PMC raceengines Posted September 24, 2012 Share Posted September 24, 2012 For the crasy people that like the Lka conversion 50mm itbs hi low inj Quote Link to comment Share on other sites More sharing options...
stony Posted September 24, 2012 Share Posted September 24, 2012 That looks cool and pricey ;> Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted September 24, 2012 Author Share Posted September 24, 2012 (edited) Yes not cheep to make but works so well the L 2.3 made 300hp at 7500 ,, and we are making a L28 manifold as well,so the stroker gets some good air lol Edited September 24, 2012 by PMC raceengines Quote Link to comment Share on other sites More sharing options...
Super X Posted September 25, 2012 Share Posted September 25, 2012 Those are pretty nice and compact! Any thoughts/plans on doing a set for the sr20ve head? I'd be interested if you can make a set of 52mm-55mm for them. Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted September 26, 2012 Author Share Posted September 26, 2012 We do have them for that head and the 50mm itb flow more than the head will and there is no power to be had from the bigger bore , infact we tried some when we made this set and lost so much torque under 6500rpm , we found the 48mm set would make the same hp in 2L form as the 50mm up to 8500, and made more than the 55mm set as well . the 50mm set made power to 10000rpm in the LKA 2L . pmc Quote Link to comment Share on other sites More sharing options...
Super X Posted September 26, 2012 Share Posted September 26, 2012 You have done testing on a VVL? That's great news! I'd be very interested in seeing any pictures you have of the manifold and tb's. 48/50mm might be suitable on a 2.0 but i'm inquiring for a 92x92 engine, with a head that flows in the low 400@.550' on IN, using a 324/12.5mm IN cam and 9.5-10k rev limit. Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted September 27, 2012 Author Share Posted September 27, 2012 So is that 400hp @ 550 of 400cfm @ A 2.2 would have to make 180hp per L to use that much air a sb2 nascar head flows 400cfm at 700 and if you could get a 2.2 to use that head it would make 450hp NA thats that better than any F1 race car they need 17000rpm to make that VE a nascar makes 130hp per L Quote Link to comment Share on other sites More sharing options...
josh817 Posted September 27, 2012 Share Posted September 27, 2012 Hmmmm You gave me an idea. It looks like that setup is able to use those stock type filters. The ones that are like a big oval ring of filter material sandwiched between two plates. I've been pondering on how or if I want a filter system for my project. This looks like it could be a solution if you aren't too worried about the stand off injectors not sealing *perfectly* in the plate. Unless of course you use an oring or something to solve that. I like! With the fuel rail/injector hold down plate supports, I didn't know how to handle making a filter with all this crap coming through on the backside. Which reminds me; how do the airhorns seal on the back plate of the filter assembly? Do you use another oring? This was precisely what I meant by "all this crap coming through the backside". I'm trying to think of a solution to keeping the airbox (for lack of better words) sealed, without having make the airhorns a permanent fixture to the rear plate. Lastly, I think I asked you this before, but did you find an optimum height of your stand off injectors; distance from the face of the airhorn to the tip of the injector? Quote Link to comment Share on other sites More sharing options...
Super X Posted September 27, 2012 Share Posted September 27, 2012 (edited) On 9/27/2012 at 7:16 AM, PMC raceengines said: So is that 400hp @ 550 of 400cfm @ A 2.2 would have to make 180hp per L to use that much air a sb2 nascar head flows 400cfm at 700 and if you could get a 2.2 to use that head it would make 450hp NA thats that better than any F1 race car they need 17000rpm to make that VE a nascar makes 130hp per L cfm. It's is a streath but an obtainable one. Majority of the guys with port work on this head get around 330-370cfm's and some getting even more. I haven't had mine flowed yet but i'm hoping it will be on the higher end of the scale Here's one from back in 2008 with oversized valves and extensive port work and reshaping. There have been guys who are right at 300whp(380bhp) on the 92x92 setup. Edited September 27, 2012 by Super X Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted September 28, 2012 Author Share Posted September 28, 2012 MMMM 172 hp per L lol better than a 410 sprint car engine and better than any engine in the world NA with that rpm . if that was for real that 410 sprint engine would make 1191 hp the best one in the world makes 850 realy Quote Link to comment Share on other sites More sharing options...
Gollum Posted October 4, 2012 Share Posted October 4, 2012 All the more reason to not use flow benches as a rule, but just another tool. Comparing what one person gets from X head on one flow bench should never be compared to another flow bench. Oh, and I'm sure pmc knows this, but flow numbers are almost meaningless unless you have port volume data. Just because you increase flow a ton doesn't necessarily mean you'll make a ton more power. I've met plenty of notice porters that built their own shade tree flow bench and chased down what "flowed best" in their port work, just to find out they LOST power... Open up the ports too much and you'll kill velocity. Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted October 5, 2012 Author Share Posted October 5, 2012 Just on that subject , the last 5 engines i have built made within 2 hp off the airflow numbers off our bench , there a great tool if you use them right and dont cheat, and you must use the bore size that you have on the bench . Quote Link to comment Share on other sites More sharing options...
Super X Posted October 8, 2012 Share Posted October 8, 2012 On 9/28/2012 at 12:13 AM, PMC raceengines said: MMMM 172 hp per L lol better than a 410 sprint car engine and better than any engine in the world NA with that rpm . if that was for real that 410 sprint engine would make 1191 hp the best one in the world makes 850 realy PMC, A 92x92 4cyl is 2.4_L not 2.2L so it's more like 158hp per L. I don't want to get into the whole comparison discussion, but the numbers are very obtainable. There are a half a dozen of 92x92 n/a VE’s making well over 280whp and a few already into 300whp range, with room to grown. I'll PM you to get info on the throttles that you have tested. On 10/4/2012 at 1:20 AM, Gollum said: All the more reason to not use flow benches as a rule, but just another tool. Comparing what one person gets from X head on one flow bench should never be compared to another flow bench. Data and formulas are all theory until proven. A 2200lb car that runs 11.5@116mph is all the proof I need that it's making the power. Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted October 9, 2012 Author Share Posted October 9, 2012 Yes sorry 2447cc , that a big bore kit , good luck with it all ,, Quote Link to comment Share on other sites More sharing options...
ZIPPY Posted October 17, 2012 Share Posted October 17, 2012 On 9/24/2012 at 11:30 AM, PMC raceengines said: For the crasy people that like the Lka conversion 50mm itbs hi low inj Very nice... Did you make the actual throttle bodies themselves or are they a premade unit that you fabricated the rest of the manifold around? Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted October 17, 2012 Author Share Posted October 17, 2012 The 50mm throtal comes from EFI hardware and we fab the rest off the parts Quote Link to comment Share on other sites More sharing options...
redzedturbo Posted November 13, 2012 Share Posted November 13, 2012 Hey for anyone running a u67 l4 i found exhaust flanges cheap... http://www.weir-tech.com/datsun/ Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted December 28, 2012 Author Share Posted December 28, 2012 Quote Link to comment Share on other sites More sharing options...
Z Greek Posted January 4, 2013 Share Posted January 4, 2013 On 12/28/2012 at 8:18 AM, PMC raceengines said: [attachment=46505:PC270254.JPG In the build this L2 Lka will be on the dyno soon in the new year with a vidio so you can see the manifold in action . peter, If I lived in Australia, I'd voulanteer to work for you for free. You build the coolest stuff! Quote Link to comment Share on other sites More sharing options...
