jjslade Posted May 30, 2020 Share Posted May 30, 2020 with this setup current my SU’s are cranked all the way to the top, idle screws set as low as possible, and it’s still idling at 2000rpm and incredibly rich, so i’m thinking when i ordered a carb rebuild kit i bought the wrong needle? could someone please recommend me an appropriate needle for this setup? Kind regards Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted May 30, 2020 Share Posted May 30, 2020 What needles are you using and have you set the float levels. The float level is the primary mixture adjustment. Quote Link to comment Share on other sites More sharing options...
jonbill Posted May 31, 2020 Share Posted May 31, 2020 if its idling at 2000, your first problem is too much air, not too much fuel. Quote Link to comment Share on other sites More sharing options...
jjslade Posted June 1, 2020 Author Share Posted June 1, 2020 On 5/30/2020 at 3:27 PM, bunkhouse said: What needles are you using and have you set the float levels. The float level is the primary mixture adjustment. Expand Not sure what needles they are, i just bought a 240z carb rebuild kit on ebay, float level is reccomended to be set at 14-15mm so i set both at 14.5 Quote Link to comment Share on other sites More sharing options...
jjslade Posted June 1, 2020 Author Share Posted June 1, 2020 On 5/31/2020 at 6:45 AM, jonbill said: if its idling at 2000, your first problem is too much air, not too much fuel. Expand how could i reduce the amount of air going in? i’ve tried spraying started fluid all around the intake & manifold and nothing causes a rise in rpm, should i try with the air cleaner fitted ? Quote Link to comment Share on other sites More sharing options...
jjslade Posted June 1, 2020 Author Share Posted June 1, 2020 there’s really a lot of white smoke coming out the back, but i’ve got a brand new head gasket, and just using regular water for coolant temporarily plugs are black and sooted after 1 minute of running Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted June 1, 2020 Share Posted June 1, 2020 Two interesting problems. Plugs are black, idle is too high. Jonbill is correct about too much air causing the high idle and it must be getting too much fuel judging by the plug color. Describe your carb rebuild. What did you take apart and reassemble? Did you interchange any parts from one carb to the other? Quote Link to comment Share on other sites More sharing options...
jjslade Posted June 3, 2020 Author Share Posted June 3, 2020 On 6/1/2020 at 2:19 PM, bunkhouse said: Two interesting problems. Plugs are black, idle is too high. Jonbill is correct about too much air causing the high idle and it must be getting too much fuel judging by the plug color. Describe your carb rebuild. What did you take apart and reassemble? Did you interchange any parts from one carb to the other? Expand it wasn’t a full rebuilt i just bought a refurbed set of su’s on ebay and some how the needles were bent. i’ve sprayed started fluid all around so i know there’s no vacuum leak Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted June 4, 2020 Share Posted June 4, 2020 Raise both pistons with your fingers and let them drop. You should feel considerable resistance when raising them and they should both fall at the same rate and hit bottom at nearly same time. Quote Link to comment Share on other sites More sharing options...
jonbill Posted June 4, 2020 Share Posted June 4, 2020 are you sure the choke is off? Quote Link to comment Share on other sites More sharing options...
jjslade Posted June 4, 2020 Author Share Posted June 4, 2020 On 6/4/2020 at 2:44 AM, bunkhouse said: Raise both pistons with your fingers and let them drop. You should feel considerable resistance when raising them and they should both fall at the same rate and hit bottom at nearly same time. Expand Yep they both are hard to raise and fall slowly, have correct oil in dashpot Quote Link to comment Share on other sites More sharing options...
jjslade Posted June 4, 2020 Author Share Posted June 4, 2020 On 6/4/2020 at 7:03 AM, jonbill said: are you sure the choke is off? Expand choke is 100% off Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted June 4, 2020 Share Posted June 4, 2020 Do you have the vacuum hose connected to the booster on the brakes? If so, disconnect it and plug it. You may have a big vacuum leak internal to the booster. 1 Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted June 4, 2020 Share Posted June 4, 2020 Next time you fire it up watch the carb pistons to see if they raise to the same height. Quote Link to comment Share on other sites More sharing options...
porkbun Posted June 8, 2020 Share Posted June 8, 2020 My guess is its running rich because you have the wrong needles/did not install them properly. My suggestions: Check that the needles that came with the carbs match (if you can still read the markings) then throw them in a drill or dremel and straighten them out by hand (you do not need a lot of speed for this so be careful that you are not removing material). When you change the needles back to the originals are you still running rich? For the high idle, remove the center linkage between the carbs and see if it still idles high. The 260Z linkage has a nub on the linkage for the front carb that keeps the front carb slightly open. I had to sand it down for the engine to idle at a reasonable speed. Quote Link to comment Share on other sites More sharing options...
