bestlowrida Posted January 27, 2015 Share Posted January 27, 2015 Hey everybody. I have picked up a rb20det engine for my 71 240z which currently has the stock l24. I've been researching and planning the swap for years but still unsure about the fuel system for my carb conversion to efi. I know I have to upgrade the lines with 3/8 size return/feed lines and add an inline walbro fuel pump. I understand that i have the following options correct me if I'm wrong: !. Modify stock 240z fuel tank with a sump. 2. Replace stock tank with a 280z tank. 3. Keep stock tank but add a surge tank in the system. Which is what you guys are currently running in your setups or recommend? This car will be a weekend street car with a hp goal of 300. PS. Will I need to modify my driveshaft? I been searching and searching for a while but still unsure thank you in advance! Quote Link to comment Share on other sites More sharing options...
EF Ian Posted January 27, 2015 Share Posted January 27, 2015 Cheapest is to keep stock tank and run a surge tank, neatest is a custom tank with in tank pump or a fuel cell. Depends what you are after. Look at some of the build on here to help you decide what you want, lots of different way to go can be seen on each build. Lots of research but I easily put in many hundreds of hours of research on my build. From what I understand 300hp is about the limit for U-joint shafts so you will probably be ok without upgrading to CV's. Quote Link to comment Share on other sites More sharing options...
Klmykvl Posted January 27, 2015 Share Posted January 27, 2015 I agree with Ian. With a surge tank you shouldn't need a larger return. Use a HVLP pump from the tank to the cell and Your Walbro from the surge tank to the fuel rail. Route the return from the rail to the surge tank and another return from the surge tank to the old return line on your chassis. Quote Link to comment Share on other sites More sharing options...
Bishopsrock Posted January 31, 2015 Share Posted January 31, 2015 I mounted a GTR fuel pump in a 260z tank. Here is the info about it:- http://forums.hybridz.org/topic/67475-gtr-in-tank-pump-mounted-in-260z-baffled-tank-fitted-to-240z-how-to-pics/ I have little experience with the RB20 so all I can say is that this may be of some help. Quote Link to comment Share on other sites More sharing options...
bestlowrida Posted February 26, 2015 Author Share Posted February 26, 2015 thanks guys, so far I decided to go with the sump since I have a welder. DIY pics coming soon! Quote Link to comment Share on other sites More sharing options...
helghast7 Posted February 27, 2015 Share Posted February 27, 2015 I don't know the dimensions of your tank but Aeromotive's Phantom kit dropped right into my 78 tank, only need to slightly modify the trunk and i'm good to go. Not sure if this link is any good but my photobucket doesn't seem to want to cooperate right now. https://www.facebook.com/photo.php?fbid=10154746477740621&l=12ff477682 Quote Link to comment Share on other sites More sharing options...
mtnickel Posted February 27, 2015 Share Posted February 27, 2015 On 2/27/2015 at 4:56 AM, helghast7 said: I don't know the dimensions of your tank but Aeromotive's Phantom kit dropped right into my 78 tank, only need to slightly modify the trunk and i'm good to go. Not sure if this link is any good but my photobucket doesn't seem to want to cooperate right now. https://www.facebook.com/photo.php?fbid=10154746477740621&l=12ff477682 After going through all the trouble of welding into a stock tank, I can easily say I wish I had gone a similar route to this one listed. I welded in a baffling system, had to replace the return to drain into the same baffles, and then also had to deal with all the fiddly pre-pump filter, clamps, mounting fuel pump, etc etc. Having a tried and true simple drop in would have saved some headaches. I've even read threads (maybe not on here) of users just buying a junkyard tank/pump assembly from a nice modern car and bolting it in the same way as above. Good luck either way. Quote Link to comment Share on other sites More sharing options...
