LuisZ31 0 Posted November 5, 2011 I have a question: vg30dett pistons can be installed in a vg30et engine??? Quote Share this post Link to post Share on other sites
s30red240z 0 Posted November 6, 2011 (edited) Yes, dett piston+rod fits on ET. Edited November 6, 2011 by s30red240z Quote Share this post Link to post Share on other sites
260DET 31 Posted November 6, 2011 The valve cutouts are different, two valve, four valve. Quote Share this post Link to post Share on other sites
LuisZ31 0 Posted November 7, 2011 but if I install these in the ET do not hit the valves? Quote Share this post Link to post Share on other sites
s30red240z 0 Posted November 8, 2011 I don't really sure about kissing valves, but a friend of mine, he was running DETT pistons on VG30ET, with out any bad issue. Quote Share this post Link to post Share on other sites
Gregmatic 10 Posted November 23, 2011 No valve interference, will work fine Quote Share this post Link to post Share on other sites
VG30TT-X 10 Posted January 3, 2012 Pretty sure the small end of the rod has to be enlarged and bushed. The wrist pin for the DE/DETT is larger than the E/ET. Quote Share this post Link to post Share on other sites
LuisZ31 0 Posted May 27, 2012 Thaks boys, then I will buy one of these I saw that are less expensive and would work well Quote Share this post Link to post Share on other sites
LuisZ31 0 Posted May 27, 2012 I must also get a crank right? Quote Share this post Link to post Share on other sites
LuisZ31 0 Posted May 27, 2012 I must also get a *connecting rods right? Quote Share this post Link to post Share on other sites
s30red240z 0 Posted May 29, 2012 I must also get a *connecting rods right? Yes because the pin diameter is different! Quote Share this post Link to post Share on other sites
BLOZ UP 19 Posted May 29, 2012 You can use the piston and rods from a DE on the E, but not just the pistons or just the rods. Quote Share this post Link to post Share on other sites
