Need s130 r200
akumazedex
I need a s130 r200 diff for an na. That would be for the companion flange axles. Broke mine at the track yesterday so need one ASAP. Lmk what you guys have. Located in sf bay area. Local would be awesome.
What's the difference between an S-30 r-200 and an S-130 r-200 rear diff.? aren't the splines the same ? thanks.
Fair enough, my mistake. Good luck with it.
Edit - my mistake was in not defining early and late well enough. For anyone wondering, the 82 ZX came with CVs or u-joints as did the 83, using FSM specs. So 79 - 81 is all u-joint half-shafts for the R200, 82 and 83 can be either Cv or u-joint. For the record.
Edited by NewZed
Actually, in #6, he said he needs an R200 with companion flanges for half shafts. The only way to get the flanges for the half-shafts on the R200 is to have the stub axles. So he must mean that he wants an R200 with the stub axles.
