Budget Radiator Setups: Please Advise Us
I have searched the forum, PMd multiple people, reviewed the thread that was recent as of Sept 2014, and there is no general consensus on what upper and lower radiator hoses will work with a stock 280z Radiator &LS1 motor setup. I plan on purchasing an aftermarket replacement, as I cant bring myself to spend $85 on mounts and $75 on hoses from JTR. What does everyone run for a budget setup?
Edited by sloganish
The stock radiator with four cores supported me and 350+ HP forever.
Not much cheaper than 'stock'
Im going this same route, my question is aimed at what hoses as well, upper and lower. Theres another thread that isnt exactly clear on what everyone is running for hoses!
"240z small block radiator hoses" on Google brought up some stuff.  Here's one of several - http://purplesagetradingpost.com/sumner/techinfo/73%20Datsun%20Z%20-%20Small%20Block%20Chevy.html
The inlets/outlets on an LS1 car water pump do not line up with a SBC as far as I recall, also this has no part numbers for what I'm looking for.
Take a couple coat hangers and bend them to the approximate shape needed to connect point a to a and b to b and take them to your friendly auto parts retailer and see what's closest fit. You can get a coupling if you need to rotate it.
I used an aluminum double pass radiator from speedway that was pretty reasonable. Check out my build thread finally got started there may be some part #s
I have a 1977 280Z with the Johns Cars LS1 conversion using a 4-row 280Z radiator.  If you really want the hose numbers PM me and I'll go out to the car and see if I can find some numbers.  They've been there for 11 years now so hopefully the numbers are still on them.
