Taka Time! Project bolt-on
Costing me lots so far! :) Including some new/used repair panels, I'm already up to at least $20k. A lot of labor involved getting the car stripped. I'm guessing by the time things are done, its going to be in the $30k to $35k range. Since this project has been taking over 2.5 years, it doesn't hurt as much. The bodyshop only charges me in phases. There was a lot more rust involved than the pictures i posted up... I can see why there is a lot of DIYers when it comes to bodywork. Its expensive! If I'd known how bad things were gonna get, I would have looked for a new shell... but I'll do the z gods a favor and save this one from going to the scrap yard. :)
  • Like 1
Holy crap! That's dedication! The chassis looks gorgeous though. You're essentially getting a better than brand new Z chassis though, so if you think of it that way, its kinda like buying a new car. And people spend way more than 35k on new cars.
I'm just trying to justify my own body work to myself at this point haha. Keep up the good work.
Thanks! I can only justify spending this much because I do not plan on doing another project after this car is done. Don't plan on selling the car ever either.
And more progress!! Wow! Things are moving a lot faster now. They've done more work in this past month than the previous 2 years (there's a story behind that).
So in the last few days, they did more finishing work to the exterior.
Epoxy primer getting laid down
1460142_10151731203550598_1824965212_n_z
1451408_10151731203835598_780450795_n_zp
1471172_10151731204580598_189037541_n_zp
Layer of slicksand. Nice and smooth body line! They will block sand the car again, and perhaps lay down another layer of slicksand and block sand again.
1461229_10151731206845598_1659000330_n_z
1468700_10151731206540598_1721181450_n_z
They will hang the rest of the body panels now, and then do some final fitting and adjustments, ensuring all gaps nice.
  • 7 months later...
After a 6 month hiatus, the body shop is back on my car. They started fitting the panels on the front end and discovered none of the panels fit as they should!  They ended up outsourcing my car to a frame shop because there was a twist and a slight diamonding of the front end of the car. After spending more money to get the frame straightened out professionally, panels fit MUCH better! Luckily, I had a FSM of the 260z and it had all the detailed measurements of the car. I'm glad the body shop discovered this before everything got painted!
So here are some pictures:
Body getting boarded out again to make it straight. Doors looking good.
984138_10152170690525598_721485296608305
10511287_10152166796895598_1449026036454
10527704_10152166796595598_7319902864391
10421266_10152170690865598_9104918368400
10525602_10152166796430598_7911203830280
10556432_10152170691220598_8790264490287
10525939_10152170691620598_9049156993446
10155211_10152166796800598_5067695986934
Marugen Shoukai flares getting fitted. EVERYONE should buy these! It fits awsome! I had some classic datsun flares and they didn't fit very well. With these, I will not need fender welting.
10269456_10152171110490598_3404011695930
10377430_10152171110065598_1538244950218
I've had heck of a time finding a good donor hatch. The one that came with the car was crap... Its tough up here in canada to find rust free parts. If I had a choice I would buy brand new... but of course, they are NLA.
So here is what my best hatch looks like. Still kinda rusty.
10409678_10152171110970598_5221243956931
Off it comes apart...
10537438_10152171111735598_4968868664259
Yummm... rust... Hatch will be removed and sandblasted to get rid of all the surface rust.
10389540_10152171111370598_8809426344973
Edited by takayuki
Beware of placing flares too low on body when you are mocking up at a crazy high ride height. You should mock up the flares at the ride height you plan to wide up and with the wheels and tires that you plan to run. And turn the steering lock to lock. Only then will you know where to place the flares.
Yep you bet. We will do final fitment tests before everything is finalized... I also have full coilovers and other suspension bits so I should be able to set my wheels in a desirable location.... I also don't plan on lowering the car that low because the roads here are terrible!
  • 2 months later...
No real update. Progress on the bodywork is still  slow. I'm hoping to have my car back at the end of october.
However, I decided to order my power plant from rebello racing!  3.35L stroker with ITB's!!!  Should be fun to drive with this thing!
I finally unwrapped the  Kameari Stainless headers I had for nearly 3 years. So purrrdy. I have the complete stainless exhaust too, but I'm too lazy to unwrap those just yet.
Finally some progress at the bodyshop!  Competion ETA is early november!! so excited!
some progress pics
bottom tailgate metal was replaced
10606393_10152304742630598_2158950422669
some rust repairs on the lower doors
10609447_10152304745630598_2475526387208
10437516_10152304745875598_6918527785529
10641204_10152304746115598_8176936443324
10660168_10152304746700598_4588304749589
all primed up in slicksand for more boarding!
nice and straight lines!
1240286_10152305372500598_76152782192886
10672210_10152305372175598_6536038103055
Its only in primer but the lines are looking nice and straight! so straight, you can't even see the gaps between the doors!
10329091_10152305372685598_2875333423796
Edited by takayuki
Thanks tamo3!
Things are moving faster now... goal is almost near....  some more boring bodywork pictures...
After making the car straight, the bodyshop is now fitting my rear spoiler.
rear hatch fixed!
10686934_10152317213810598_5480037462883
spoiler fitted! guy did a great job making it fit nice considering its a generic bre style spoiler
1003068_10152317214560598_44959889289697
10653807_10152317215185598_3849711358761
10437778_10152317215325598_5733041146328
1146532_10152317215605598_62578613141117
Edited by takayuki
Getting motivated now to do some work that is off the car.
Decided to start rebuilding my steering rack and linkages. The steering shaft u-joints on my car were a little worn so I went hunting for replacements... Not that there wasn't any available, but I decided to convert my steering shaft to all Woodward steering parts. They also happen to make U-joints that attaches to the stock 260z steering rack stub.
this is the stock steering column shaft
I ordered this stub. Its a 3/4" 20 spline stub
The Idea is to cut off the old U-joints, drill a hole, then weld the woodward stub in
This is how it worked out. Notice how the flange was left on....
I also had Woodward make me a custom steering shaft. It has 3/4" 20 spline ends on both sides.
Re-assembled steering column with the woodward u-joints. Also re-painted steering column tube. This U-joint has 3/4" 20 spline sockets on both ends.
Steering rack end. The u joint on the steering rack end has a 0.570" 29 spline socket to match the shaft for the nissan rack. The other end has the 3/4" 20 spline socket.
This is how it looks put together
Now.... I'm crossing my fingers that this will all work! I won't know until I get my car back.  I am hoping that the steering shaft is the right length....
Had the bodyshop fab up brackets to mount 240z bumpers on the front.
Also, Spook front air dam fitted. I'm not 100% sold on this, but I figured I try something different. There isn't much pictures floating around on the internet with s30's with flares and spook air damn.... Maybe because it doesn't look good. lol
1779278_10152361623505598_70850411008735
10437496_10152361623215598_5145136132958
Final boarding before the final coat of primer. Next time I post pictures of my car, it will be painted!
10641174_10152361624890598_7228379204000
10647097_10152361626220598_3923759996057
10639715_10152361625670598_7555407290213
10731104_10152361626015598_3790860674230
Wow! You've got a great body shop, your car looks incredible. If that steering conversion is pretty easy, you could probably make a little money doing them. All of us have ancient linkage and it bothers me a lot to think of a steering shaft failure. I may hit you up for info on that via PM in the future. I see an electric steer assist in my future unless I start lifting weights.
Yeah, the bodyshop is sure exceeding my expectations for quality so far! They've done a lot that I would have never known.
I was definitely going to share my steering conversion with the community once I have everything properly fitted and tested. Didn't want to be too open about it until I did some R/D myself. The cost is subjective to each person, but I found it reasonable for something I may never have to repair or replace. The weld stub on the column was $6, two u-joints cost $60 each, the custom steering shaft was $75, and the labor to install the stub onto the steering column shaft was $105 (labor is very high where I live). If you can weld and fabricate yourself, this setup can cost you about $201(not including shipping) in just parts. If you can weld and fabricate yourself, it won't cost you much more.
The woodward u-joints look very high quality and it should last you a very long time. way longer than the stock u-joints.
I'm not sure, but it kinda looks like your flare is mounted too low on the front side - may want to double check that. Otherwise, everything looks amazing. You're gonna have an incredibly nice Z when it's all done.
I've had few people tell me this.. Not sure if its the camera angle, but the fitment of the flares are where I want it to be. I have no intentions of slamming this car at all. Roads where I live are TERRIBLE! There are gnarly speed bumps and dips in the road. My car will not survive if I had it lowered too much.
