mattd428 Posted June 29, 2013 Share Posted June 29, 2013 Hit the dyno this morning. 291hp 304hp 5.3 with a small cam tune but just a safe tune so theres more power to be had and was running open headers through the hood vents so thats robbing a little bit also. Wfritts I dont know how you ran open headers for so long way way way way way way too loud. Rear end is holding up really good just need the right springs way too stiff right now. Heres a video does 141 in 4th gear with the stock 3:08s. https://www.youtube.com/watch?v=ec9BiMwSESU Quote Link to comment Share on other sites More sharing options...
Domzs Posted June 29, 2013 Share Posted June 29, 2013 Awesome and loud . Quote Link to comment Share on other sites More sharing options...
240z72 Posted June 30, 2013 Share Posted June 30, 2013 Sweet...What spring weights you running? Quote Link to comment Share on other sites More sharing options...
mattd428 Posted June 30, 2013 Author Share Posted June 30, 2013 180# Quote Link to comment Share on other sites More sharing options...
wfritts911 Posted June 30, 2013 Share Posted June 30, 2013 Hahaha. First off I'm young and have a very high tolerance level. Second, I'm on the stock cam. Cams make these motors WAY louder. Also it doesn't appear your pipes actually come through the hood vents. My pipes came past the hood a 2-3 inches, which might have helped on the noise. Another thing, if you think those are loud, wait until you run straight longtube headers that dump below the floor. When I built my long tubes, the stacks didn't even come close to the noise level of the actual headers. I drove it around straight headers for 2 weeks and had to go back home to build exhaust. Between the noise and the fumes, I couldn't handle it lol. Power seems low to me, but maybe its not. Feel like a cammed 5.3 should be higher than that. Need to get some track times. And you desperately need to swap those 3.08s out for a real gear. I'm probably going to go 3.73 or 3.90 in mine. Car looks good though! Go drive it! -Will Quote Link to comment Share on other sites More sharing options...
mattd428 Posted June 30, 2013 Author Share Posted June 30, 2013 Nope they dont come out of the hood but damn its loud. I ran glass packs dumped under the seats awhile back and wasnt as bad but still annoying. Power isnt bad for a 5.3 the cam is very small 510/510 236/236 114 lsa but its not tuned for it and the lack of exhaust hurts quite a bit. Track times are coming having no fear hopefully this time it wont hop across the track in every gear. The 3.08s suck so badly its not even funny it did 141 mph on the dyno in 4th at around 5800 rpm will spin 6200 if i let it. Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted July 1, 2013 Share Posted July 1, 2013 Mustang dyno? You have a graph? Quote Link to comment Share on other sites More sharing options...
mattd428 Posted July 1, 2013 Author Share Posted July 1, 2013 Not sure what dyno i have a graph ill upload it when i get home tonight. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted July 1, 2013 Share Posted July 1, 2013 (edited) On 6/30/2013 at 10:42 PM, wfritts911 said: Hahaha. First off I'm young and have a very high tolerance level. It doesn't take much to damage your hearing, and it doesn't come back... Power does seem a bit low, hopefully there's an A/F ratio on the graph, that'll splain a lot I'm betting. Edited July 1, 2013 by BLOZ UP Quote Link to comment Share on other sites More sharing options...
gtslo88 Posted July 1, 2013 Share Posted July 1, 2013 If its a Dyno-Dynamics or Mustang, those numbers probably arent too far off. Dyno numbers dont mean a whole lot though. Are you still running the 5.3 intake manifold? They pick up quite a bit with an LS6 intake which can be found pretty inexpensively. Quote Link to comment Share on other sites More sharing options...
mattd428 Posted July 2, 2013 Author Share Posted July 2, 2013 Has an ls1 egr intake nothing special. Air fuel has never been checked and has never been fully tuned. There are no o2 sensors it has a speed density tune. The plan is ls2 intake ported heads and a 76 mm turbo around 11 psi. Thats the reason for no o2 sensors right now. The dyno was reading a roughly 7-10 hp off that day do to no optical sensor. Quote Link to comment Share on other sites More sharing options...
mattd428 Posted July 2, 2013 Author Share Posted July 2, 2013 For some reason wont let me upload the graph. Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted July 2, 2013 Share Posted July 2, 2013 take a picture of it, upload to photobucket, link to photobucket. i hate loading photos to this site Quote Link to comment Share on other sites More sharing options...
mattd428 Posted July 2, 2013 Author Share Posted July 2, 2013 BAM!!!! got it Quote Link to comment Share on other sites More sharing options...
Mikelly Posted July 2, 2013 Share Posted July 2, 2013 (edited) I wouldn't focus on numbers at all... The dyno I use is horribly low, but is also the type that allows a load to be applied to the drum. Stock 2006-2013 Z06 Corvettes generally roll 370-380 WHEEL HP on it. We don't chase numbers though, as we use it as a tool to test combinations in the hunt for speed. If that's the dyno you're going to use consistently, you might want to get familiar with it, and ask the dyno guy lots of questions. Will he be tuning it for you? Did they not log any AFRs? Mike. Edited July 2, 2013 by Mikelly Quote Link to comment Share on other sites More sharing options...
mattd428 Posted July 2, 2013 Author Share Posted July 2, 2013 Havent decided who will be doing the tuning for old tuner has disappeared some where. No they didnt do any logging. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted July 2, 2013 Share Posted July 2, 2013 On 7/2/2013 at 9:40 AM, Mikelly said: I wouldn't focus on numbers at all... If that's the dyno you're going to use consistently, you might want to get familiar with it, and ask the dyno guy lots of questions. Will he be tuning it for you? Did they not log any AFRs? Mike. The numbers are kind of the point, no? While comparing numbers from different dynos can be somewhat pointless (or even ones from the same dyno at different times of year), using one dyno consistently to tune the numbers up is the whole point. So, while you may focus on the A/F and knock/timing, the numbers respond directly. But yeah, without an A/F readout you're just guessing. Quote Link to comment Share on other sites More sharing options...
Domzs Posted July 2, 2013 Share Posted July 2, 2013 On 7/2/2013 at 1:06 AM, mattd428 said: BAM!!!! got it Really ? . I think you got it upside down ? Time to juice it , Matt . Quote Link to comment Share on other sites More sharing options...
mattd428 Posted July 3, 2013 Author Share Posted July 3, 2013 On 7/2/2013 at 9:12 PM, Domzs said: Really ? . I think you got it upside down ? Time to juice it , Matt . Nope turbo time juice is cheating.......no offence sunnyz Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted July 3, 2013 Share Posted July 3, 2013 hahahahaha. OK. Because boost is waaaaay different. (still a power adder) Quote Link to comment Share on other sites More sharing options...
