Changing gears between R200s
Ejkej
So just to be certain: Can I swap gears from R200 shortnose into R200 longnose to achieve the gear ratio I am looking for (3,9; 4,11)?
R200 shortnose are sometimes available here, since they were installed in quite common in Europe 200sx.
Thanks!
Edited by Ejkej
you can swap in the center though with some modification. At least I think that's what this is saying. But yeah the pinion and crown are a matched pair.
http://www.zclub.org...t=102&test=test
The carrier doesn't give you the gear ratio. His question was can he swap the gears from shortnose to longnose to change the ratio, and the answer is no.
Edited by JMortensen
