DeLorean Posted November 6, 2011 Share Posted November 6, 2011 I installed a new fuse box today, but in the course of doing so uncovered some new electrical gremlins. My park lights no longer work, nor do my console lights. However, when the brake pedal is pushed, the console light comes on very faintly. I have a set of JDM tails that I wanted to install, seems like now is the time since I'm digging through the wiring. The first problem is the connections on the tails do not match the harness at all. I have photos below that show the issue: This is the connection on the main harness: This is the connection on the tails: If I get a connector for the main harness to match the tails, I should be in business. But my confusion really lies in the brake pedal turning on the console lights (faintly). Also, does anyone know the wire color codes for brakes and for turn signals? Thanks Quote Link to comment Share on other sites More sharing options...
Miles Posted November 6, 2011 Share Posted November 6, 2011 See if this helps. 72_240z_wiring.pdf Quote Link to comment Share on other sites More sharing options...
DeLorean Posted November 10, 2011 Author Share Posted November 10, 2011 It does help, I just have a hard time reading schematics. Quote Link to comment Share on other sites More sharing options...
NewZed Posted November 10, 2011 Share Posted November 10, 2011 Your best plan of attack is to fix the fuse box first, then work on the tail lights. You must have created some new gremlins, not uncovered them. Quote Link to comment Share on other sites More sharing options...
Miles Posted November 10, 2011 Share Posted November 10, 2011 (edited) I installed a new fuse box today, but in the course of doing so uncovered some new electrical gremlins. My park lights no longer work, nor do my console lights. However, when the brake pedal is pushed, the console light comes on very faintly. I have a set of JDM tails that I wanted to install, seems like now is the time since I'm digging through the wiring. The first problem is the connections on the tails do not match the harness at all. I have photos below that show the issue: This is the connection on the main harness: This is the connection on the tails: If I get a connector for the main harness to match the tails, I should be in business. But my confusion really lies in the brake pedal turning on the console lights (faintly). Also, does anyone know the wire color codes for brakes and for turn signals? Thanks What do you mean by console l light? Instrument lights? Brake warning light? Edited November 10, 2011 by Miles Quote Link to comment Share on other sites More sharing options...
