calZ Posted September 1, 2020 Share Posted September 1, 2020 What shape are your suspension bushings in? If they're extremely worn, it's possible that under load the suspension geometry could change, despite it being aligned correctly while static. Quote Link to comment Share on other sites More sharing options...
zev Posted September 2, 2020 Share Posted September 2, 2020 (edited) Here are some pics. I'm no diff expert either but those do seem like clutch plates stacked up if you look at the closeup in the first pic. Also I apologize I misspoke about the direction the stub shafts spin. They don't spin in opposite directions, I just meant I was rotating them in opposite directions to feel how much play was present before the clutch engaged and stopped me, but they both rotate in the same direction. I've been thinking about the dog tracking video since this afternoon and decided to double check the printout from my last alignment. My current measurements in the rear are 0.11 degrees of positive toe (toe in) on each side (22 degrees total toe in) and a thrust angle of zero. I was under the impression a small amount of toe in is good for stability but I didn't consider that maybe improper toe could be the culprit. Does anything about the above measurement seem like it could cause the rear of the car to walk out suddenly under hard acceleration? If so, I'd love any guidance and I'll button this thing up, go get the toe adjusted and report back. Seems like a good idea to rule that out totally before installing the OSG unit. Especially since once it's installed I can't send it back! Edited September 2, 2020 by zev Quote Link to comment Share on other sites More sharing options...
madkaw Posted July 15, 2021 Share Posted July 15, 2021 So what was the outcome here . I noticed my 3.90 CLSD ( Subaru’s ) has significant play at the axles . I’m talking up and down movement of the axle at the diff . I know the STI’s don’t mount their diffs the same as ours . They are rubber mounted I believe. Quote Link to comment Share on other sites More sharing options...
zev Posted July 16, 2021 Share Posted July 16, 2021 I just decided to live with the play for now. I'm going to upgrade to the Giken LSD at some point and see if that helps. Quote Link to comment Share on other sites More sharing options...
