Plugs in head (4 near cam)
3 hours ago, ZHoob2004 said:
Core plugs for the coolant passages. My machinist said there's usually no reason to remove them.
2 hours ago, D9inger said:
I’m glad you could answer that, I was drawing a blank
Thanks guys. I screwed up, and wasn't paying attention... I ended taking one out, thinking it was a head screw, and stripped the socket head during the process. zcardepot doesn't carry them. They look the run of the mill. Are there anything special with them? BSPT?
18 hours ago, D9inger said:
I'm pretty sure they are BSPT Male. It's a metric tapered thread.
https://www.mcmaster.com/metric-pipe-fitting-plugs
If you google it, it'll explain allot, or look here
https://www.ralstoninst.com/news/story/the-difference-between-npt-bspp-and-bspt-seals
It's NOT NPT
Thanks, I was hedged my bet with bspt; being Japanese and all. Unfortunately, mcmaster carr only carried the lower profile ones. I ended ordering some thru ebay.
And for anyone else that runs into this trouble... I measured the plug to be 1/2" pipe thread (assumed BPST) and 20mm thick.
Edited by scartail
