T-5 Fluid Leak - This is probably a dumb question...
So I'm getting ready to mount my T-5 to the bellhousing.  I changed the gear oil, and while tipping the transmission to work out the old mount bolts, I noticed A LOT of gear oil pouring out of the tailshaft housing.
Is this normal?  The oil seal back there looks fine.  I guess my question is if the seal is actually made when the driveshaft slip-yoke is slid in, or if it should be all sealed up as is.
An old Driveshaft stub and rubber trucker's strap stops that leak.
They make plastic plugs for removing/installing trannies without draining.
On some of the Datsun stuff, there are spray can tops that slip over the dust cover, and have an inner cup that snaps onto the spray can that slips right inside the seal lip as well...making for a super-cheap plug! I want to say "Wal Mart Carb Cleaner" is one of the caps that works...
