A to Z Posted December 13, 2021 Share Posted December 13, 2021 (edited) SPRAY MAX 2K Gloss Clear....****DO NOT USE THIS!!! IT HAS ISOCYANATES IT IN, IT IS VERY POISIOUS, IF YOU BREATHE IT, IT CAN KILL YOU. **** I used it today and it screwed me up a tad even just a hour maybe 2 with a mask on (dental mask). VERY bad stuff. Please read and heed. It is the same as some of the professional body work and paint stuff. Those guys wear respirators to protect them. A shade tree guy can try to use it like KRYLON and hurt themselves BAD. Please avoid this and stay away from paint with Isocyanates in it. Like I said, just a tad exposure and I can feel it. Edited December 13, 2021 by A to Z Quote Link to comment Share on other sites More sharing options...
calZ Posted December 13, 2021 Share Posted December 13, 2021 Shade tree guys should still use respirators. PPE is very important in the garage Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted December 13, 2021 Share Posted December 13, 2021 Absolutely agree Isocyanurate is toxic, but it is in almost every 2-component epoxy and urethane I have ever worked with. Spray Max is just 2-component in a can, and a plunger to release the hardener. 3M respirator with the right carbon scrubber canisters should do just fine with these chemicals. These respirators aren’t very expensive. I don’t spray any sort of paint or coating without wearing a respirator though, and I encourage everyone else to do the same. Even spray-on enamel has chemicals that will cause long-term harm if breathed in often. Isocyanurate is also toxic to the skin and eyes, so I only brush it on inside my garage. I do any spraying in my driveway. Quote Link to comment Share on other sites More sharing options...
fusion Posted December 13, 2021 Share Posted December 13, 2021 Absolutely agree with the above. You shouldn't be spraying even Krylon without a respirator. Quote Link to comment Share on other sites More sharing options...
A to Z Posted December 14, 2021 Author Share Posted December 14, 2021 Thanks. Yeah, real scare. I purchased a 3M P100 respirator at Lowe's today. Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted December 14, 2021 Share Posted December 14, 2021 9 hours ago, A to Z said: Thanks. Yeah, real scare. I purchased a 3M P100 respirator at Lowe's today. hmmm, is it OV/P100 or just P100? The P100 filters alone look like little saucers and are insufficient for organic volatiles. If it looks like a “canister”, 1.5” thick or so, then it’s the right filter. There is a little fold-out that comes with the canister describing the precise chemicals it protects against. if you can “smell” VOC’s, the respirator is not working. the regular p100 particulate filter is used for particulates (grinding) and vaporized metals from welding. I regularly switch between two masks, with the two different filter elements I need. Quote Link to comment Share on other sites More sharing options...
A to Z Posted December 16, 2021 Author Share Posted December 16, 2021 they are the canisters......soemthing like OG/AV/P100 Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted December 16, 2021 Share Posted December 16, 2021 Sweet! You good good luck! Quote Link to comment Share on other sites More sharing options...
