280z 5.3 Turbo Build
  • Replies 324
Posted Images
Those mounts look so simple and clean compared to the JCI mounts. I wonder how well the metal on the subframe will hold up at that location. It will get some good testing by you for sure. Looking good!
These look similar to the Hawks 3rd gen set-up they are simple and free up tons of room
Awesome work man! Where abouts in Iowa are you?? Im from cf and I just picked up a 280z recently and I am planning to go the same route as you but rather with the 4.8l. However I did just find a crashed gto ls2 with 20k miles on it which is very tempting...  however I have a lot of body work and restoration work to do before I can start on the motor!
Around Des Moines
Don't need a tig to weld stainless. Comes out nicer though.
Agreed.
  • 4 weeks later...
Well the 4" was just not going to fit easily, so I picked up some 3.5", and got the DP out past the bellhousing.  Welds are kinda crappy on some of it as I was at the end of the tank of gas.
Still trying to decide if I want to dump the wastegate or just route it back in.
Thoughts?
If your worried about back pressure the dump them. If not let them recirculate them.
I'm not sure if I should be worried or not! the 3.5" downpipe should support quite a bit of power. plenty of guys making around 800 on a 3" DP.
Got a little done last night despite spending an hour and a half snowblowing  :icon55:
Hot side painted
And wrapped. Just cheapo black FG wrap from siliconeintakes.com. Double wrapped with 50% overlap on crossover. Used 50' of 1" on the one manifold, need to buy more.
Finished wrapping the hot side, put it back in the car, and worked on tying the frame rails together.
This is what I came up with. It has to be this far back to allow room for the monster Taurus E-Fan.
I was thinking about moving it further forward, in front of the radiator to allow more space in the actual engine bay. Not sure if it will be as effective, but its an option.
Edited by SUNNY Z
