broken spark plugs??????
hey guys i was driving my car and it felt sloooooooow so i figured well maybe the humidity but then i reved it up and it reved slow too so i took the plugs out and three had the ceramic around the electrode broken :eek: It just broke and slid over the gap of the plug :confused: this happened one time before but it only effected one plug and now i have three.Has anyone ever seen this happen?If so why?
I've heard tell sometimes you don't hear detonation until it's too late. What color were the insulators? If they were close to white, maybe you should try a colder heat range, but I'd not push your boost any more, or back it off some, until you figure out what it is. Ceramic chips can't be good in a (relatively) soft steel engine cylinder.
Hopefully someone with more experience will chime in here, but you can't always HEAR detonation when you are right on the ragged edge of it. Turbo had a good article on this a little over a year ago... If I can dig it up, I'll quote from it tonight. However, If it were one, you might be able to just say "Well I got a bad plug" but three??? Scottie, you've got a serious problems there and as someone else mentioned, if you don't fix it, you should start shopping for a boat because you will have the anchor... I'd also recommend you get an air/fuel meter, and make sure it is a good one, and then I'd off the boost.
Well I did some more thinking, and it could be you are way lean too. My plugs have a nice tanish brown color on them. Leaness would make ton's of excess heat, which could be causing the insulators to crack.
Scottie, I run 98 BWM M3 dual electrode plugs in mine, since they are easy to index. They are of course a bosch plug, and their systen works alot like NGK's, the higher the number the cooler the plug. If you have NGK's, they should be heat range 7.
Whatever your problem, you need to get a handle on it. Good luck.
thanks for the help guys i really appreciate the comments.Now to the tech part ok i'm running ac delco plugs(i know not the best)they are for the zxt motor.I was also thinking maybe they could be too hot and when the turbo blows cooler air on them they might be breaking.Or it could be that it is detonating and i am not hearing it.I am gonna check the timing tonight to make sure it's right i could have timed it wrong too.The plugs are all black from running rich but the first time this happened they where all brownish except for the broken one it was black from all the gas not getting burned right.After it started running bad i drove alot on them that's why they are black.I think i'm gonna go with bosch plugs now and get rid of the ac delco ones.I just put them in cuz i needed somthing and they where there.Like i said as far as the plugs actually breaking into pieces they aren't you can't even see where they broke it's up so far into the plug.I wish i could show them to you guys it would be a little easier.Everyone i show them to is baffled too unless i got a bad batch of plugs.I dunno but i have the boost turned back and i am taking it easy until i figure out what it is.I do have a a/f gauge and it's an autometer one works great and it never goes lean it actually runs rich ad i just replaced the o2 sensor so i know it's good.I'll keep you guys posted my g-friend's dad who i get my parts from is gonna call ac delco and ask them.
  Quote
Originally posted by Jim Powers:
You don't suppose it could be detonating while the BOV is making it's racket?
Actually the car runs a little richer after the BOV releases the air (if it's not rerouted back to the intake pipes).
Scotty I would get NGK's instead ACD. I'm sure you get a discount from your g-friend's dad :D
ok guys the timng was only off like 3to 4 degrees so now it's 20 degrees btdc and it runs better and i can get more boost out of it.But it still doesn't explain the plugs.I'll just buy bosch plugs and call it good if it breaks those then it's definately an engine prob.Thanks guys
Which part number NGK did you get? I am running the BPR7ES, one heat range cold. I checked them last night, and they were a nice tan color with some carbon buildup - have some tuning work I think, before it will pass emissions.
Scotty...
For the amount of boost you have been running, you really should heed everybody's advice and go to at least the BPR-7ES NGK. I'm running -8ES's on mine.
The -6ES plugs are too hot for your application - this can make you more detonation-prone.
