run the sucker up to 7k. It should make power to 6500 at least. If not look for restrictions. *** dyno operator. I, for one, dislike revving my VG past 5,500 RPM or so. They aren't really high-revving motors... Quote Link to comment Share on other sites More sharing options...
zmainiac Posted September 13, 2011 Author Share Posted September 13, 2011 Well, a couple of things happened there. I did let off fairly early. Redline is set low because it is a stock na block, heads, cams so i want it to last a little bit. I did have some wiring gremlins that i took care of since and there are new ign wires on there now. Also there was a shoty circuit board on the dyno which is getting replaced tomorow. It still does break up top so it may be one of the coils going bad. I have a vg33 bored to a 3.5 with forged brc pistons, scat rods, s2 cams, rebuilt heads, mueller twin disc at the machine shop ready to go when i say so but i want to get the highest hp stock block and fastest 1/4 mile before i throw that beast in. I think that it is 450ish and 11.6. Going to do a 100 octane 20psi tune very soon to beat it. Quote Link to comment Share on other sites More sharing options...
zmainiac Posted September 14, 2011 Author Share Posted September 14, 2011 Two coils are on there way out so ordered them from haltech and they should be here by the weekend. Quote Link to comment Share on other sites More sharing options...
260DET Posted September 15, 2011 Share Posted September 15, 2011 Well, a couple of things happened there. I did let off fairly early. Redline is set low because it is a stock na block, heads, cams so i want it to last a little bit. I did have some wiring gremlins that i took care of since and there are new ign wires on there now. Also there was a shoty circuit board on the dyno which is getting replaced tomorow. It still does break up top so it may be one of the coils going bad. I have a vg33 bored to a 3.5 with forged brc pistons, scat rods, s2 cams, rebuilt heads, mueller twin disc at the machine shop ready to go when i say so but i want to get the highest hp stock block and fastest 1/4 mile before i throw that beast in. I think that it is 450ish and 11.6. Going to do a 100 octane 20psi tune very soon to beat it. Your VG35 is similar spec to my VG34 except mine has oversized valves, a forged crank and improved lube system too. With a GTX3582R it should make power to 7000rpm. Quote Link to comment Share on other sites More sharing options...
zmainiac Posted September 21, 2011 Author Share Posted September 21, 2011 i believe that a t67 is a little bigger than a gt35r. i think that with the 3.5 setup i want to run twin billet 6262's since this season is almost over. we will see. this turbo isn't even in its effiency range at 15 psi. Quote Link to comment Share on other sites More sharing options...
