L28et Dizzy no rpm Ms2extra
supershanesta
Hey guys. My last issue is with my Dizzy on my MS2extra
I have had it working at some point during testing, but now it is not getting signal in car.
I have 12v power in red position on dizzy
I have white wire (tach wire) from ms2 harness in white wire position on dizzy
I have black wire (tach wire) from ms2 harness in ground position on dizzy with pull up resistor in ms2.
I have it wired and try to spin the dizzy by hand with no results in basic mode or in wheel mode because I am using the DIY wheel.
If i tap the black tach wire to the white tach wire (creating the tach current) I get rpm signal, but through my dizzy I do not.
I had one cas that came with the car that never worked so I bought the replacement to put in that worked, but now suddenly it seems fried or something.
Is there an easy way to test out the cas unit?
Thanks,
Shane
I think Issa has a faulty CAS sensor as well. Trigger and Tooth logs are all over the place and intermittent.
Car ran great one run, then  as I watched in real time,   the Tooth logs took a dump and the car died.  Trigger logs and Tooth logs were very broken up. Think CAS said.... Buh Bye!!
