BLOZ UP Posted November 7, 2011 Share Posted November 7, 2011 On 10/26/2011 at 2:08 PM, Chemicalblue said: So MS cant read the stock Nissan trigger wheel? Seems it would be much easier to change the software than reinvent the wheel. I see what you did there. Matt, what are the chances of you also making a distributor cap as well? Although, I've been thinking about adding a "spinner" to replace the rotor. That is, "my rotor keeps spinning every time my engine stops". It'd be pretty fly, right? Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted November 7, 2011 Author Share Posted November 7, 2011 On 11/7/2011 at 7:18 PM, BLOZ UP said: I see what you did there. Matt, what are the chances of you also making a distributor cap as well? Although, I've been thinking about adding a "spinner" to replace the rotor. That is, "my rotor keeps spinning every time my engine stops". It'd be pretty fly, right? Blanked-off distributor caps would be considerably more expensive - they'd probably have to be billet aluminum unless there's a LOT more demand for them than I expect. We'd have to see how this one sells and if we have several people asking, we might set up a group buy. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted November 7, 2011 Share Posted November 7, 2011 Just wondering. Not a huge deal. The normal cap works just as well. Any ETA on the wheels? Quote Link to comment Share on other sites More sharing options...
FricFrac Posted November 9, 2011 Share Posted November 9, 2011 On 11/7/2011 at 7:18 PM, BLOZ UP said: I see what you did there. Matt, what are the chances of you also making a distributor cap as well? Although, I've been thinking about adding a "spinner" to replace the rotor. That is, "my rotor keeps spinning every time my engine stops". It'd be pretty fly, right? Lol - I got it So is there an updated ETA on the wheels? I was thinking finding some stainless shim stock and sweet talking the guy at the water jet if it's going to be a while.... Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted November 10, 2011 Author Share Posted November 10, 2011 It's not likely to be long now - I'll keep you posted. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted November 10, 2011 Share Posted November 10, 2011 I am already setup with EDIS but if this was available back then, I would have used it. I don't see any reason NOT to make these. Good idea DIY. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted November 10, 2011 Share Posted November 10, 2011 Now I need 6 of the IGN-1 coils... Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted November 14, 2011 Author Share Posted November 14, 2011 They're officially on order now - watch for them early December! 1 Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted November 14, 2011 Share Posted November 14, 2011 I was so hoping your latest post was a "I have X ready to go, first come first serve", and I was going to WIN. Quote Link to comment Share on other sites More sharing options...
letitsnow Posted November 14, 2011 Share Posted November 14, 2011 (edited) Glad I have 7 LS2/truck coils. Guess I need to devise a decent looking bracket now. Edited November 14, 2011 by letitsnow Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted November 14, 2011 Share Posted November 14, 2011 (edited) I've got 3 or 4 OE Z31 coils and ignitors, just need to swing by the Z yard and get a couple more. I think they might be overkill, like 10 pounds in coils. And all the ignitors have heat sinks. Win! Edited November 14, 2011 by BLOZ UP Quote Link to comment Share on other sites More sharing options...
Swervey McZCar Posted November 15, 2011 Share Posted November 15, 2011 I'm in for sure. L28ET Running MS-II with EDIS is the goal. I'm tired of reading about trigger wheels, damper failure and $400 solutions. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted November 15, 2011 Author Share Posted November 15, 2011 Our trigger wheel manufacturer had been hit with a pretty big order; sorry about the delay. On 11/15/2011 at 4:14 AM, Swervey McZCar said: I'm in for sure. L28ET Running MS-II with EDIS is the goal. I'm tired of reading about trigger wheels, damper failure and $400 solutions. These wheels will not work with a EDIS module. They will, however, let the MS control EDIS coils directly. Quote Link to comment Share on other sites More sharing options...
letitsnow Posted November 15, 2011 Share Posted November 15, 2011 I feel like a lot of people don't quite get that MS controlling coils directly actually has more features and is less complicated than EDIS. The only thing it lacks is a limp mode, but limp mode is only active if the ECU isn't sending a signal to the EDIS box, which would be a wiring or config issue. If the sensor goes, you'd still be SOL. On 11/14/2011 at 10:49 PM, BLOZ UP said: I've got 3 or 4 OE Z31 coils and ignitors, just need to swing by the Z yard and get a couple more. I think they might be overkill, like 10 pounds in coils. And all the ignitors have heat sinks. Win! Maybe just a little. Quote Link to comment Share on other sites More sharing options...
Swervey McZCar Posted November 16, 2011 Share Posted November 16, 2011 On 11/15/2011 at 6:32 PM, letitsnow said: I feel like a lot of people don't quite get that MS controlling coils directly actually has more features and is less complicated than EDIS. The only thing it lacks is a limp mode, but limp mode is only active if the ECU isn't sending a signal to the EDIS box, which would be a wiring or config issue. If the sensor goes, you'd still be SOL. I was planning on MS-II (v3.oPCB) sending the advance only to the EDIS module. So I still need the EDIS 36-1 Trigger wheel? I guess I thought this wheel would create the same waveform. The stock Ignition system doesn't have a limp mode so that wouldn't really be an issue. I'm willing to let MS control the coilpack directly if it will work with my MSII Unit. If not, I wonder if I could write some code to output a modified waveform to the EDIS via some unused wire in MS. If that were doable somebody would have done that with the stock distributor by now, right? Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted November 16, 2011 Author Share Posted November 16, 2011 (edited) If you must have an EDIS module, you must have a 36-1 trigger wheel. I don't really see any advantage to trying to fake a 36-1 signal - the code and wiring is more complex, and there's more hardware but no clear benefit. My preference is direct coil control; I'd only use an EDIS module if I were doing a plug and play install on a car already equipped with a working EDIS system. Edited November 16, 2011 by Matt Cramer Quote Link to comment Share on other sites More sharing options...
letitsnow Posted November 16, 2011 Share Posted November 16, 2011 (edited) I agree with matt, you can try to fake a signal, but all you'd be doing is adding inaccuracies into the timing algorithms, adding complexities into the wiring and code, all to lose the ability to use spark cut rev limiting and have more hardware in the engine bay. You can run the proposed wheel signal straight to the MS, then have the MS fire the coils directly. The EDIS box can go in the trash or on ebay or something, it's not needed. All you have to do is tell the MS what kind of wheel you've got and which coils are hooked to which outputs and you're done. Edited November 16, 2011 by letitsnow Quote Link to comment Share on other sites More sharing options...
Swervey McZCar Posted November 16, 2011 Share Posted November 16, 2011 Sounds great. I see now the MSII Extra has support for direct control of COP and Wasted Spark. B&G didn't mention either in the standard MSII documentation, but talked about a triggering a single coil or using EDIS for WS. This changes everything. Now I have to research this implementation since my PCB was built targeting EDIS. Quote Link to comment Share on other sites More sharing options...
letitsnow Posted November 16, 2011 Share Posted November 16, 2011 I think the MS2e documentation could really use an update, the current firmware has a ton of features that I can't find any information on. You can find some by searching the forums, but that can take a ton of time. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted November 16, 2011 Share Posted November 16, 2011 I just picked up 6 Z32 COPs, but I need that stupid ignition box. Quote Link to comment Share on other sites More sharing options...
