ZXT T5 trans tailshaft bushing R&R
madkaw
I have been flogging the internet for hours trying to aquire info regarding this.
Why, because i can grab my DS at the yoke closest to the tailshaft and get lot's of movement along with audible clunk(though not loud), that's with just my hands-eek!
I've been chasing a high speed vibration forever and the DS has been checked and balanced twice.
The problem is that the Nissan T5 is an oddity with a 1.3" tailshaft vs. the Ford 1.5". so parts don't interchange. I have found the seal which is SKF 13958 and that info was found on this site as well as others. The bushing/sleeve in the tail shaft keeps everything tight and square and I am trying to order now from Drivetrain.com-part# 301396
Another issue with this project is finding someone that can replace it. Most trans shops are set up for doing the Ford T5 and have the appropriate puller, but it won't work on the smaller tail shaft. For a Ford, this job can be done with the trans in the car and a couple of hours. The other option is pulling the trans and separating the case and pressing out the bushing-well we know how much work that is.
So can anyone add to this or your experience? There's a Z guy on the CTZCC that started a really nice thread on this with pics and all, but never finished the thread;(   I'm in the process of trying to contact him now, so I'll let you know how that goes.
I had my driveshaft custom made by a company in California called Wenco. The rear was the done with the NEAPCO adapter to use the Chevy 1310 size joint but I went with a new Nissan T5 front. He said he could reduce the OD of a Chrysler Torqueflite input shaft which had the right spline count but the wrong seal diameter and I could run 1310 joints in both ends.
Knowing that, you could bore the tailshaft out to take a bushing the size of the Torqueflite input shaft, or you could have the TF shaft reduced in diameter to match the "worn" bushing in the Nissan housing.
Seems you could also cut the bushing out (slowly and carefully!) and then press the new one in DIY.
Wow, great info to use. So a Chrylser DS for the torqueflite trans has the same input spline, but it's OD is bigger then the Nissan T-5?
I don't have nor can I aquire a new bushing for the Nissan t-5, so pressing out the old one gets me nothing except maybe something to match.
  • 4 weeks later...
Still plugging away at this. I have been wanting to go to a trans shop for them to give me an opinion about the side play. I know the owner thru a friend so I think I can plan on an honest assessment. I also wonder if I sized the DS too short and it sits too far off the tailshaft allowing for play. I looked at another T-5(out of a car) and tried the DS in it, and depending on how far the splines were meshed was directly related to the play. It seemed that the yoke had to be all the way up on the spline to eliminate play. But what play amount is normal or tolerable? I don't know so i am taking it to a trans guy.
Thru  searching I have found similiar issues, but usually yoke not properly centered on the DS. My DS was made by a DS shop and I have taken it back for verification of balance.
Since the diff does not move as much as a live axle car the drive shaft should not need very much travel on the splines.I am guessing but if the drive shaft was fully inserted it should only needed to be backed out .5" to .75" before bolting onto the diff.Maybe try a oem nissan bushing.Try www.transtar1.com for parts
  • 6 months later...
  • 8 months later...
  • 7 years later...
