Head gasket question, E88 on F54
joem64
Andreas is right, considering bore size.  I was thinking of the classic N42, N47, F54, P90 head and gasket problem.  L28 heads on L28 blocks.  You have an L24/L26 head on an L28 block so an L24/L26 gasket might not seal the bore.
Take measurements and consider coolant flow.
Thanks for all of the replies.  Figured someone has done this already....thought it was the 'thing' to install E31 heads on 280Z blocks...
I've had my block bored out 1mm over.
I'm not sure what's what when looking at the holes and such, what's oil, what's coolant.
Interesting.
thanks again, i'll dig a little myself and see what i figure out.
joe in WI
I just put a 72 E88 on 81 F54. The F54 had the original P79 head which had two more coolant openings. When I put on the Felpro gasket listed for the 81 F54 block , I drilled out the two openings the E88 head didn't have. I fed a wire up through other openings to make sure I was drilling into a coolant passage.
Edited by BJSZED
