Datsunfsu Posted October 25, 2020 Share Posted October 25, 2020 These are the front brakes with the 5 lug conversion and vented rotors. Question on how to get the cap off to tighten the hubs? I feel like I’ve tried everything to separate or removed about all bolts. These were done from a prior owner and discontinued. Can’t find anything about these when searching either. Wondering if someone has this setup. Don’t have any image hosting to post a pic. Any help will be great. Quote Link to comment Share on other sites More sharing options...
calZ Posted October 25, 2020 Share Posted October 25, 2020 You don't need an image hosting service. You can upload the image directly into your post. You want to tighten the hub nut? I don't know what MM hubs look like, but if they're the same as any other hub you just pop the cap off with a chisel or screwdriver. You could probably get by with a hard plastic trim tool if they have a nice finish you don't want to scratch. Quote Link to comment Share on other sites More sharing options...
Datsunfsu Posted October 25, 2020 Author Share Posted October 25, 2020 Thanks. Missed the upload button. These seem different than the normal z ones Quote Link to comment Share on other sites More sharing options...
Miles Posted October 26, 2020 Share Posted October 26, 2020 Is the cap threaded? Perhaps it will unscrew. Quote Link to comment Share on other sites More sharing options...
Datsunfsu Posted October 26, 2020 Author Share Posted October 26, 2020 Tried that. Nothing to grip onto as the elite outside is smooth. Quote Link to comment Share on other sites More sharing options...
Miles Posted October 26, 2020 Share Posted October 26, 2020 (edited) Your cap may be threaded like the attached picture. Apply heat around the outside and unscrew the cap with channel lock pliers? Propane torch would do it. Edited October 26, 2020 by Miles added picture of threaded dust cap Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 26, 2020 Share Posted October 26, 2020 How about a strap wrench? Quote Link to comment Share on other sites More sharing options...
Datsunfsu Posted October 26, 2020 Author Share Posted October 26, 2020 Going to pick one up after work today and give it a try with those wrenches Quote Link to comment Share on other sites More sharing options...
pchermit Posted October 26, 2020 Share Posted October 26, 2020 It will tear it up more than likely but a pipe wrench might do the trick if you are desperate. Quote Link to comment Share on other sites More sharing options...
Datsunfsu Posted October 26, 2020 Author Share Posted October 26, 2020 Couldn’t get a strap in there but I gave in and did the pipe wrench after heat. Came off and it is threaded. Thanks for everyone’s input. Maybe this will help someone down the road. Quote Link to comment Share on other sites More sharing options...
