Tito Posted November 25, 2018 Share Posted November 25, 2018 I have a 1978 datsun 280z cranks but won't start .i already checked the 3 main relay s to run the fuel pump and nothing no power to the pump.please anyone here where should I check next? Quote Link to comment Share on other sites More sharing options...
Miles Posted November 25, 2018 Share Posted November 25, 2018 Procedure is in the FSM Useful information Download a Factory Service Manual (FSM). http://forums.hybridz.org/topic/48825-factory-manuals-some/?page=2&tab=comments#comment-1208329 Download electrical schematics for your car. PDFs are easier to read than those found in books. Some are in color. Buy the book How to Restore Your Datsun Z Car by Wick Humble. It will save you hours of searching for "how to" info. Focus on searching Hybridz as 99% of questions have already been addressed. Start bookmarking Z car parts suppliers - there are many! Remember these are 40 year old cars and will need restoration to be safe and drivable. Join ClassicZCars.com website and search there as well. Become well informed about modifications before asking questions. People will be more inclined to answer informed questions. Search the forums. Useful Links: https://www.datsun-240z-upgrades.net/ Recommend the headlight relay harness http://zhome.com/ https://www.zcar.com/ http://www.classiczc...com/index.html/ http://www.zcarparts.com/ http://www.arizonazcar.com/ http://www.jagsthatrun.com/index.html 1 Quote Link to comment Share on other sites More sharing options...
Tito Posted November 26, 2018 Author Share Posted November 26, 2018 I'll continue looking Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted November 26, 2018 Share Posted November 26, 2018 1 hour ago, Miles said: Join ClassicZCars.com website and search there as well. Ask the question over there. They deal with gremlins in stock Z's all the time. Quote Link to comment Share on other sites More sharing options...
Tito Posted November 26, 2018 Author Share Posted November 26, 2018 Thanks bro Quote Link to comment Share on other sites More sharing options...
NewZed Posted November 26, 2018 Share Posted November 26, 2018 18 hours ago, Tito said: I have a 1978 datsun 280z cranks but won't start .i already checked the 3 main relay s to run the fuel pump and nothing no power to the pump.please anyone here where should I check next? Did you actually check voltage at the pump? Or just assume that it had no power because it's not working? Om the 78's you can disconnect the oil pressure sender and the pump should get power when the key is on. Easier than trying to measure it while cranking. That will at least tell you if the pump circuit is complete. Quote Link to comment Share on other sites More sharing options...
Tito Posted November 26, 2018 Author Share Posted November 26, 2018 Newzed I'm gonna try that with the oil pressure sender disconnected. And I disconnected the fuel pump conectors behind passenger seat,i attached a multimeter and I got no voltage when key on and not even when cranking.. Now I'm fixing some wires.im soldering those wires That go to the fusible links they are rusted And corrorroed Quote Link to comment Share on other sites More sharing options...
NewZed Posted November 26, 2018 Share Posted November 26, 2018 The 78 system has a lot more parts and connections to get screwed up. You're starting in the right spot, the fusible links. Classiczcars.com has wiring diagrams and factory service manuals. They'll help a lot for troubleshooting, with a meter. Quote Link to comment Share on other sites More sharing options...
Tito Posted November 26, 2018 Author Share Posted November 26, 2018 Newzed do you know where to get the relays for the fuel pump Quote Link to comment Share on other sites More sharing options...
NewZed Posted November 26, 2018 Share Posted November 26, 2018 Get the part number and Google it. Here's a link or you can just take yours out, the numbers are on the side. http://www.carpartsmanual.com/datsuns30/Datsun-Z-Index/Electrical/Electric-Unit-Switch/Section-1/280Z Quote Link to comment Share on other sites More sharing options...
Sjoost Posted November 29, 2018 Share Posted November 29, 2018 Tito, I had same issue some time ago. Did you check my quest? http://forums.hybridz.org/topic/129390-fuel-pump-and-relais/ 1. Looked like I had some thing with a stuck relais or beeper for the seat belt 2. The new ignition switch did not work correct. When pressing hard on the starter key my switch was working. I fixed that later. My relais were all fine in the end. Hope it helps Quote Link to comment Share on other sites More sharing options...
Tito Posted January 21, 2019 Author Share Posted January 21, 2019 I fixed already those wires that were rusty,, now I removed the maf sensor and I sprayed starting fluid and it turned on right away and smooth,, but once again. I check all the relays with the multimeter and apparently they are fine and I still have no voltage at fuel pump. Please help guys I will appreciate so much. Quote Link to comment Share on other sites More sharing options...
Sjoost Posted January 21, 2019 Share Posted January 21, 2019 Tito, If you disconnect feed wire to the solenoid of the starter motor (so it does not start if you turn ignition to starts), and remove the left side block connector (88c, 86,88a,86b,88b) from the fuel injection relais, and turn the ignition to "start" (keep it on start), and measure the voltage on the fuel pump terminals, what do you measure (not really easy to do, and extra hands help here)? & did you check all the circuits from the icu (see page 45 onward, http://www.atlanticz.ca/zclub/techtips/efisystem/280zfuelinjectionbook.pdf)? Greetz Joost Quote Link to comment Share on other sites More sharing options...
Tito Posted January 21, 2019 Author Share Posted January 21, 2019 I think I did that but with the feed wire still in the solenoid. Behind the passeger seat I found the connectors of the fuel pummp .i attached the multimeter and when I start it I got 0 voltage Quote Link to comment Share on other sites More sharing options...
NewZed Posted January 21, 2019 Share Posted January 21, 2019 You're jumping around from idea to idea. Follow the power from the battery to the pump. Come back and post where you last saw voltage. The "Ign" fusible link then pin 93 of the fuel pump relay are your first two spots to check. Quote Link to comment Share on other sites More sharing options...
