compression test, how-to?
I haven't done a compression test on these cars (or anything carbureted), is there anything particular about the procedure beyond removing all the plugs and testing on a warm engine with throttle wide open? Do you disconnect the ignition source as well? How about fuel?
I did a search and lots of threads come up, but (seemingly) none regarding the testing procedure.
Thanks in advance
Edited by thedarkie
The procedure for EFI & Carbs is identical: throttle is blocked at WOT.
There is no vacuum in the manifold when cranking in either system.
It's the premise of "flood clearing" a carbureted engine holding it at WOT: no vacuum to suck any more fuel out of the carb while cranking to dry out the cylinders and hopefully fire once the mix is correct.
On an EFI engine, disabling the pump keeps fuel from being injected, while the carb being held wide open stops fuel from being introduced to the engine, on an EFI ENgine it will still be injected. It doesn't need vacuum to atomism fuel, high pressure from the fuel system and injector spray pattern take care of that.
Edited by Tony D
