tom_mcmullen06 Posted September 29, 2012 Share Posted September 29, 2012 Im going to be getting a 280z and I cant seem to find a stoker kit for the motor. I know they make em. I went to an online site its called thezstore or something like that and they no longer carry one. Any Ideas? Quote Link to comment Share on other sites More sharing options...
daddydonuts Posted September 29, 2012 Share Posted September 29, 2012 You can scavage for parts or open your wallet at zccjdm.com Quote Link to comment Share on other sites More sharing options...
s30zgt Posted September 29, 2012 Share Posted September 29, 2012 http://www.kameariusa.com/ Quote Link to comment Share on other sites More sharing options...
dexter72 Posted September 29, 2012 Share Posted September 29, 2012 SInce you said you were new to Z's, I would figure out what kind of setup you want for the engine. Turbo, Carbs, Stock Efi, or Aftermarket Efi. You have a lot of research to do so take your time. Read a lot and save a lot of links on your computer. Welcome to the Site. Quote Link to comment Share on other sites More sharing options...
devil280Z Posted September 30, 2012 Share Posted September 30, 2012 Also take a look a rebello. Quote Link to comment Share on other sites More sharing options...
tom_mcmullen06 Posted September 30, 2012 Author Share Posted September 30, 2012 rebello? so far ive decided im not doing an engine swap.ill keep the 2.8 the one i found im saving up for is a 78 which I think is fuel injected/tbi. I want to do a stroker kit but that would require bigger injectors and more fuel pressure am I correct? Im going to stay Naturally aspirated. Im going to do some upgraded things like rear disc conversion, aluminum radiator with dual electric fans, Mild bodykit a small spoiler the headlight covers and some decent wheels. Nothing too crazy lol 1 Quote Link to comment Share on other sites More sharing options...
daddydonuts Posted September 30, 2012 Share Posted September 30, 2012 rebello? so far ive decided im not doing an engine swap.ill keep the 2.8 the one i found im saving up for is a 78 which I think is fuel injected/tbi. I want to do a stroker kit but that would require bigger injectors and more fuel pressure am I correct? Im going to stay Naturally aspirated. Im going to do some upgraded things like rear disc conversion, aluminum radiator with dual electric fans, Mild bodykit a small spoiler the headlight covers and some decent wheels. Nothing too crazy lol Good choice, get all the major components "refreshened" and upgraded first ie. brakes, body kits, suspension etc..., faster engines /more HP need all that done first anyway. Quote Link to comment Share on other sites More sharing options...
tom_mcmullen06 Posted October 1, 2012 Author Share Posted October 1, 2012 I agree Power doesnt do a bit of good without being able to control it or stop it. Quote Link to comment Share on other sites More sharing options...
Gollum Posted October 3, 2012 Share Posted October 3, 2012 rebello? Rebello http://www.rebelloracing.com/nissan1.htm If you're going to stay fuel injected, you're shooting yourself in the foot to keep the stock EFI. It's going to be like pulling an angry tiger's tooth out when it comes to improving power over stock. This is all covered elsewhere, but you won't make enough extra power to be worth the cost doing JUST a stroker. You'll want an upgraded cam, you'll want some BASIC head work done at the LEAST, you'll probably want a better intake, and to follow all that up with the OEM EFI would just be miserable. The other question that should be asked though, is why spend $4k building a 250hp stroker, when you can spend $2k or less on a 2.8 with a modded head? Of course you're free to do what you'd like, I just haven't seen too many people pull off budget stroker motors, especially if they're looking for a "kit" to make it easy. And if you're not really concerned about the money, I just don't exactly see it as a fruitful return when buying said "kits". Quote Link to comment Share on other sites More sharing options...
Tony D Posted October 3, 2012 Share Posted October 3, 2012 If you do a 3.0, the way to go is find the EFI out of a BMW 3-liter Six of comparable vintage, and hook the ecu/pin the harness & BMW AFM correctly and run that. FAR better results than trying to make the Datsun ECU work with the bigger engine, and a hotter cam... Quote Link to comment Share on other sites More sharing options...
