Lunch time pie cut project
Kinked_Chrome
I started working at a place where we take hour lunch breaks, a luxury I never had before, and I started getting bored. I also get to use all the machines basically whenever I want. I was looking to work on my metal forming and aluminum welding skills and I'm a little sick of the of the rubber intake elbow on my LT1 so I decided to build a pie cut style one. I started out with a little help from solidworks.
Then I ended up with these.
And formed and welded it into this
Not quite sure what type of finish I want to put on it yet. It will likely just get powdercoated.
yeah, the welds on them really stink. The material I used was .063" 5052 Al. Made it really easy to form, but rather difficult to weld. I think that I will sand all the welds down and run a new nice bead around so I can keep the pie cut look. If I had to do it all over, I would use .090" and make it out of five sections instead of eight.
  • 4 weeks later...
That is awesome. So how did you get from design to paper to aluminium?
Does the design software create a print and you cut out the shapes?
Is the software freely available?
I'd love to learn how to do this. :)
heh, solidworks is a multi-thousand-dollar-a-seat program. I wish it was free...however Solidedge has old versions available with no fee...just never ever open your project in a new version if you don't want to buy the new 19,000$ version.
I'm sure it was done with a CNC plasma, waterjet, or laser. I vote waterjet.
  On 3/1/2012 at 4:06 PM, GOTHALOSISM said:
What would you charge for something like that?
No idea. This project took me about 4 lunches. So whatever that works out to. $100 or so.
I drafted the entire thing in Solidworks, and then the software will make a flat pattern for me.
Unfortunately the software is not freely available. However if your a college student or know a college student you can get a year subscription for ~$140. instead of $10k-$15k
You sir are correct. It was cut on a maxiem waterjet
